normis
Which types of ports would you like to see for a high speed router
Fri May 12, 2017 1:07 pm
We are working on some future high speed routers with around 100Gbit throughput, and we would like your input on what types of ports you would want to see in such devices.
If you imagine a device with around 16 ports (just an example), how many of them would you want to be (just examples, you can add your own ideas):
SFP+ (10G)
SFP28 (25G)
QSFP (4x10G)
10Gbit copper (10G)
Management with PoE
Let us know in the replies here
anuser
Long time Member
Long time Member
Re: Which types of ports would you like to see for a high speed router
Fri May 12, 2017 1:24 pm
Only some ideas:
Router A: 16x SFP+
Router B: 16x SFP+/16x RJ45 10GbE (combo ports)
Router C: 8x SFP+/8x RJ45 10GbE (combo ports) + 2x QSFP
later
(Router X: 24x SFP+)
(Router Y: 24x SFP+ plus 4x QSFP)
(Router Z: 24x SFP+ plus 4x QSFP28)
(Speeking for myself: I do not need 10GbE copper at all as 10GbE SFP+ optics are cheap nowadays)
all with:
- dual power supplies, hot swappable
- 1x RJ45/SFP combo management interface
I didn't know what ASIC you are looking at, but I'd prefer an ASIC/SOC with less CPUs (1big one instead of 72 small ones) According to that slide from Cavium, the biggest highend ASIC is only 500$, so it would be absolutely possible to build an inexpensive highend router, although this means multiple CPUs and therefore single thread performance isn't that great.
The Indigp NPS-400 Network Processor by EZchip looks better. It looks like it has less CPUs. I cannot find pricing information, unfortunately
But you talked about 100Gbit/s throughput, so the NP-5 seems to be the right one:
raffav
Fri May 12, 2017 1:34 pm
I think that would be a great idea some group of port be on a expansion slot so we can change the type depending on our needs.
Enviado de meu XT1580 usando Tapatalk
normis
Fri May 12, 2017 1:36 pm
What format do you mean?
anuser
Long time Member
Long time Member
Fri May 12, 2017 1:37 pm
I think that would raise the costs for those routers too much. Fixed configurations would be a less expensive solution. 1x product design / mainboard with different ports attached to the ASIC.
raffav
Re: RE: Re: Which types of ports would you like to see for a high speed router
Fri May 12, 2017 1:48 pm
Router with 24 port? Really it not a over port config for a router?
I think a version with expansion slot is not bad, it will be a super core router, I don't think that will make super high cost on the product
normis
Fri May 12, 2017 2:07 pm
You can already use a high end PC as your router.
raffav
Re: RE: Re: RE: Re: Which types of ports would you like to see for a high speed router
Fri May 12, 2017 2:10 pm
But do you agree that is not they same of a dedicated hardware for this
I really don't think that someone will build a high end server to be placed on the the core high density network traffic
normis
Fri May 12, 2017 2:13 pm
The advantage of specifically manufactured hardware is that manufacture can test it at the specific configuration. If you take that away, is becomes the same as any other PC where you have no driver support.
BartoszP
Fri May 12, 2017 2:20 pm
Primo.
Is it possible to just make funcionality of stacking Mikrotik's devices ? High-end ones. Then we can buy models with proper ports and stack them. No need for zyllions versions ....
Secundo.
One mainboard and slots for different daughter cards .... are we going to be CISCO/Juniper like ? :-)
raffav
Fri May 12, 2017 2:33 pm
Primo.
Secundo.
And this is a problem?
AlainCasault
Trainer
Trainer
Fri May 12, 2017 2:42 pm
What's wrong with giving the big boys a run for their money? ;)
In an other post, I had suggested a chassis with slots, like the Cat6500 family.
In previous MUMs, consultants have talked about replacing Cisco with MikroTik boxes.
I think MikroTik is going on the right direction.
Stackable is also a great idea. Grow your network with your business.
Off topic, MSTP (pvstp, 802.1Q) pleeease! If you're going big, go all the way. :)
Sent from Tapatalk
BartoszP
Fri May 12, 2017 2:47 pm
...One mainboard and slots for different daughter cards .... are we going to be CISCO/Juniper like ? :-)
Not at all.... havn't you spotted :-) ?
Stacking could be even the first step to HA funcionality which is missing for ROS.
doush
Long time Member
Long time Member
Fri May 12, 2017 2:52 pm
I dont think high end routers should be based on Cavium processors.
They have low freq upto 1.2Ghz and some specific RouterOS tasks require higher clock speeds such as simple queues, BGP, PPP etc..
So unless RouterOS is highly multi-threaded in such scenarios like to be used as a PPP concentrator etc.., I would prefer some different architecture than Cavium which will provide higher clock speeds instead of super-high multiple cores with low clock speeds.
raffav
Fri May 12, 2017 2:58 pm
Ah ok
I thought that you was complaining....
Ha and some kind of Hsrp for mk
Darryl
Fri May 12, 2017 3:34 pm
New inexpensive member to the CCR family of routers:
- five 1Gb ports
- five 10Gb ports
- four SFP+ ports
- two USB 3.0 ports
No port sharing / TILE-Gx based CPU
gtj
Fri May 12, 2017 3:52 pm
12 x SFP+ (10G)
4 x QSFP (4x10G)
1 x Management (no PoE)
1 x serial management
cheeze
Fri May 12, 2017 4:35 pm
48 port Gb/e and 4x 10Gb/e (SFP+) (TileGX based)
24 port Gb/e and 2x 10Gb/e (SFP+) (TileGX based)
16/32 port 10Gb/e (SFP+) (TileGX based)
The above *NEED* to be able to do line rate for IP/IPv6/MPLS traffic, or close enough to it (like the way UBNT does by using an Octeon ASIC to get a decent level of mpps, although UBNT doesn't do MPLS at the mpps level. We need MPLS at that level too).
Or please support the following chipsets from Broadcom. The Trident II and the Tomahawk.
https://people.ucsc.edu/~warner/Bufs/St ... tation.pdf <-- Trident II
https://www.broadcom.com/products/ether ... c/bcm56850 <-- Trident II
https://www.broadcom.com/products/ether ... c/bcm56960 <-- Tomahawk
Lastly, if one were to compare to say Juniper or Cisco I would say the comparisons would be...
A 'tik equivalent to the Juniper ACX1100, or an equivalent to the Cisco ASR-920-12SZ-IM.
A 'tik equivalent to the Juniper ACX5048 would also be fantastic.
psannz
Fri May 12, 2017 5:37 pm
Personally, I'd be interested 2x QSFP and the rest with SFP+ and the obligatory Management Port paired with a rs232 for console access.
The pair of QSFP would provide redundant access to e.g. core switches, while the SFP+ would connect to ISP, DMZ, or further routers/firewalls/gateways.
In regards to the PoE-in functionality, I very much doubt that even PoE+ will provide sufficient power. PoE++ / 4PPoE on the other hand just might. I'd much rather see a pair of redundant hotswappable PSUs with a bit of headspace.
Speaking of hotswappable: I think we'd all love hotswappable fans.
Grüße,
Philip
Hammy
Forum Veteran
Forum Veteran
Fri May 12, 2017 6:06 pm
2x QFP28 (with breakout support), 10x SFP+
2x QFP28 (with breakout support), 3x QFP (with breakout support)
QFP28 Can do 1x100G or can be broken out into multiple 25G.
QFP can do 1x 40G or can be broken out into multiple 10G.
sguox
Trainer
Trainer
Fri May 12, 2017 6:20 pm
+1 for SFP28 and QSFP28, maybe a 4 port router
StubArea51
Trainer
Trainer
Fri May 12, 2017 6:26 pm
Great thread!
25 and 40 gig would be my focus. I'll post a longer response when I have a spare minute to think about specific port configurations. Right now, I've got to get ready for the US MUM :-)
anuser
Long time Member
Long time Member
Fri May 12, 2017 9:04 pm
- Trident/Tomahawk is meant for switches not for router.
- Does TileGX has a future at Ezchip/Mellanox? There are other options: http://www.mellanox.com/page/npu_overview (NP/NPS):
planetcoop
Fri May 12, 2017 9:10 pm
The ccr1036 with two SFP+ (10G) ports based on speed tests is working great.
viewtopic.php?f=2&t=104266
Going forward more ports is better and support for QSFP ports would allow additional networking options. I have not tested the CHR yet beyond the SFP+ (10G) ports in my btest CHR but suspect scaling is allowed based on licensing, currently a p10.
SFP+ (10G)
QSFP (4x10G)
planetcoop
Fri May 12, 2017 9:14 pm
A side question to Normis and team: any opportunity for routerboard designs with native x86 or x64 support. Tile has been good as a platform but i do also like the x64 potential in the CHR guests. And one more shout out for CHR vmware-tools :)
TomjNorthIdaho
Fri May 12, 2017 10:48 pm
I really like this topic !!!
My suggestions are:
- Possible special stack ports
Where there is a minimum of two stack ports per device (or four ports) , which enables the ability to stack more than two Mikrotik devices.
Where there is a new Mikrotik stack interface using normal copper RJ-45 connectors and cat6 compatible (and possible cat7 or cat8 compatible.
Where stacking could enable two stackable Mikrotik routers and possibly two stackable Mikrotik switches to act and behave as a single device.
Where there could be an option that if these copper RJ-45 stack ports are not used in a stack configuration, then they can alternately be used in a 10-gig copper Ethernet environment.
With high-speed stack ports, it would then be possible for Mikrotik to offer a lower-cost basic system, then additional Mikrotik devices could be ordered later, or as/when new Mikrotik stackable devices come out, then can also be added to the stack.
Where with the base system, it is possible to bring up a small--to-medium--to-large number of interfaces by adding to the Mikrotik stack interfaces.
Where a 48 port 10/100/1000 Ethernet option is simply a new stacked device.
Where a 12 to 48 port SFP interface is simply a new stacked device.
Where a 12 to 48 port SFP+ interface is simply a new stacked device.
Where additional 12 port 10-gig copper Ethernet interfaces can be added into the stack.
- The ability to perform true bonded/load-sharing of SFP+ or 10-gig-copper ports to achieve 20 t 40 Gig throughput (True single MAC address to single MAC address balanced load-sharing)
Where it would be possible to have up to four (or more) 10-gig fiber (or copper) which are remotely separated to have greater than 10-gig throughput.
- SFP+ ports are backwards compatible with normal SFP devices ( This would be assumed )
- Possibly four 1-gig Ethernet ports (with POE on each port)
- For faster than 10-gig interfaces (not including stack ports), I would like see the most common/compatible/popular/standard interface used.
I have no experience with SFP28 or QSFP)
- CPU
A bad-ass and popular CPU (Intel XEON), with lots of built-in CPU internal cache
Then as newer & faster CPUs come out, it is just a simple matter of switching to the newer CPU
High-speed RAM (standard high-speed normal memory sticks) (not motherboard surface mounted - user upgradeable & user replaceable)
- Possibly one to four PCI card slots for future cards/interfaces.
There may be a desire to use an already existing PCI card in a Mikrotik - where a quick/simple ROS driver could bring up the PCI card device/interface.
- Dual power supplies (the new system should be able to be powered by industry standardTelco-48-Volts, and/or standard AC outlets
Where the AC power supplies are NOT built-into the new Mikrotik - but instead the AC power supplies are standard telco-48-volts out and then connected to the new Mikrotik.
Were 12 or 24 Volts is not needed or used (except to POE ports)
- One serial port
- All flash ram on removable user replaceable industry standard media
- ROS (Intel/AMD) 64-bit firmware
- Future software/firmware ability for two independent systems can function in a hot-stand-by-redundant mode (something like Cisco HSRP)
- Future ROS firmware/software for true VRF interfaces/routing tables (similar to how Cisco handles VRF interfaces/routes without injecting routed/IP-addresses/MAC-addresses into the entire system.
Where it would be additionally possible to also have a VRF interface for true out-of-band management interface on a router.
Where multiple independent VRF routing tables and interfaces to not see each other and are not seen by the base system.
With VRF features, I suspect a MetaRouter feature will not be needed or even desired.
These new VRF features should support the normal stuff a network configuration will probably encounter - such as VRF to VRF bridges & VRF DHCP & VRF NAT & ability to bridge VRF interfaces to other VRF configurations & bridge VRF interfaces to live interfaces & bridge VRF interfaces to non-VRF interfaces.
Possible idea - Ability CPU limit VRF functions so that a single or multiple or all combined VRF features do not degrade the primary non-VRF configuration (UNIX nice )
- This is a MUST ... The ability to perform full BGP and quickly handle all BGP routes (without the need to upgrade something at the BGP tables increase and more BGP interfaces/peers are added.
Possible idea ... Ability to run full BGP under a VRF environment instead of under the non-VRF environment --- there can be some huge advantages to a VRF BGP environment. And possibly the ability to run multiple independent full BGP environments to multiple up-stream connectivity peering networks.
- No excessive fancy LEDS. Possibly just a small simple LED display which can actually show real-time diagnostic information (verses individual single LET lights)
- Two platforms at first.
A low cost (fewer interfaces & devices mounted to the motherboard. Something most of us -and- our customers can afford without breaking our budgets.
A high-end high-throughput version (exact same motherboard - just with faster parts and all the interfaces mounted on the motherboard.
This simplifies production and the low-cost version gets the product out in the field quicker to the engineers who want to test-drive it in a LAB or evaluate in production.
- Standard rack mount chassis
- No huge big blade chassis in the design - where expansion and additional devices are added to the system using Mikrotik stack interfaces (keep costs down to get started)
- When this low-cost stackable configuration starts to take off and becomes desired and popular, then a blade version of the same thing could then be latter designed which would then use a high-speed back-plane between cards.
By starting with a stack interface (instead of a blade back-plane), the initial costs would be lower.
Later, when a pattern and market develops for an even faster version, then the basic designs could then be slightly re-engineered to use a back-plane in a large chassis (which is more expensive/faster).
Stacking existing and older Mikrotik devices (some with less memory and flash and slower CPUs) could be possibly done with a RO-Stack OS, where the new OS has everything but the minimum necessary software drivers to enable the new RO-Stack OS to participate in the stack and deliver the interfaces over an Ethernet stack interface. This would add value to all existing Mikrotik devices because a fork-lift replacement would not be necessary to get started with this new "Mikrotik stack head-end device".
Consider a CHR stack version of ROS. It might be interesting to combine other CHR systems to be able to participate in the stack (possible VRF BGP via stacked CHR ??? Interesting idea ? ) I would want to name it CHR-Stack (over Ethernet interfaces)
- With a stack interface (using a normal Ethernet interface), it would be great to have all existing Mikrotik ROS devices support 1-Gig or 10-Gig stacking. This adds value to all existing Mikrotik products already in production and already in use.
EDIT/add - If stack interfaces are considered - the stack interfaces do not need to support power over the stack. Each stack device should use it's own (48 volt or AC) power supply.
EDIT/add - A possible hardware reset-/-reboot watchdog. The ROS (or what I would like to call it the RO-Stack OS) could do something like a Netwatch IP ping or something) to keep resetting/clearing the hardware watchdog. If the ROS ( or RO-Stack OS ) locks up - crashes, then the hardware watchdog will continue counting down to zero which could then trigger a full-blown reboot - resulting in an auto-recovered system. The slave stacked devices could also participate in the primary watchdog. Possibly by using a reset wire in the RJ-45 stack cable. Thus, a reboot command on the primary master stack device could possibly reboot everything in the stack if wanted/needed.
EDIT/add - Clarification - When I refer to stacking using Ethernet ports , I am not referring to stacking using IP. It could be something like MAC to MAC. Where the master stacked devices knows the MAC address of everything that is supposed to be in the stack and what it is. The hardware Ethernet switch chips (or ROS software bridge if necessary on old devices) could be used to re-distribute the stack data at wire-speed to other stack ports. It might be even possible to allocate/use a special Vlan for the Ethernet connector(s) stack interfaces.
EDIT/add - Optional - faster than 10-gig stack ports could also be combined and also work with 10-gig or 1-gig interfaces. Possibly, the administrator simply just defines what ports are used for stacking instead of being normal interfaces. This makes it flexible for how the ports are used. With user/administrator selectable stack ports and with the ability for the master stack device to talk to different stacked slave devices at different speeds, the system would never become obsolete - instead it just becomes bigger faster and more desirable for commercial business use/installations.
EDIT/add - slaves on the stack only need to be configured to know the MAC address (or auto-discover) the master slave interface. The master stack device should hold the entire configuration for everything and be as simple as making a backup on any other Mikrotik.
North Idaho Tom Jones
Last edited by TomjNorthIdaho on Sat May 13, 2017 2:49 am, edited 8 times in total.
raffav
Sat May 13, 2017 1:40 am
My suggestions are:
- CPU
- One serial port
OMG this is big text
But Iiked [emoji6]
hush
Sat May 13, 2017 10:06 am
IMHO, there is no point in developing anything new with 10Gbps/40Gbps ports at this point in time and the new 16 x SFP+ switch you presented in Milan this year should have already been made with SFP28 ports. But let's keep it simple for starters...
  • Considering that new SFP28 ports should be able to support old SFP+ modules, how about a CCR2572 with 8 x SFP28 ports as a direct in-place upgrade for CCR1072?
  • Then bring it up a notch and create something like CCR10072 (yes, that's an extra zero) with 8 x SFP28 + 1 (or 2?) x QSFP28, although it would probably need a better CPU.
  • Then let's talk datacenters - how about a new 16 x SFP28 + 2 x QSFP28 switch with enough CPU power for some OSPF/iBGP routing experiments?
Naturally, this would also require some new SFP28 modules, SFP28/QSFP28 DAC cables and so on...
Edit: It looks like some people here aren't aware that new 25/100 Gbps ports can also support "old" 10/40 Gbps speeds? Here's some reading material:
BartoszP
Sat May 13, 2017 10:55 am
So IMHO the conclusion so far is:
Hardware
1. Stacking as the fastest path for extension
2. Rack chassis with highspeed backplane to connect interfaces and CPU motherboards tailored for current needs
3. True HA funcionality
If we could have CPU-board with ROS kernel separated from interface cards then we can easily upgrade router without changing any rule.
If the interface name will be local and bound to interface card id then rules based on that name will need no change,
Do you need more pure CPU power ? Just replace CPU card.
More memory ? Add it.
Hard disk or any permanent storage ? Add storage card.
etc., etc.
nz_monkey
Sat May 13, 2017 11:30 am
@TomjNorthIdaho you win the award for the longest post ;) but it sounds like you want a x86 server.
nz_monkey
Sat May 13, 2017 11:52 am
Normis, thank you for asking for our opinions.
If it was at all possible, I would suggest Mikrotik make this new router with 2x modular "interface" bays. Users could then "cold swap" these modules to meet their specific requirements...
Making a modular router would:
- Allow various interface combinations, and would keep everyone happy :)
- Lower the manufacturing risk to Mikrotik (Bulk manufacture the base router, then JIT manufacture the interface modules)
- Allow users to change out the interface modules as their requirements change, e.g. they could start out with a 8x SFP+ module, then later on move to a QSP28 module
- Meet lower cost requirements, e.g. cost sensitive customer could buy base router + 1 PSU + 1 module card. Baller customer could buy base router + 2 PSU + 2 module cards.
Example interface modules could be:
1x QSFP28
2x QSFP28
4x SFP28
8-10x SFP+
16x SFP
16x 1gigabit Copper
If you do decide to go with "fixed" port configs though, my suggestions would be:
Spec1 For people who have exiting 10gigabit networks and do not need higher performance.
- 16x SFP+
- 1x Gigabit Ethernet
Spec2 For people wanting higher speed per "wavelength" or to future proof themselves.
- 8x SFP28
- 2x QSFP28
This will allow 100gigabit throughput via the 8x SFP28 (4in, 4 out) or the 2x QSFP28 (1in, 1 out). It would also mean you could interconnect to other locations via redundant QSFP28 connections and then use SFP28 to connect customers, or to other equipment in the same DC.
I put the 1x Gigabit Ethernet on both of them, as this can be used to netinstall the routers, and for out-of-band management.
ingen
Sat May 13, 2017 5:04 pm
SFP+ (10G)
SFP28 (25G)
QSFP (4x10G)
10Gbit copper (10G)
Management with PoE
Hello Normis
IMHO sfp+ on router more than enough.
haik01
Sat May 13, 2017 7:19 pm
Maybe not a specifica high speed router, but a PoE switch / router model which has configurable PoE voltages.
So each port should be able to set:
  • no PoE
  • passive PoE (and select voltage, mostly 24V)
  • 48V / 56V PoE.
So that for example a Cisco or HP switch can be replaced by a Mikrotik.
The problem now is that if you have an existing Cisco / HP / Juniper etc.... PoE switch for xxx AP's, and you want to add Mikrotik, you cannot simple do that, since all professional AP's work on 48V. And most Mikrotik (and Ubiquity etc...) work on passive 24V. So you need to find local power (not always available) etc...
So I want to select the power voltage output on each port.
planetcoop
Sat May 13, 2017 7:48 pm
I second the x86 architecture, but with the configuration and control of a routerboard :)
supportingit
Sun May 14, 2017 6:33 am
Port config, I'd like to see 16 or 24 ports SFP+ with an option on a couple of higher speed ports for interconnection.
Most importantly though, if its a rack model, it MUST have internal psu, with an optional secondary. No more damn wall warts in the rack!
nz_monkey
Sun May 14, 2017 11:09 am
This router sounds like the Next Gen CCR. The current CCR have internal PSU so I can't see Mikrotik changing now for no reason.
My wishes are for user replaceable PSU on the new product line, so that PSU can be replaced without removing the router from the rack.
And for -48volt DC input like the new RB1100AHx4 has :) this way they can be used in Telco co-lo rooms and road side cabinets that are almost always -48volt only.
pukkita
Trainer
Trainer
Sun May 14, 2017 1:12 pm
I don't know which are the possibilities of the considered platform so cannot tailor port count/capacities to specific CPU lanes, but these would be sweet combos to have, I assume 1U and routing application (not switch):
- 12 SFP+, 3xQSFP
- 16 SFP+, 2xQSFP
- 16 SFP+, 4xQSFP
- 24 SFP+, 4xQSFP or 2xQSFP28 (2x100G)
mfrabbibd
Mon May 15, 2017 12:34 am
Normis, every RM Router Should have a DC power option!
Sent from my iPhone using Tapatalk
cheeze
Mon May 15, 2017 2:18 am
I respectfully disagree. Those chipsets from Broadcom are fully functional and capable routers. I was hoping Mikrotik could jump into the bandwagon to disrupt Cisco/Juniper/Nokia and bring down the overall costs of networking. Eventually I'd like to start an ISP business, but well.....equipment isn't exactly cheap. That being said, it's not equipment that bothers me so much as having to grease the wheels by buying political power to get right of way and whatnot.
nz_monkey
Mon May 15, 2017 8:28 am
The chipsets from Broadcom are being used in "routing switches" e.g. Brocade MLX/VDX, Nokia 7210 SAS-T/M and certain Arista switches.
They are great for fixed scenarios but are not good as a "General Purpose" router, and have some pretty hard limitations. e.g. Broadcom Trident II can do VXLAN and QinQ and vlan re-write, just not all together, and due to everything being "baked" into the silicone, that cannot be changed.
Mikrotik have a lot more experience now than when they started the CCR project, so I am confident they will select an architecture that is suitable for use as a general purpose router.
nz_monkey
Mon May 15, 2017 8:30 am
every CCR should have a -48volt DC power option ;)
gangz
Mon May 15, 2017 12:35 pm
If you says about ROUTER, this configuration will be interesting:
2 x Copper 1Gbit
10 x SFP+ 10Gbit
2 x Copper 10Gbit Ethernet
2 x QSFP 40Gbit
cheeze
Mon May 15, 2017 6:16 pm
Yes, they are layer 3 "routing switches". Basically routing functionality bolted on. The reason I was looking more at those is because that limitation that you're pointing out (which does exist) is one that GENERALLY isn't hit too often.I was more looking at the MPLS/VXLAN/QinQ/translational as features that can be done at line rate. Usually one would need one or the other, but not all at once. Now I am not pushing super hard to get those chipsets, I'm just more investigating and seeing if they are a fit. I personally would love to see line rate from Mikrotik. Or near line rate (which the Tile GX approach).
Something I was always hoping for was like a CRS226-24G-2S+RM chipset with the Tile GX for forwarding. Or CRS125-24G-1S-RM with Tile GX. Or even the smaller ones like the CRS210-8G-2S+IN.
idlemind
Mon May 15, 2017 6:29 pm
In additional to as many high-speed ports as you can cram into the box either a line-card slot or just a bank of regular 1GB Ethernet ports can be extremely useful to designers and provide a high level of flexibility. Something like 6 - 12 x 1GB ports wouldn't hurt the back-plane of the box significantly I imagine. Something I hated with the earlier Cisco ISRs and even somewhat today is the difficulty to obtain the number of ports necessary to do anything other than trunk down to a L2 switch below it if you are doing anything more than a typical edge router with NAT. This is already a strength with most of your devices shipping with 4+ ports.
StubArea51
Trainer
Trainer
Mon May 15, 2017 9:55 pm
Great points as always NZ...
However, I will add that ASIC limitations are no longer an issue for any of the newer whitebox switch gear running the Barefoot Tofino chip as the ASIC can be programmed on the fly with the P4 language. Barefoot is being put in switches that would have otherwise run a Trident 2+ chipset.
nz_monkey
Tue May 16, 2017 12:51 am
@IPANetEngineer I completely agree, the Barefoot Tofino is one of the most interesting developments in networking in the last 10 years.
It will be interesting to see what products make use of Tofino in the next 18 months.
Hammy
Forum Veteran
Forum Veteran
Tue May 16, 2017 12:55 am
I assume that chip is a bit larger scale than Mikrotik is looking to go... given that it handles 65x the performance Mikrotik hinted towards in the initial post.
tempName
Tue May 16, 2017 12:57 am
The question was on a router and around 100 Gbit throughput.
I'd think that would limit it basically to two QSFP-Ports (probably often used as "upstream"). I'd further propose 6x SFP+ - ports and additional 8x 10G copper (10GBASE-T) for compatibility with existing (even GBit) connections. I'd liked an extra (GBit) management lan port and serial connection, too.
It probably makes sense to have (at least optional, if need be external) redundant power supplies as well.
Even if reduced to 4x SFP+, 4x 10GBase-T, 8x 1000Base-T (maybe even partly or all with PoE+) plus mgmt-LAN & serial would it make a great cloud router switch ...
SteveWrightNZ
Tue May 16, 2017 1:23 am
And go compete with china?
I think you should stick with wireless stuff, and maybe build a quality FDM full-duplex system with sub-1ms ping over 10km. We'd like that.
Revelation
Tue May 16, 2017 5:06 am
Coming from a Data Center background, I'd like to see:
Access / Distro #1
24x 1G / 10G Copper
4-6x SFP28 / QSFP28
Access / Distro #2
16x SFP / SFP+
4-6x SFP28 / QSFP28
Core
You could also run a "core" router with:
10x SFP28 / QSFP28
4x 1G / 10G Copper
or
4x SFP / SFP+
I'd still love to see you guys add VXLAN / EVPN features to your devices.
Hammy
Forum Veteran
Forum Veteran
Tue May 16, 2017 5:16 am
Let's not forget that QSFP and QSFP28 both support breakout or fanout cables.
JimmyNyholm
Tue May 16, 2017 9:52 am
And Dont forget:
QSFP28 can do:
1-4 x 10
1-4 x 25
1-2 x 50
1 x 100
SFP28 can do:
1 x 10
1 x 25
QSFP+ can do:
1-4 x 10
1 x 40
SFP+ can do:
1 x 10
1 x 1
All speeds and breakout combinations should be supported on all the ports no shit as of now only 10 och sfp+ port
nz_monkey
Tue May 16, 2017 1:44 pm
This is getting pretty OT now, but:
+1000
Please email support@mikrotik.com and lodge your official feature request. Eventually they will get annoyed enough by the constant emails and add it :D
StubArea51
Trainer
Trainer
Tue May 16, 2017 3:49 pm
Mike, Barefoot is looking to scale down as well as up. It's a question I specifically asked them when I visited their corp HQ in January. Look for Barefoot going into smaller boxes in next 12 months.
sterling
Wed May 17, 2017 12:37 am
I would like 8x QSFP+ in pretty much the same form factor/config as the CCR 1072.
That way I could do uplinks to my older model Force10 switches and backbone 40Gbps pretty cheap across longer distances.
LR QSFP+ modules are in the low hundreds range now. With 40km QSFP+ modules coming down in price as well.
anuser
Long time Member
Long time Member
Wed May 17, 2017 7:58 am
I myself also talked about QSFP28, but as Normis mentioned, Mikrotik prepares for a 100Gbit/s router, not a terrabit one. Although I also want to build an inexpensive 100 Gbit/s core. ;-)
paulct
Wed May 17, 2017 11:59 am
I would like to see more of a focus on the layer2 distribution side so it ties in with these new proposed routers. Otherwise we would need to pick other brands for L2 which we have been doing especially for SFP+ port density and POE. Stacking on the switches as well as the routers. More IPv6 support in ROS. No need for any LCD's. Removable dual power supplies.
Personally I do not need 10gb ethernet, but in the server/dc environment I can see the need.
Layer2 access:
24 SFP+ ports, dual PSU
24 SFP+ ports + 4 x QSFP, dual PSU
48 x 1Gbe + 2 x SFP+
24 x 10Gbe + 4 x QSFP
48 x 1Gbe POE at/af + 2 x SFP+
CCR's:
12 x SFP+ and 4 x 10Gbe combo ports
12 x SFP+ and 4 x QSFP
savage
Thu May 18, 2017 7:13 pm
Please do a CLEAR separation between "enterprise" routers, and SOHO routers. I think it's time...
Enterprise Routers - PLEASE we are willing to pay, MAKE IT RELIABLE, make it PERFORM.
Interfaces, can be modular. 4 x 1GB, 4 x SPF, 2 x SFP+, 1 x QSFP+, etc... No need to have fixed ports. Same with power supplies, same with fans.
Just my 2c, but BIGGER routers means NOTHING when the CURRENT routers can't perform either. There's numerous flaws on your "flagship" CCR routers, which has little to no interest from MT to be fixed (PSUs, BGP, etc). I for one, won't even THINK about purchasing "bigger" routers from MT when the existing routers are so unreliable and under performing.
brotherdust
Thu May 18, 2017 9:58 pm
I know this is probably not going to go over well, but I'm going to say it anyway: it's time for Mikrotik to have an Apple equivalent of "Back to the Mac"; except the Mac is RouterOS. I don't want to see another piece of hardware. I want to see a commitment to releasing RouterOS 7. All these different devices they are releasing, yeah.. they make sense for a small portion of your customers. Why not focus some effort on something that _all_ your customers can benefit from? There are numerous wish lists on the forums talking about what we'd all like to see in v7, so it's not worth re-iterating here.
Hopefully someone out there will see the logic in what I'm saying.
cheeze
Thu May 18, 2017 10:11 pm
I've said this many times and I get yelled at and disparaged.
ROS7 > *
ROS7 needs to come out before 'tik is able to really make more inroads.
Hammy
Forum Veteran
Forum Veteran
Thu May 18, 2017 10:12 pm
Software engineers != Hardware Engineers
Not that I disagree with the importance of getting v7 done and done properly.
savage
Thu May 18, 2017 10:14 pm
Well there's also no point in bringing out hardware, if the software to utilize the hardware, isn't there :?
Hammy
Forum Veteran
Forum Veteran
Thu May 18, 2017 10:39 pm
Just different requirements\designs. The CCRs are great performance for the price when you're not considering large routing tables. Whatever this platform is may have big enough cores to overcome the large routing table issue. BGP works just fine on x86 and CHR. If not, you use these boxes for MPLS and they don't carry full Internet tables. Just stick on an x86 box for your full tables routers.
Let's keep this thread on topic. If you must whine, elegantly incorporate it in an appropriate response to the original request.
savage
Thu May 18, 2017 10:56 pm
x86 which is being phased out (and supports a few, at best hardware devices. MT even said no more new drives till the mythical v7 makes an appearance), CHR which to say the least carries piles of additional licensing fees, and misses crucial functionality. Hell, I may just as well take a trusty linux distro with Quagga, Bird or something else then I suppose. Why then bother with MT, and MT's hardware at all (and what about the thousands I've already invested in hardware that promised the world and delivered everything but)? I suppose it's much more important to rather have a ROUTER running a SMB server, or HTTP Proxy server, or even insecure DNS servers by default :wink:
Anyways, that's pretty much the response I expected yes. Say anything bad and you are "whining" Never allowed any criticism against MT, they can't do anything wrong... All I'm saying, MT needs to get its priorities straight... There's a lot of people starting to notice these... issues...
Hammy
Forum Veteran
Forum Veteran
Thu May 18, 2017 11:01 pm
If you don't think I criticize or allow criticism, you clearly haven't been paying attention.
brotherdust
Thu May 18, 2017 11:51 pm
Look guys, I'm merely trying to point out that MT's customers would be better served by concentrating their efforts on RouterOS v7 instead of releasing all these little "trinket" devices. Has anyone else noted that the newsletters are mostly full of hardware announcements? I get that hardware engineers != software engineers. That actually makes my point more strongly: it's like MT forgot that RouterOS is the entire basis of their platform. Really, I think the argument could be made that the hardware doesn't really matter all that much. RouterOS can run on almost anything these days.
nz_monkey
Fri May 19, 2017 2:19 am
Make RouterOS great again ? :lol:
upower3
Fri May 19, 2017 1:59 pm
Take into account only a few devices have 2 power supply built-in, I really doubt you'll do well on really high-end market. Cheap China-grade external "hey ma, I got my phone power supply for my router!" typed power sources are something that won't look nice for anything high-end.
Who'll pay for 100G's while unsure in device just for its low-priced components? If so, then high-availability features must be built-in deeply into ROS. Stability and failover is the key, and MT devices used to hang sometime so far, this is blocker for high-load high-end market, too.
What you may want to do is to create 10G switches (with ASIC and ROS in it and a lot of memory, not just SwicthOS), this may be useful for poor-man clusters and some low-end datacenters, but hight-end is something different...
normis
Fri May 19, 2017 2:17 pm
None of the rack mountable CCR units has an external power supply
brotherdust
Fri May 19, 2017 6:57 pm
omg you savage! =)
upower3
Fri May 19, 2017 8:26 pm
Ok, then lets's count how many of them has two PSU? I suspect there is only ONE (ok, two, since one was a replacemnet for another one) When it comes to this point all I got from Mikrotik was advice to supply second power source via PoE, either via MT-compatible switch (tricky thing to find to use in rack in high-end DC) or via use PoE injector with - yes - China made cheap external PSU.
So you're still go to high-end market?
Ok, I understand: your CCRs are so strong and reliable so you don't even believe anyone may want to have two PSU? Then that's good approach, but guys at huge DCs are so used to see backup PSU everywhere so they won't get that for real.
So you may not worry for ports. Start with PSU and overall durability. Looks like your newsletters are not at all monthly, and you still have no service contracts, so it looks pretty unserious for someone who try to deal with 100G ports.
andriys
Fri May 19, 2017 9:47 pm
That's not even the question of how reliable the PSUs themselves are. That's the question of the ability to power the router from two separate UPSs and be able to keep the router running while you're replacing the batteries in one of them.
No one argues that having two PSUs in a high-end device is a must. However this topic is about something else, right? So, please, guys, lets stay on topic here! :)
vortex
Sat May 20, 2017 12:36 am
But I would like a desktop unit with a single internal PSU.
upower3
Sat May 20, 2017 10:39 am
Not a problem, but this is not high-end device, right? And this topic is for 100G ports, something you just don't need in desktop unit, after all.
anuser
Long time Member
Long time Member
Sat May 20, 2017 11:59 am
So MikroTik is now working on a 100 Gbit/s router. The only decision is which ports that device should support. Can we get a hint what ASIC / platform is currently used?
berlo
Sat May 20, 2017 2:48 pm
For first high end routers i think better is create a product with most used ports. Due to dropping of 100Ge ports price, most datacenters are replacing SFP28 QSFP etc with them.
Modular router is fundamental requirement
I think somethinf like:
- Default:
1 x Fe Mgmt Port
8 x 10SFP+ port
- Free module Slot where customers can choose between
4 x 10SFP+ port
8 x 10SFP+ port
n x 100Gbps Port
Another requirement is to optimize the handle of bonding ports that now impact too much the cpu
upower3
Sat May 20, 2017 8:01 pm
Wish to look at it! Modular 13U router from Mikrotik with add-in blades full of different ports, with built-in support for hardware redundancy of CPU cards, storage.
And with (still) one internal PSU :)
Really, I suspect a lot of people would like to see not 100G, but simple to say modular (or at least stackable) solutions from MT. It you build decent LAN you'll need at least 100-150 client LAN ports per closet and you have to put switches each of 24 or 52 1G ports then connect it to central unit with 10G SFP+ but - no redundancy!
So to say, I'd ask for:
- central switch (capable of hardware stack, so I can put two of them) full of 10G, that'll have at least 2x10G or more to uplink or to interconnect to different closet in different room.
- edge layer switch capable to connect with two 10G links to these "central" switches
all of these should offer full stack of switch technologies, and good diagnostics/manageability.
To my surprise, even when we'd like to feel we have a lot of traffic in the network in fact not always we need 100G ports. What we really need is some approach to build robust self-healing system so big network in office or in datacenter won't be affected by single device fault. So modular approach is a good thing, indeed.
By the way, modular devices are more controllable and power-efficient, so for say 10 line cards worth of 50 ports each you can use 2 or 4 PSU per chassis, not 10 (one for each small switch) and the overall robustness will be higher. Remote management will be much better when you can control the whole chassis with cards in it due, etc.
So, please, aim at modular and longer-live devices, not at cheaper "save on everything" ones!
berlo
Sat May 20, 2017 8:12 pm
You''re confusing "modular" word. Modular not mean 13u or bigger router. For example ASR 1001 is a modular router and is 1u.
You can setup a 1u or 2u router with fixed ports and a module for expansion to save $$ if you need expansion
Hammy
Forum Veteran
Forum Veteran
Sat May 20, 2017 10:08 pm
Again, remember that with big ports, you can do breakout\fanout cables to put multiple smaller ports into a bigger port. That way you can have 40G or 100G ports, but can also do 10G or 25G off of them.
stucki
Sat May 20, 2017 11:30 pm
I would prefer modular port cards.
for example the box should have the rj45 mgt port, a serial one and two sfp+ combo ports by default
everything else should be on the extensions cards.
you need another 8 copper ports? buy a card. qsfp for the router on a stick configuration? select the right extension card.
the cpu/chasis should only have two versions:
a full one (all cores whatever) and a reasonable one.
right now it is really painfull to select the right ccr.
one of the extension cards could use infiniband to expand to another next gen ccr to extend the ports.
and please do not forget hotswapable psu.
Hammy
Forum Veteran
Forum Veteran
Sun May 21, 2017 1:04 am
A modular chassis is something I'd accept, but I'd assume it's a lot more expensive than a fixed switch.
Yes, redundant hot-swap power supplies are a must. I like the power layout of the RB1100AHx4.
nz_monkey
Sun May 21, 2017 8:37 am
When I mentioned modularity I was thinking of the Cisco ASR 1001/1002, Huawei NE05E-S2 and at the higher end the Juniper MX104. Not some 10+ RU monstrosity.
The line cards in a 1 or 2 RU router could be made cost effectively by just containing the appropriate SERDES to PHY conversions.
easyswiss
Sun May 21, 2017 8:47 pm
If you bring out ROS7 (BGP Multicore), then please build routers with 2-4 Tilera72 or newer CPU's with:
4x CFP4 (100GE) (router should be able to handle a total amount of 200 Gbit/s)
8x SFP+
1x RJ45 Gbit
I think the future is CFP4 at the moment.
This is the market that Mikrotik does not reach at this time (Brocade CES, Juniper, Cisco,...).
But why not build a plattform like Brocade MLX with linecards (24x RJ45, 8x SFP+, 4x CFP4,...) and CPU cards that can be placed?
A case with 2 power supplies and line card slots could be cheap to produce.
Hammy
Forum Veteran
Forum Veteran
Sun May 21, 2017 8:50 pm
8x SFP+
1x RJ45 Gbit
Will people please stop talking about multicore BGP! It isn't going to happen! The performance enhancements are coming from other areas, not multi thread support.
cheeze
Sun May 21, 2017 9:47 pm
Well, they did do some work on it and were talking about it. I personally am not a big fan of making it too complicated....I think 1 thread for 1 neighbor should be good enough. But that's up to 'tik. However their competitors are multi-threading all of their daemons so........there's that.
If Mikrotik is to keep up then they kinda have to do so.
I personally have never had that much of a problem with the "speed" of a router/network convergence. This coming from working on networks that throw around tens of Tb/sec, the speed of convergence is generally not that much of a problem. Unless one works in like financial services I don't see this as much of a big deal.
To be honest, having separate daemons (as in a separate daemon for LDP, BGP, OSPF, ISIS, RSVP, so on) is more important than the daemons being multi-threaded themselves.
It's all about what Mikrotik is focusing on. If they want to to compete with Cisco/Juniper then they will need to get their software in gear. If they don't then they shouldn't. I personally would love to have an equivalent to Cisco/Juniper. Currently, 'tik is just not there. They do ok, but they aren't there yet.
Hammy
Forum Veteran
Forum Veteran
Sun May 21, 2017 9:51 pm
To be honest, having separate daemons (as in a separate daemon for LDP, BGP, OSPF, ISIS, RSVP, so on) is more important than the daemons being multithreaded themselves.
Who is doing multi-threaded BGP? I think there's one or two platforms out of all BGP platforms that are multithreaded. Gah, I got suckered into a hijack....
To attempt to bring it back on-topic, bigger CPU cores postpones the need for v7's new routing. Unless MT is going x86 or CHR with the new platform, version 6 will need major rewrites, which just seems silly at this point.
cheeze
Sun May 21, 2017 10:11 pm
At one point in time I thought there was a powerpoint presentation and a video talking about multithreaded BGP daemon for CCRs in v7. I'm having a hard time finding it now but I did read through it a few times.
Hijack wasn't meant at least on my end.
On the hardware front, the reason I personally wanted to go towards the Broadcom or Octeon chipsets is mainly because one thing that networks need is wire rate (or near wire rate) performance for all packet types. I personally as a network engineer would be fine building a network that can wire rate 256 byte packets, and really any smaller than that requires specific ASICs even. Most network vendors struggle to do wire rate at 64 byte packets. At the moment the 'tik can't really do near wire rate when using non-fast path/firewall filters/NAT/marking/QoS/MPLS edge services. To build the networks that are needed for today one kinda needs to be able to approach wire rate even with services enabled. Either 'tik needs to do multiple Tilera chips working together to provide the processing power needed or they need to go the ASIC route. Either would be fine with me. Or they can stay where they are, but they shouldn't expect to be able to break into the network that will buy tens of thousands of 'tik routers without those features. I would personally love to be able to use them as MPLS services edge boxes but, they just aren't there yet. Would love to use them as core devices but they aren't there yet either.
Hammy
Forum Veteran
Forum Veteran
Sun May 21, 2017 10:18 pm
https://youtu.be/ihZiAC-Rox8?t=37m09s
https://mum.mikrotik.com//presentations/US14/ccrros.pdf (page 32)
Octeon would be a good path for sure.
chechito
Mon May 22, 2017 2:58 am
i think 2.5g ethernet and 5g ethernet must be take in consideration (for smaller routers off course) maybe as an intermediate upgrade without going to full 10g ethernet over copper 6a category
marklylelk
Mon May 22, 2017 9:59 am
Now I am at 10G network, and I prefer to deploy the 10G to 25G to 100G migration path instead of the 40G to 100G, so I hope the high speed routers with 25G ports.
The single lane 25G network will become more popular in the near future.
nz_monkey
Mon May 22, 2017 11:25 am
Agreed.
We are already seeing 25G switches from the major datacentre switch vendors.
Hammy
Forum Veteran
Forum Veteran
Mon May 22, 2017 3:01 pm
In my recommendation, you could do both. ;-)
mysz0n
Fri May 26, 2017 12:10 pm
I would like to see CCR with
2x SFP + and 8 SFP
You don't have anything that has 2xSFP+ ports and several SFP ports (Not counting the CCR1072-1G-8S + which is terribly expensive)
At the moment, I need 2xSFP + and 5xSFP, so I use 2x CCR + bonding on ethernet ports - I dont like this solution...
iwikus
Fri May 26, 2017 5:21 pm
I'l vote for SFP28 - 25Gbit should be future, but few people know about it, sadly.
It was mentioned on AWS:reinvent
"The custom chips also power a custom AWS network architecture that uses 25Gb Ethernet, a format Amazon believes is actually more scalable and efficient than the 10Gb and 40Gb Ethernet standards commonly used."
http://www.plexxi.com/2014/07/whats-25- ... rnet-want/
And for smaller boxes (home usage?) 5Gbit makes sense, cause it can reuse cat5e cables
http://www.anandtech.com/show/11368/aqu ... 25g1g-nics
acruhl
Mon May 29, 2017 5:10 pm
4 40 gig QSFP
8-10 10 gig RJ45
8-10 10 gig SFP+
As long as the QSFP ports can be configured with LACP, this is a pretty flexible setup. Breakout cables were mentioned, they can be used if needed to match LC infrastructure.
10 gig RJ45 is not super duper popular, but it's flexible for older devices since it will negotiate all the way down to 10baseT. And I really don't like using RJ45 SFPs. I think a 10 gig one is not cheap and not common.
I never understood the argument for putting fewer ports on a router. Just shut the ports not in use, and don't use more than bandwidth will allow for. Simple right?
Railander
Thu Jun 01, 2017 10:24 am
based on our own needs here, i'd like to especially have more ports in a single router (given the CPU can handle it).
example 1 (medium thoughput, actual router, not CRS):
24 SFP
2 SFP+
example 2 (high throughput):
8 SFP
8 SFP+
example 3 (very high throughput):
8 SFP+
4 QSFP
in all three cases, both PoE-in and PoE-out would be nice if possible.
HarBenly
Mon Jun 05, 2017 10:33 am
These routers are for distribution purpose only?
HarBenly
Mon Jun 05, 2017 10:38 am
Like not for home use right? I am bit confuse. I have a 100mbps connection and Gbit is a lot considering the experience I get on 100.
Hammy
Forum Veteran
Forum Veteran
Mon Jun 05, 2017 3:49 pm
Yes, these are for a new tier of high end Mikrotik routers. As they said initially, 100 gigabit capacity.
j2sw
Mon Jun 05, 2017 10:20 pm
I would like to see a modular router with add in cards for 25G, 40G, and possibly 100G. If I buy a router that I am doing 25G today I want to be able to upgrade that to 100G at one point.
tetecko
Tue Jun 06, 2017 9:55 pm
48x SFP+
6x QSFP
as a BGP router...
edit: any ETA?
k3dt
Tue Jun 06, 2017 10:14 pm
48x SFP+
6x QSFP
as a BGP router...
edit: any ETA?
+1
Hardware like
https://whiteboxswitch.com/products/qua ... -with-onie
http://www.edge-core.com/productsInfo.p ... =59&id=119
have very good performance/price ratio, but it is still too complicated to setup and maintain. With RouterOS this should be (and will be) killer.
nz_monkey
Wed Jun 07, 2017 12:53 am
48x SFP+
6x QSFP
as a BGP router...
edit: any ETA?
I think Mikrotik are talking about a high-touch(services) router, not a low-touch router. This will be a services router like the CCR that can run PPP/NAT type services, not a "low-touch" router/switch that can just forward frames quickly.
stucki
Wed Jun 07, 2017 2:00 am
why even people post switch gear links? we are talking about the next gen ccr
geneb846
Wed Jun 07, 2017 2:19 am
I want 100gb and -48vdc power.
nz_monkey
Wed Jun 07, 2017 6:44 am
Don't we all ? :D
tetecko
Thu Jun 08, 2017 8:44 am
for BGP in IX we need something which have as much ports as possible. And quick forwarding/routing is they key functionality :-)
inspiration here .. http://e.huawei.com/en/products/enterpr ... s/ne/ne40e
tetecko
Thu Jun 08, 2017 9:06 am
now and in the future, there is not difference between L3 switch/router, speed is the key... hardware ASIC with TCAM is what you need.
HarBenly
Thu Jun 08, 2017 12:25 pm
Well this is good news then! So can I get it on my home network?
HarBenly
Thu Jun 08, 2017 12:26 pm
Also, I would like to know if these routers will allow me to distribute Internet bandwidth separately to other connected devices?
Hammy
Forum Veteran
Forum Veteran
Thu Jun 08, 2017 5:44 pm
48x SFP+
6x QSFP
as a BGP router...
edit: any ETA?
An IX shouldn't be doing any routing. An IX should only be switching. Layer 2 only.
nz_monkey
Fri Jun 09, 2017 2:00 am
For the "more ports" people, check out 802.1BR
If Mikrotik were to implement 802.1BR on their routers and switches, it would allow "port extension", e.g. there could be a Mikrotik Router connected to a Mikrotik Switch in "Port Extender" mode, all of the ports on the switch would then appear as if they were local ports on the router.
802.1BR is supported by the switch chips used in the new CRS3xx series of switches, so it would be possible for Mikrotik to add the ability to use the CRS3xx as port extenders for their routers.
Golovics
Fri Jun 09, 2017 2:13 am
until then 802.1ad can be used to connect CRS switches (CRS317-1G-16S+ will make lots of things possible) to CCRs as port extenders
there was great a presentation about this solution last year on Budapest MUM. unfortunately it was in hungarian, that's why the presentation is not available in pdf
tetecko
Sat Jun 10, 2017 12:10 am
BGP is L2 ?
tetecko
Sat Jun 10, 2017 12:13 am
why two or more boxes? it is twice more chance something went broken. One box with enough SFP+ and QSFP port is preferred :-)
Hammy
Forum Veteran
Forum Veteran
Sat Jun 10, 2017 12:24 am
48x SFP+
6x QSFP
as a BGP router...
edit: any ETA?
BGP is L2 ?
The IX infrastructure doesn't do BGP. It just does basic Ethernet. Many (most) do have route servers that do run BGP, but those are best ran on servers, not routers.
tetecko
Sat Jun 10, 2017 1:43 pm
Brocade, Juniper, Arista, Cisco, Huawei ... do you really mean "servers" ? Sorry maybe we talking about two other things, in IXP we have routers and interconnection with other providers by BGP, public IX have "routing servers" most of them Bird I guess.
But if you want to peer with other providers, you need router, with many ports, some ports you use for interconnect, some for transport. Ok, you can do it by two boxes, switch + router, but why? One box is better in may ways. Power, failure, security, backup ....
BartoszP
Sat Jun 10, 2017 2:10 pm
Could you be so kind and do not cite full post if you answer it ? If you need emphasize some part of previous post just cite this part.
Hammy
Forum Veteran
Forum Veteran
Sat Jun 10, 2017 5:39 pm
BGP is L2 ?
I have built and operate two Internet exchanges and am in regular discussion with my colleagues on IX operations. If you are running an IX, you want a switch, not a router. This is because Internet exchanges don't route themselves. They provide a platform to allow operators to connect to. Those operators then run BGP.
Yes, I really do mean servers and most IXes do run their route servers on BIRD, but OpenBGPd is making a comeback. We have built ours on OpenBGPd and are loving it.
If you're an operator connecting to an IX, you only need one port to connect to everybody else. That's the point of an Internet exchange. Obviously you would need other ports for transport, transit, etc. but they have nothing to do with the IX.
https://en.wikipedia.org/wiki/Internet_exchange_point
However, I feel as though we have gone far beyond the OP's question in explaining to you how an IX works. We can continue this conversation elsewhere, if you'd like.
BartoszP
Sat Jun 10, 2017 6:05 pm
Hammy,
Sorry but I have to ask as moderator: Can you read ? Do you understand what I am asking for ?
I have just asked not to cite post under post ... yes, yes, I know that your latest one is not strictly citation "post under post".
PLEASE edit your post and shorten it.
tetecko
Sat Jun 10, 2017 10:58 pm
no flame, but we prefer private direct peering (dedicated fiber), not through public IX. So from our point of view, as many ports as router can have, is better for us.
mmuniz
Trainer
Trainer
Fri Jun 16, 2017 12:42 am
I would like a a 48 SFP's with one or 2 SFP+'s
ideally if it can be Stack-able to have expansion
nz_monkey
Fri Jun 16, 2017 1:13 am
That sounds like a switch rather than a router..
vortex
Sat Aug 12, 2017 6:04 pm
This topic is not about 100Gb ports, but about 100Gb throughput.
Hammy
Forum Veteran
Forum Veteran
Sun Aug 13, 2017 3:11 pm
Which you also don't typically need in a desktop unit. Most of those commenting seem to have lost the initial scope of the request.
juliokato
Sun Aug 13, 2017 6:30 pm
acruhl
Sun Aug 13, 2017 8:02 pm
Way, way off topic, sorry:
What OS and what hardware?
I played with it on a PC just to see how it worked but it's been a while. Would be cool to deploy that on OpenBSD on beefy hardware, should be solid based on what I've seen.
Hammy
Forum Veteran
Forum Veteran
Sun Aug 13, 2017 8:43 pm
Running OpenBSD on Proxmox and vSphere VMs now. Well, some older Dell hardware too. Low load, so don't need much power behind it.
TomjNorthIdaho
Tue Aug 15, 2017 9:28 pm
I think I will add another 2 cents of my thoughts ...
I would like to see some copper 10-gig ports. (or 10/100/1-gig/10-gig ports).
How about something where we have 4 SFP+ ports and all Ethernet ports are 10/100/1-gig/10-gig ports and all ports are on a switch-chip.
My reasoning for the copper 10-Gig Ethernet ports is that servers are now available with copper 10-gig Ethernet ports.
paulct
Fri Oct 13, 2017 3:54 pm
Bump, @Mikrotik can you give any details of what is potentially being planned? Are you going to be moving of the Tilera platform? Marvell? Broadcom? 2018 launch? Faster Mhz CPU's?
normis
Fri Oct 13, 2017 3:57 pm
We only gather ideas, but there is nothing to announce yet. When we have something ready, we will announce it in our MUM conference.
berlo
Fri Oct 13, 2017 4:09 pm
@normis for me new router need to be able to handle medium/high pps during attacks. We have lot of customers that joined our DDoS protected transit service because they have 100% CPU usage and loose router access during tcp floods (ccr1036 and ccr1072 devices).
As personal experience, on our CCR1072 we're able to push 15-20Gbps on exchanges without any issue. .Is useless create >100Gbps routers capacity when 1gbps tcp can block him (like ccr1072 now).
stucki
Sun Nov 26, 2017 5:12 pm
normis, we need sfp28 and qfp28
jmginer
Sun Dec 03, 2017 4:26 pm
QSFP28
Sanity
Sat Feb 10, 2018 8:00 pm
Have to step in here...
the next logical step would be a SFP28 / QSFP uplink SWITCH - routing not SO much needed, you can start with an Ethernet switch (though RouterOS would be appreciated). "Cloud Core" is moving to 25gbit, not alone because Intel has no network card (that I could find) in the 10g range that supports RDMA. Shame. And the Mellanox for a similar price to the Intel 710 - are SFP28. So, next round of servers here gets 25g Ethernet.
Cheapest switch I could find is https://www.fs.com/products/69375.html - 48 SFP28 and 6 QSFP for uplink. Which is too large for MY needs - a 16+2 port would be enough. Still, that things runs at 5000USD. WIthout OS - which adds significantly. On the plus side it is an ONIE switch, so you can choose the OS to use (hint: Mikrotik ONIE would be nice, handles flexible hardware). There is one free from MS, but it is db driven (no config command line, pulls config from a database - VERY nice for a large setup, they use that on Azure, but very limited on smaller scale setups). There is a smalle rversion (18xSFP28, 4xQSFP28) that costs around 6000 complete with OS.
kingfly2000
Wed Mar 07, 2018 6:24 am
We are working on some future high speed routers with around 100Gbit throughput, and we would like your input on what types of ports you would want to see in such devices.
If you imagine a device with around 16 ports (just an example), how many of them would you want to be (just examples, you can add your own ideas):
SFP+ (10G)
SFP28 (25G)
QSFP (4x10G)
10Gbit copper (10G)
Management with PoE
Let us know in the replies here
That is great, I hope you can launch a router with at least 4 QSPF ports.
TomjNorthIdaho
Re: Which types of ports would you like to see for a high speed router
Wed Mar 07, 2018 5:43 pm
SFP+ (10G)
SFP28 (25G)
QSFP (4x10G)
10Gbit copper (10G)
Management with PoE
Question re "...routers with around 100Gbit throughput..."
To better understand the question and better formulate a response, I would like to ask what type/brand of CPU(s) are being considered to acheive 100Gbit routed L3 throughput ?
Mandroid76
Thu Mar 15, 2018 6:02 pm
I would be amazing to have this Mikrotik switch:
24 SFP
4SFP+ (10G)
Two gigabit copper ports
We want to upgrade our network and replace Alcatel switches with Mikrotk.
hknet
Tue May 01, 2018 12:07 am
12 x SFP+ (10G)
4 x QSFP (4x10G)
second that.
StanNats
Thu May 10, 2018 10:07 pm
For example,
I working now on a project for vip-class residential high-rise buildings. And we planning to make 10GFTTH. What we want to have on one site:
1. Stackable switch (Layer 2 and Layer 3 switching) for 500 SFP+ ports (in total) and 10x100Gb ports for uplink, with 128 Gb/s cross-connection between switches (connecting as ring).
2. For apartments we need user router with 2 (or 4) SFP+, 6 ports 10GBASE-T, and 10 ports GBASE-T (maybe few RS485 for telemetry, IoT, alarms).
3. Something like UBNT UAP-XG (bgn/ac/Wave2, if it will also have /ad this will be good) with real seamless WiFi roaming.
This APs and router will installed in apartments as defaults.
kingfly2000
Sun Jun 24, 2018 9:01 am
it has been more than one years, still don't see 100G port router from mikrotik, any new update?
anuser
Long time Member
Long time Member
Mon Sep 10, 2018 10:15 pm
Any news about this one? Any hints, any signs? Any rumors?
Back to CPUs/ASICs: Cavium´s Thunder X2 or Octeon TX look great.
=> list price for 32 core Cavium´s CN9980 is $1795
keefe007
Tue Oct 23, 2018 2:01 am
What's the status on these new router models?
ste
Tue Oct 23, 2018 4:47 am
SFP+ (10G)
SFP28 (25G)
QSFP (4x10G)
10Gbit copper (10G)
Management with PoE
6x10Gbit Copper, 4xSFP+, 2xSFP28
Hammy
Forum Veteran
Forum Veteran
Wed Oct 24, 2018 3:01 pm
The 40G we use still requires LC.
vortex
Wed Oct 24, 2018 3:33 pm
If 40G switching is already good for CPE, I think core would need 100G.
nz_monkey
Thu Oct 25, 2018 4:08 am
40gig is older generation now. No new gear is coming out with 40G on it any more, everything new is 100G QSFP28 as the chipsets cost the same whether they have 40G or 100G ports.
Also, the carrier/service provider industry has never embraced 40G, it has always been 10G, 25G, 100G, 200G and now 400G.
vortex
Thu Oct 25, 2018 1:44 pm
You could buy a small Ryzen NAS and a couple 40G cards for your home. You cannot do that with 100G.
I did not say 40G for the datacenter.
If you can plug a 40G cable into the 100G port and a small router/switch does not become much more expensive, 100G would be preferred for such a device, as one SSD is enough to saturate 40G. But that is not the subject of the discussion.
ufm
Wed Nov 14, 2018 12:51 pm
Hi!
I think you first need to learn how to make stackable hardware.
WBR,
Fyodor.
nz_monkey
Wed Nov 14, 2018 2:16 pm
Hi!
WBR,
Fyodor.
Which other routers are stackable ?
Tiesto
Thu Dec 13, 2018 10:46 am
Good day!
Here is my idea
1) The main thing is that the router should have power supply modules like on CCR1072 (48v + 48v, 48v + 220v, 220v + 220v)
2) The router should have a minimum of 8x10GB (SFP +) and a 2x40GB interface. And so, you can create a router with 8x10GB (SFP +) and a slot for modules with interfaces 2x25GB or 2x40GB or 2x25GB + 2x40GB interface.
3) A CPU that will, without any problems, handle this interface volume on the switching ~ 320/480/960GB router. Because with this amount of data, many will use Mikrotik CCRxxxx as a core router with BGP Full View.
4) You can increase the size of the router by 2U or 3U. Not so much difference between 1U or 2U or 3U.
Best Regards.
AlainCasault
Trainer
Trainer
Thu Dec 13, 2018 3:12 pm
Given that there are switch chips and encryption chip, how about other types of specialized ASICs to further offload the cpu and give the boxes better performance.
A firewall chip perhaps??
Sent from my cell phone. Sorry for the errors.
Hammy
Forum Veteran
Forum Veteran
Thu Dec 13, 2018 4:06 pm
Switch chips typically have ACL capabilities built-in.
AlainCasault
Trainer
Trainer
Thu Dec 13, 2018 6:12 pm
Limited to layer 2 I assume??
TomjNorthIdaho
Thu Dec 13, 2018 8:07 pm
When it comes to future new features on new designs of Mikrotik devices ,...
I would like to propose:
#1: CRS (Bad Boy)
- An Intel XEON processor on a motherboard (fast clock with lots of CPU cache & ability to disable CPU hyper-threading)
- Zero 1-Gig ports (no 1-Gig only ports)
- Qty ten SFP+ (10-Gig) ports
- Qty 4 10-gig Ethernet ports (copper)
- A card slot for an optional faster-than-10-Gig I/O card that can be inserted later)
- All I/O ports use a single switch chip
--- Designed for maximum performance ---
#2: CRS (Bad Boy's little brother)
--- Designed to be cost effective ---
Tiesto
Thu Dec 13, 2018 10:01 pm
I apologize, but the name of the topic about the "high speed router", and not on the switch...
TomjNorthIdaho
Fri Dec 14, 2018 5:48 pm
So , I am assuming that you think/feel that a hardware switch-chip and/or a XEON processor and/or 10-Gig SFP+ and/or 10-Gig copper-ethernet ports and/or a faster than 10-Gig expansion slot would would not make a router run faster for Layer 1, Layer 2 and Layer 3 throughput ?
anuser
Long time Member
Long time Member
Thu Jan 24, 2019 11:19 pm
It´s 01/2019: Any rumors when the new router will be released?
Hammy
Forum Veteran
Forum Veteran
Fri Jan 25, 2019 6:04 am
Usually big announcements are at the EU MUM.
Redmor
Fri Jan 25, 2019 8:14 am
I would like a CCR 1036 with 4 SFP+
anuser
Long time Member
Long time Member
Mon Apr 29, 2019 5:26 pm
04/2019 is over: Any rumors when the new router will be released?
anuser
Long time Member
Long time Member
Mon Jul 08, 2019 11:05 pm
06/2019 is over: Any rumors when the new router will be released?
jarda
Mon Jul 08, 2019 11:53 pm
No need to ask every three months. Once per three years is more than enough.
savage
Tue Jul 09, 2019 9:30 am
LOL
normis
Wait, which new router?
Hammy
Forum Veteran
Forum Veteran
Tue Jul 09, 2019 2:57 pm
I'm assuming the one that this thread was started for.
normis
Tue Jul 09, 2019 3:38 pm
Thread was started to get ideas about potential requirements in hypothetical devices that may come in the future, not a specific product. To see what standards people see as becoming more needed etc.
ste
Tue Jul 09, 2019 4:17 pm
Yea. But my first wish is to make interfaces work perfect which are there. I still cant see how flow control is negotiated. It happens flow control is not negotiated at all. And I often have the problem with negotiation on sfp interfaces. I need to disable/enable an interface after reboot (made a script) to make it work.
Imho it is senseless to buy a high speed router with e.g. QSFP+ with only basic Ethernet functionality.
(As WISP I would like to see a bigger/more powerful powerbox pro (which is a great device) with SFP+ (or integrated LC-Singlemode plugs), and mixed 24/48V POE ports).
guipoletto
Wed Jul 17, 2019 10:22 pm
This.
Oversite
Sun Mar 15, 2020 3:18 am
Hi, great thread.
I would love to see SFP28 and QSFP28 with support ofcourse for SFP+/SFP. Something like the crs317 but with SFP28 instead of SFP+ plus 2 QSFP28.
richard_s
Thu Apr 23, 2020 3:33 pm
Interesting thread. I would like 2-4 QSFP ports with 24 SFP+ ports that are both 1 and 10 Gig capable. For the CPE HAP ac's etc a VOIP port RJ11 connection.
joarc
Thu Apr 23, 2020 5:09 pm
Ehm, that 2-4 QSFP ports and 24 SFP+ already exists:
https://mikrotik.com/product/crs326_24s_2q_rm
AFAIK, mikrotik supports 1G and 10G SFPs in SFP+ ports.(Atleast it does in the CRS317)
richard_s
Fri Apr 24, 2020 8:47 pm
Ooops. Missed that shopping time
mhugo
Tue Jan 05, 2021 3:10 pm
One thing I notice is that MT like with the new CCR2xxx has 2 faster ports, but I would say 4 would be required.
2 ports only makes it possible to build rings, but with 4 or more meshing is possible. For me 4 would be enough normally.
/Mikael
richard_s
Wed Jan 27, 2021 11:31 pm
Joarc I am holding off I would like to see 100G upstream with 10 SFP+ down feeding 1 SFP+ to 10 1G SFP or 2 SFP+ to 20 1G SFP routers for feeding customers with 1G capability. The 40G modules are not that common I can see the 25G-50G-100G-200G route prevailing in the long term and end up with the modules coming down in price lower than 40G units.
New 5 mile fiber backbone going in March this year and I said I was retiring 5 years ago. With luck new routers/switches available for me!!! Time to wake up LOL.
My penny's worth
Richard
jerryroy1
Thu Feb 11, 2021 1:19 am
I have 10 New HP servers and all have 10gb and 25GB ports. Our Current HPE switches do not have 25gb support. Which Mikrotik Switches support this? I was unable to see this standard on the routerboard site.
QSFP28
SFP28
seriousblack
Thu Feb 11, 2021 8:42 pm
Any update on this?
We need something better than 1072? or a 1072 with 40G/100G
richard_s
Fri Dec 10, 2021 6:15 am
I would love a SFP version of the RB4011iGS+RM 20 SFP ports instead of RJ45 as none of my customers are within ethernet range of my cabs. I cant be the only one in this boat. 2 x SFP+ and 20 SFP would be ideal.
inteq
Thu Dec 16, 2021 12:29 am
2 x SFP+ (10G)
2 x 10Gbit copper (10G)
1 x Management with PoE
99% of locations I manage are using only 1 ISP, thus most multi port routers are pretty much empty (only using two ports because switches on RBs are crap)
athome
Tue May 31, 2022 3:47 pm
Hi Normis,
The CCR2004-1G-2XS-PCIe smart PCIe network interface card is finally here.
Are there plans to release an updated fw with an RDMA Engine and driver?
Br
