ropeba
snow and signal
Mon Nov 13, 2006 12:09 am
hi,
I have a link on 7 km with rb112, CM9 and grid 27db.
usualy, signal is -59db, but tonight I notice that signal is -77 db. Is it possible that snow is cousing that?
I would allso like to know wich is minimum signal for qualitet link?
Yes, link is on 5,8 GHz.
Thanks...
jwcn
Mon Nov 13, 2006 1:54 am
Snow will have that effect.
What are you showing for noise levels?
ropeba
Mon Nov 13, 2006 2:02 am
noise level is -101db
signal to noise 27 db
jwcn
Mon Nov 13, 2006 2:11 am
Experience says I worry about anything that is worse than -75 reality says I have reliable links as bad as -84 still pushing 5-7 megs of throughput...
karyal
Re: snow and signal
Tue Nov 14, 2006 12:48 am
hi,
Thanks...
Guess it depends on how much snow.. last winter i had no problems at all with snow, but we're talking of not much (about 70 cm and 5/6 times)
We do not use any grid, just panels, and this may help -.
Users browsing this forum: No registered users and 50 guests
