rgroothuis
The Dude monitoring 3 ADSL lines on Sonicwall
Tue Apr 18, 2017 11:58 pm
I'm setting up a Dude server to monitor all the Mikrotik devices in the network, it works really great and I even get Telegram notifications.
Next challenge, if possible, is that I want The Dude to monitor my three outgoing ADSL lines. The dude is installed on a local Mikrotik device within the network. The local network is connected through one Sonicwall device via 3 ADSL lines (load balancing) to the internet. How can The Dude monitor the status of those three ADSL lines. I want to get a notification if one of the ADSL lines goes down.
The ADSL modems do not have a pingable IP address. I tried to ping the public IP address but that doesn't seem to work either.
Any suggestions? Thanks.
Shadeofspirit
Re: The Dude monitoring 3 ADSL lines on Sonicwall
Wed Apr 19, 2017 12:36 am
look for SNMP option in sonicwall. if it supports it - look what kind of information it can provide, if you are lucky one - there wiil be information about links
MTCNA, MTCWE
rgroothuis
Wed Apr 19, 2017 10:02 am
Yes, thanks. Found that option, SNMP is giving me a lot of info. Next question is how can I set triggers on SNMP info in The Dude? Like if interface X0 is down then send report etc.
After this post I will do some further searching and investigations as well.
Shadeofspirit
Wed Apr 19, 2017 10:12 am
you should find sonicwall snmp oid for link state (up or down). Create probe in dude. add it to sonicwall in dude or create a new device in dude (for each adsl link) without ping, just with this new probe. Try to google "dude snmp link state", there are some examples in internet
Отправлено с моего Redmi 3S через Tapatalk
MTCNA, MTCWE
Shadeofspirit
Wed Apr 19, 2017 3:38 pm
there is a little cheme
https://drive.google.com/open?id=0Bxq9Y ... TRaR0tsVzA
tested it on one of my nets (there are 2 uplinks, l2tp and static address )
MTCNA, MTCWE
rgroothuis
Wed Apr 19, 2017 9:56 pm
Excellent, thanks for the suggestions. The probe tip, the example above and the SNMPWALK tip I found on the internet I was able to add 3 Probes, one for each ADSL line. Perfect. Now I should get a Telegram message when one of the lines are down. I will do a test when at the premises again. Thanks.
Shadeofspirit
Wed Apr 19, 2017 10:38 pm
You can set notifications for each prob separately.
go to services tab of your device in dude, select probe in list, then right click-settings, go to notifications tab and mark kinds of notifications you need for this particular probe
MTCNA, MTCWE
Users browsing this forum: No registered users and 11 guests
