taundertaker773
P2P matcher is obsolete please use layer7 matcher instead
Thu May 04, 2017 6:13 pm
Hi all after upgrading to Version MikroTik RouterOS 6.39 my torrents started downloading, yet on previous version i had blocked them and they were working perfectly.
I can guarantee you that I have no clue on what I should do, I have checked through the forum and what they are saying
I have no absolute idea Any help appreciated.
msatter
Re: P2P matcher is obsolete please use layer7 matcher instead
Thu May 04, 2017 6:46 pm
Follow the postings: viewtopic.php?f=2&t=121304
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
taundertaker773
Thu May 04, 2017 7:36 pm
I'm clue less Please assist with script if you have it ?
msatter
Thu May 04, 2017 8:31 pm
I never used the P2P matcher and only know that Mikrotik made it obsolete. You can go back to earlier version of RouterOS or write your own filtering for non encrypted P2P traffic.
Running:
mansoor
Thu Jan 25, 2018 2:19 pm
Users browsing this forum: Google [Bot], MSN [Bot] and 102 guests
