MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Just blew 2 cm9s in a row
Sun Nov 12, 2006 10:44 am
Hello
On one of my busy links (Rb500 with 1 cm9 and a 5.8 26dbi grid) My cm9 just lost about 30di
I put another one in and 1 hour later same thing.
What could this be? Bad RB? Bad power?
jp
Long time Member
Long time Member
Mon Nov 13, 2006 4:34 am
Could be bad coax pigtail or poor pigtail connection to the cm9 too.
normis
Mon Nov 13, 2006 12:53 pm
the pigtail is not touching any metal parts on the card? and you have not overriden the tx-power setting to something exessive?
Equis
Forum Veteran
Forum Veteran
Mon Nov 13, 2006 11:16 pm
Hello
No The pigtail is clear.
I always use default or lower setting (law)
spire2z
Long time Member
Long time Member
Tue Nov 14, 2006 7:43 pm
I had this problem just the other day! I thought I had blown a CM9 but after replacing it worked for a while but same as you after a few hours again v low signals.
My solution was to replace pigtail and re seal N-connector and also blocked up the holes in the bottom of MikroTik outdoor case. No probs since!
I did wonder if the holes were the problem in winter damp weather?
Users browsing this forum: No registered users and 29 guests
