Shlyahov
No-IP & DNSdynamic update
Mon Apr 03, 2017 7:19 pm
Exellent working script for update DDNS of NO-IP in conjunction with DNSdynamic Sevices.
Debugging and checking done.
Made because of the unreliability of long-term work without confirmation on NO-IP service.
I am sorry for my bad english
# No-IP, DNSdynamic update
#--------------- Change Values in this section to match your setup ------------------
#User account info
:local noipuser "NO-IP_User_Name"
:local noippass "NO-IP_password"
:local dnsdynamicuser "DNSdynamic_User_Name"
:local dnsdynamicpass "DNSdynamic_password"
:local noiphost "NO-IP_host"
:local dnsdynamichost "DNSdynamic_host"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "Internet_Interface_Name"
#-------------------No more changes need---------------------------------------------
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interface
   :local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# Strip the net mask off the IP address
   :for i from=( [:len $currentIP] - 1) to=0 do={
       :if ( [:pick $currentIP $i] = "/") do={
           :set currentIP [:pick $currentIP 0 $i]
   :if ($currentIP != $previousIP) do={
       :log info "IP: Current IP $currentIP is not equal to previous IP, update needed"
       :set previousIP $currentIP
# The update No-Ip URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
       :local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
       :local noiphostarray
       :set noiphostarray [:toarray $noiphost]
       :foreach host in=$noiphostarray do={
           :log info "No-IP: Sending update for $host"
           /tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
           :log info "No-IP: Host $host updated on No-IP with IP $currentIP"
# The update dnsdynamic URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
       :local url "https://www.dnsdynamic.org/nic/nic/update\3Fmyip=$currentIP"
       :local dnsdynamichostarray
       :set dnsdynamichostarray [:toarray $dnsdynamichost]
       :foreach host in=$dnsdynamichostarray do={
           :log info "dnsdynamic: Sending update for $host"
           /tool fetch url=($url . "&hostname=$host") user=$dnsdynamicuser password=$dnsdynamicpass mode=http dst-path=("dnsdynamic_ddns_update-" . $host . ".txt")
           :log info "dnsdynamic: Host $host updated on dnsdynamic with IP $currentIP"
   }  else={
       :log info "IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
   :log info "IP: $inetinterface is not currently running, so therefore will not update."
Rey46
Re: No-IP & DNSdynamic update
Tue Apr 04, 2017 3:21 pm
Hi Shlyahov,
I use this script found on this forum, it works with no-ip and it doesn't require an interface so you can use with failover ;) Hope it is usefull for you and others people.
# Atualização automática de DNS Dinâmico NO-IP
#--------------- Defina os valores nessa sessão para configurar ------------------
# Informações de acesso NO-IP
:local noipuser "EMAIL OU NOME DE LOGIN DO NOIP"
:local noippass "SENHA DE LOGIN"
# Defina o nome do servidor da web a ter o IP atualizado.
# O nome do servidor não aceita espaços. Substitua o valor entre as aspas pelo nome(URL) do seu servidor.
# Para especificar vários servidores, separe-os com vírgulas.
:local noiphost "HOST, EX.: host.ddns.net"
# Não precisa alterar mais nada
:global previousIP
/tool fetch url="http://myip.dnsomatic.com/" mode=http dst-path=mypublicip.txt
:local currentIP [file get mypublicip.txt contents]
       :log info "No-IP: O ip atual $currentIP não é igual ao IP anterior, atualização necessária"
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
           :log info "No-IP: Servidor $host atualizado com o IP $currentIP"
   }  else={
       :log info "No-IP: IP anterior $previousIP é igual o IP atual, atualização não necessária."
qbek
Sat Apr 08, 2017 1:33 pm
Non of them are working for me. I have to login at noip.com and manually change ip given from RB log and hit Update hostname.
RB 951Ui-2HnD v6.39rc58 firmware 3.33
Rey46
Mon Apr 10, 2017 4:10 pm
Which errors?
qbek
Mon Apr 10, 2017 11:17 pm
Log
06:12:13 system,info router rebooted
06:12:20 pppoe,ppp,info pppoe-out1_VDSL: initializing...
06:12:20 pppoe,ppp,info pppoe-out1_VDSL: connecting...
06:12:21 interface,info ether5 link up (speed 100M, full duplex)
06:12:23 interface,info ether4 link up (speed 100M, full duplex)
06:12:25 pppoe,ppp,info pppoe-out1_VDSL: authenticated
06:12:25 pppoe,ppp,info pppoe-out1_VDSL: connected
06:12:25 system,info item added
06:15:37 script,info IP: Current IP 83.x.x.x is not equal to previous IP, update needed
06:15:37 script,info No-IP: Sending update for domain.ddns.net
06:47:17 script,info IP: Current IP 83.x.x.x is not equal to previous IP, update needed
06:47:17 script,info No-IP: Sending update for domain.ddns.net
here I delete file no-ip_ddns_update-domain.ddns.net.txt from "Files"
Fetch file contain nochg IP.
08:02:40 script,info IP: Current IP 83.x.x.x is not equal to previous IP, update needed
08:02:40 script,info No-IP: Sending update for domain.ddns.net
08:02:40 info fetch: file "no-ip_ddns_update-domain.ddns.net.txt" downloaded
08:02:41 script,info No-IP: Host domain.ddns.net updated on No-IP with IP 83.x.x.x
08:02:41 script,info dnsdynamic: Sending update for DNSdynamic_host
08:32:16 script,info IP: Current IP 83.x.x.x is not equal to previous IP, update needed
08:32:16 script,info No-IP: Sending update for domain.ddns.net
09:07:16 script,info IP: Current IP 83.x.x.x is not equal to previous IP, update needed
09:07:16 script,info No-IP: Sending update for domain.ddns.net
Scheduler:
name="no-ip" start-time=startup interval=35m on-event=/system script run no-ip owner="kuba" policy=ftp,read,write,test run-count=27 next-run=22:32:16
FAQ noip:
nochg IP_ADDRESS Success IP address is current, no update performed. Followed by a space and the IP address that it is currently set to.
Support from noip said "After reviewing our logs for this hostname I am seeing the result "badauth". It looks like the username or password inputted into the DDNS settings are wrong. It could also be that you have a special characters, like %&#...? This could cause issues, too. "
I have checked twice login and pass in script and is OK.
I disabled IP-->Cloud.
qbek
Sun Apr 16, 2017 4:06 pm
Noip support ask me to use this script.
Why I'm not getting fetch txt file now?
Can somebody test it on v6.39rc58 and newest firmware for motherboard 3.33?
# No-IP automatic Dynamic DNS update
# No-IP User account info
:local noipuser "your@email.com"
:local noippass "yourpassword"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "yourname.ddns.net"
:local inetinterface "yourinterface"
# No more changes need
#:global previousIP;
:local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address];
:set currentIP [:pick $currentIP 0 $i];
:local previousIP [:resolve "$noiphost"];
:log info "DNS IP: $previousIP, interface IP: $currentIP";
:log info "No-IP: Current IP $currentIP is not equal to previous IP $previousIP, update needed";
# :set previousIP $currentIP;
:local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP";
:log info "No-IP: Sending update for $noiphost";
/tool fetch url=($url . "&hostname=$noiphost") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
:log info "No-IP: Host $noiphost updated on No-IP with IP $currentIP";
} else={
:log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed";
} else={
:log info "No-IP: $inetinterface is not currently running, so therefore will not update.";
ahmedalmi
Sun May 14, 2017 4:17 am
enable cloud DDNS
or use this
Code: Select all
/ip cloud set ddns-enabled=yes
then try to use this
Code: Select all
:global previousIP;
:local currentIP [/ip cloud get public-address];
:log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
} else={
} else={
qbek
Mon May 15, 2017 10:38 am
Thanks but I'm using now freedns.afraid.org
saintofinternet
Forum Veteran
Forum Veteran
Mon Jun 05, 2017 7:44 pm
ver 6.38.3 has none of the scripts working for No-IP....
can someone help please?
by professionals, for professionals....
Don't forget to give KARMA!!!
sam2030
Thu Dec 21, 2017 9:53 pm
saintofinternet
Forum Veteran
Forum Veteran
Fri Dec 22, 2017 4:01 am
that was the same one i was using before the routeros upgraded.
after the upgrade it stopped working.
ErfanDL
Fri Dec 22, 2017 9:09 am
Hi try this script
its working on 6.40.x and 6.41.x RC
:local noipuser "username"
:local noippass "password"
:local noiphost "hostname-kamu.ddns.net"
:local inetinterface "ether-inet"
:global currentIP
:global previousIP
 :log info "No-IP Updater: Current IP address $currentIP is not equal to previous IP, update needed"
 :log info "No-IP Updater: Sending update for $host"
 :log info "No-IP Updater: Update change requested. Hostname $host will be updated with $currentIP"
 } else={
 :log info "No-IP Updater: Previous IP address $previousIP is equal to current IP, no update needed"
} else={
 :log info "No-IP Updater: $inetinterface is not currently running, so therefore will not update"
linhchivas
Fri Dec 29, 2017 1:07 pm
i have problem with version 6.36.in log,it write : "No-IP Updater: Previous IP address 42.x.x.x is equal to current IP, no update needed".But i check at noip,ip dont update anything.Please help me
Users browsing this forum: SiB and 19 guests
