MUM Europe 2020
rodyeo
Hotspot AAA Microsoft IAS RADIUS - By Rodney Yeo
Fri Nov 17, 2006 10:10 am
How to setup Hotspot AAA Microsoft IAS RADIUS for use with MikroTik – By Rodney Yeo
Part A - Setup IAS RADIUS on Active Directory Services
1. Setup IAS on a server acting as Active Directory Services Domain Controller and register it’s services. (Ref: IAS-Setup1.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup1.JPG
2. Give a meaningful description and enable logging for authentication status. (Ref: IAS-Setup2.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup2.JPG
3. User respective 1812 for Authentication and 1813 for Accounting port only. (Ref: IAS-Setup3.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup3.JPG
4. Create a Realms profile, find “User-Name” replace it with “DOMAIN\User-Name” variables into IAS. (Ref: IAS-Setup4.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup4.JPG
5. Create a “hotspot.com” client profile and set IP address pointing to MikroTik hotspot server 172.19.1.253. Set Client Vendor to RADIUS Standard and enter a unique password for IAS. Do not enable Attributes Signature check box. (Ref: IAS-Setup5.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup5.JPG
6. Enable Remote Access Logging check box for all properties. (Ref: IAS-Setup6.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup6.JPG
7. Select IAS Format and set Log Time Period to Daily. (Ref: IAS-Setup7.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup7.JPG
8. Create Remote Access Policies profile to “hotspot.com”. Add “Windows-Groups” matches “DOMAIN\Username” profile. Enable Grant remote access permission. (Ref: IAS-Setup8.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup8.JPG
9. At Authentication tab Enable check box for “MS-CHAP v2, MS-CHAP, CHAP and PAP” method. Note HotSpot only uses PAP method. (Ref: IAS-Setup9.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup9.JPG
10. At Encryption tab Enable all the check box allowed by this profile. (Ref: IAS-Setup10.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup10.JPG
11. At Advance tab do not add any additional connection attributes. (Ref: IAS-Setup11.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Setup11.JPG
Part B - Setup IAS RADIUS with MikroTik
1. Add a RADIUS server profile and enable service for “hotspot”. Enter IP Address of IAS RADIUS server. Enter the same password created earlier for RADIUS secret. Use port 1812 for Authentication and 1813 for Accounting with Timeout at 300ms. (Ref: IAS-MT-Config1.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-MT-Config1.JPG
2. At “Hotspot Server Profiles” Login By check “HTTP PAP” only. (Ref: IAS-MT-Config2.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-MT-Config2.JPG
3. At “Hotspot Server Profiles” check Use RADIUS and Accounting. NAS Port Type leave it as (19 wireless-802.11) or change to 15 (Ethernet) mode. (Ref: IAS-MT-Config3.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-MT-Config3.JPG
Part C – Testing IAS RADIUS with PC
1. Use NTRadPing Test Utility to verify the communication link with a test PC. http://www.dialways.com/download/
2. Remember to add in the test PC IP Address intended for testing into the IAS Client Profile before initiating test.
3. Enter the IAS RADIUS server IP Address and port “1812” for Request Type “Authentication Request” mode followed by the RADIUS Secret Key. (Ref: IAS-Test1.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Test1.JPG
4. Also enter the User-Name found in the Active Directory Service User Domain Lists. If successful response reply will be “Access-Accepted”.
5. Next change port to “1813” for Request Type “Accounting Start” click send and reply should be “Accounting-Response” if the RADIUS server is working. (Ref: IAS-Test2.JPG) http://wiki.mikrotik.com/wiki/Image:IAS-Test2.JPG
Part D – Activating Domain Users for IAS RADIUS
1. Check for respective User properties if they are member of “RAS and IAS Server” groups, if not add them as group members. (Ref: AD-User_IAS1.JPG) http://wiki.mikrotik.com/wiki/Image:AD-User_IAS1.JPG
2. Next check the Dial-in tab and enable Allow access for Remote Access Permission. (Ref: AD-User_IAS2.JPG) http://wiki.mikrotik.com/wiki/Image:AD-User_IAS2.JPG
Part E – Using CHAP Authentication method
1. To use CHAP authentication method for Hotspot kindly go to the respective users in the Active Directory user properties.
2. At Account tab just below Password never expire check box, enable “Store password using reversible encryption” option. Note: This is required for CHAP to work in IAS (Ref: CHAP-Test-1.JPG) http://wiki.mikrotik.com/wiki/Image:CHAP-Test-1.JPG
3. Next Reset the respective user password for the encryption function to take place. Exit Active Directory Users and Computers mmc console. (Ref: CHAP-Test-2.JPG) http://wiki.mikrotik.com/wiki/Image:CHAP-Test-2.JPG
4. Go to Hotspot Server Profile, click Login By tab and ensure HTTP CHAP is enable. You can leave HTTP PAP just incase users cannot login using CHAP it will use PAP method. (Ref: CHAP-Test-3.JPG) http://wiki.mikrotik.com/wiki/Image:CHAP-Test-3.JPG
5. Finally test if the CHAP authentication is working using NTRadPing and it should show “Access-Accepted” which means it is working! (Ref: CHAP-Test-4.JPG) http://wiki.mikrotik.com/wiki/Image:CHAP-Test-4.JPG
Note: Please see attached setup image files for illustrations.
P.S. Many Thanks to Mat Dawam mda@landasan.com.my and Hamidi Yaacob hamidi@landasan.com.my of Landasan Teknologi (M) Sdn Bhd for Technical Support of MikroTik RouterOS deployment in Malaysia for Metropolitan College Malaysia.
*** The End ***
Could also Refer to Wiki Pages...
http://wiki.mikrotik.com/wiki/AAA_with_Active_Directory
Rodney Yeo
sergejs
Fri Nov 17, 2006 7:59 pm
You can post the same configuration to the MikroTik wiki,
arashi
Mon Nov 20, 2006 6:17 am
Sorry, but where are the attached setup image files?
rodyeo
Mon Nov 20, 2006 6:36 am
Okay, thanks... will contribute as suggested but I wonder if I could upload the sample configuration files to the server?
Rodney
rodyeo
Mon Nov 20, 2006 6:38 am
Sorry about that... I can't seems to upload any file into this forum? Any other way to upload files?
Rodney
balimore
Forum Veteran
Forum Veteran
Mon Nov 20, 2006 6:50 am
Rodney
put all images to other host server and linked to this post..please..!!!!
regards
Hasbullah.com
rodyeo
Mon Nov 20, 2006 8:13 am
Thanks for the tips! How silly, my ignorance.... still new to this forum thing... Good Luck in trying... It only works with PAP! I can't seem to get it to work with CHAP and MAC authentication via IAS RADIUS... Still on R&D...
Regards,
Rodney
Rodney
regards
Hasbullah.com
arashi
Mon Nov 20, 2006 9:01 am
Thanx a lot for the tips and the updates bro :)
rodyeo
Mon Nov 20, 2006 1:55 pm
No worries... thanks to you guys for the encouragement and support....
Rodney Yeo
rodyeo
Re: Hotspot AAA Microsoft IAS RADIUS - By Rodney Yeo
Wed Nov 22, 2006 9:55 am
Dear All,
I have just modified this main thread with the addition of my previous query of CHAP authentication via IAS for Hotspot solution is now resolved!
With the great help from guys from Landasan Teknologi (M) Sdn Bhd namely Mat Dawam and Hamidi.
Rodney
Rodney Yeo
squintr
Thu Mar 22, 2007 5:37 pm
These instructions/screenshots seem to apply to Windows 2000. Our Windows 2003 Server is displaying different screens (eg. missing the "realms" tab). Is the setup for Server 2003 much different?
I can't seem to get it working -- works from my desktop (on the same subnet as the RADIUS server) but doesn't work with the test utility from the desktop on the Hotspot interface (different subnet) even though I can ping the RADIUS server.
squintr
Sat Mar 24, 2007 5:00 pm
Actually I figured it out..
On the IAS server I was putting the IP address of the Hotspot gateway forgetting that it was masquerading itself so I changed it to the LAN Gateway and it worked.
rodyeo
IAS Radius with MikroTik
Sun Mar 25, 2007 12:14 pm
Sorry, I was away on another project and forgot to check in this forum for quite some time now.
I am glad you got it working... It was my Malaysian MikroTik distributor namely Mr. Mat Dawam of Landasan Teknologi company got it figured out base on the similar test done on FreeRadius.
Best Regards,
Rodney Yeo
IT System Support
IT Department
http://www.metropolitan.edu.my/
MForooghii
PDF file
Thu Jun 14, 2012 9:56 am
hi
there is the pdf document of this post
thanks to Rodney Yeo
rodyeo
Re: PDF file
Thu Jun 14, 2012 2:09 pm
hi
Thanks for the PDF compilation... :-)
Rodney Yeo
rebel2234
Thu Sep 05, 2013 1:18 am
Has anyone done this with Windows Server 2008 R2? I am having difficulty trying to replicate this in Server 2008. Anybody have a guide on how to do it? Or make a guide on the WIKI on how to do Hotspot AAA with Microsoft Server 2008 "Network Policy Server (NPS)".
jemp
Fri Nov 08, 2013 4:24 pm
Also I am searching for this for 2008R2 NPS
Any Usefull Guide
Did anybody succeed ?
I can reach the Server, but get Always rejects on the user aacount or passwords
JP
vrosic
Fri Nov 15, 2013 2:31 pm
It is because hotspot can handle only PAP auth. so, in network policies, constrains, authentication methods disable everything except "Unencrypted authentication (PAP, SPAP)"
onowojemma
Re:
Fri Jun 27, 2014 1:20 pm
Mikrotik! making networking easy
onowojemma
Re:
Fri Jun 27, 2014 1:23 pm
Hi sorry for boarding you, you follow the example above what of the realm thing am also using server 2003 and there is no realm
Kind regard.
otgooneo
Trainer
Trainer
Thu Mar 26, 2015 3:53 am
Hi Rodney,
Thank you for your great post. Very useful. How about DHCP with AAA on MT and AAA is active directory without hotspot or ppp.
Want to learn more and more...
Users browsing this forum: Bing [Bot] and 146 guests
