jessearcher
SXT LTE - Show Physical Cell ID (PCI)
Fri Apr 21, 2017 6:52 am
Does anyone know how to show the Physical Cell ID (PCI) the the device is connected to.
I can do it on other hardware (e.g. Huawei B315 and iPhone 6 - screenshot from my iPhone below).
Aufan388
Re: SXT LTE - Show Physical Cell ID (PCI)
Fri Apr 21, 2017 4:27 pm
You can find this info on the quickset menu of sxt LTE or by the " /interface lte>info 0 "command on terminal
jessearcher
Sat Apr 22, 2017 3:49 am
Unfortunately that command (or doing the equivalent via the GUI) don't expose the PCI.
The PCI is a number between 0 & 503.
I can expose it via my iPhone and despite being connected to the same cell the PCI (130) isn't showing up anywhere on the SXT LTE.
Aufan388
Tue Apr 25, 2017 2:14 pm
You should post your config concerning the LTE part of the config then maybe we can move forward in finding a solution.
Please hide all critical parts of your configuration when posting.
use " /export compact " in the terminal to get the full config and copy from it everything concerning your LTE config.
also I confused the values you wanted. You can see the Current Cell ID is "2" on my screenshot below current operator.
jessearcher
Thu May 04, 2017 5:42 am
This is what I get when I run " /interface lte>info 0 "
Code: Select all
revision: chip:2.0 fw:0.1.2.3
current-operator: 530,01 (ECI 786691/ eNBI 3073)
current-cellid: 3
earfcn: 1800 (band 3, bandwidth 20Mhz, DL freq 1865.0Mhz)
imei: 356159060219486
imsi: 530011109255837
uicc: 1527016971281782133115240
rssi: -85dBm
rsrp: -115dBm
rsrq: -10dB
sinr: 9dB
The Cell ID of "3" is not the PCI.
Export of my config as requested is below.
It's important to note that the PCI which is what I'm after (to identify the cell I'm connecting to) is different to the "Cell ID" the Mikrotik is showing.
Code: Select all
# may/04/2017 14:28:20 by RouterOS 6.36.3
# software id = W0N2-AQ96
set [ find default-name=ether1 ] mac-address=<<REDACTED>>
/interface lte
set [ find ] add-default-route=yes band=3 default-route-distance=1 ip-type=\
ipv4 ipv6-interface=none mac-address=<<REDACTED>> name=lte1 \
network-mode=lte use-peer-dns=yes
/ip neighbor discovery
set lte1 discover=no
add address-pool=default-dhcp disabled=no interface=ether1 name=defconf
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
192.168.88.0
/ip cloud
set ddns-enabled=yes
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 \
gateway=192.168.88.1
set allow-remote-requests=yes servers=<<REDACTED>>
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=input comment="<<REDACTED>>" dst-port=\
80,8291 protocol=tcp src-address=<<REDACTED>>
add action=drop chain=input comment="defconf: drop all from WAN" \
in-interface=lte1
"defconf: accept established,related" connection-state=\
established,related
connection-state=invalid
connection-state=new in-interface=lte1
out-interface=lte1
/system clock
set time-zone-name=Pacific/Auckland
/system identity
set name="<<REDACTED>>"
/system logging
add topics=lte
/system routerboard settings
set init-delay=0s protected-routerboot=disabled
/tool mac-server
add interface=ether1
/tool mac-server mac-winbox
Users browsing this forum: YaCy [Bot] and 50 guests
