aseques
CRS326-24G-2S+RM speed test?
Thu Jun 08, 2017 4:53 pm
Hi, just unwrapped two units of CRS326-24G-2S+RM, updated them to 6.39.2 and plugged a couple a 10G sfp+ to test it's capabilities. I fired a btest between them and it seems that I can't get more than 1Gbps. See the image attached.
It seems that there's a cap somewhere to 1G, but don't know if it's hardware / software limitation, or that I just have to setup something differently..
macgaiver
Re: CRS326-24G-2S+RM speed test?
Thu Jun 08, 2017 4:55 pm
Really, are you running Btest from the switch??
You need to run it from 1 x86 to other x86 through the switch.
aseques
Thu Jun 08, 2017 5:18 pm
Currently I don't have any 10G capable device other than these two switches, and I specifically (maybe naively) bought those instead of the CSS326 so I could use winbox, and also btest, to check that the fiber link is working as expected.
macgaiver
Thu Jun 08, 2017 5:28 pm
CPUs on CRS series are there to run RouterOS and use some ROuterOS features not to generate 10G of traffic :)
For 10G traffic generation you need full out CCR device and use Traffic Generator.
normis
Fri Jun 09, 2017 1:03 pm
macgaiver is right, the device is not capable of GENERATING random data in such amounts. It should be tested for it's switching speed, not random data generation capacity :)
