ik3umt
How to ban an hotspot trial user ??
Fri Apr 07, 2017 5:07 pm
Once hotspot trial authentication is enabled , each connecting user is created with T-<MAC address> username
How can I disable unwanted user(s) ??
The dynamically created users can't be disabled by ip->hotspot->user section.....
gustavomam
Trainer
Trainer
Re: How to ban an hotspot trial user ??
Mon Apr 10, 2017 2:54 pm
Hello.
You can use this
/ip hotspot user remove [find where dynamic ]
Regards.
Eng. Gustavo Angulo
Academy Xperts Spain
Mikrotik Certified Trainer
https://www.youtube.com/watch?v=Cbt2HVYwjYU
ik3umt
Mon Apr 10, 2017 4:39 pm
But I also need he cannot re-login as trial (i.e. a "rogue" client)
Any way ?
Thank you
gustavomam
Trainer
Trainer
Mon Apr 10, 2017 5:31 pm
You can achieve this through a script.
The problem is how you identify "rouge" client and normal users ?
Eng. Gustavo Angulo
ik3umt
Mon Apr 10, 2017 6:16 pm
Not so easy..... i.e. a permanently "active" hotspot user or a known "active host name" in a dhcp lease....
I mean the maintainer has to identify MAC address to be banned, not routerboard automatically itself.....
gustavomam
Trainer
Trainer
Mon Apr 10, 2017 6:37 pm
Could not be easy. The administrator have to be 24/7 looking the active hotspot users?
Its easier to make a white list of users and bypass it from hotspot, in other case why do you need hotspot if you only want to give service to know users?
Eng. Gustavo Angulo
ik3umt
Thu Apr 13, 2017 4:45 pm
Just in case some non-occasional user (i.e. my neighbor's house) gets my wpa key and use hotspot as his own gateway.....
Users browsing this forum: atuxnull, se64plus and 62 guests
