With Capsman, it would be useful i think to have an option to automatically disable Radar detection when using low power level outdoor.
Radar detection is not always reliable and can cause very long (sometimes some hours) AP detection times before interface is effectively enabled, specially when using a single or a reduced set of channels.
For short links outdoor, using low power levels, below 20 dbm EIRP, DFS and radar detection is not mandatory to stay below the ETSI regulation standard.
From ETSI :
RLAN band 2 (5470 to 5725 MHz)
Channels from 100 to 140 are part of the second RLAN band and have an EIRP power limit of 30 dBm (1000 mW) for TPC and 27 dBm (500 mW) for non-TPC devices or 20 dBm (100 mW) for devices without any TPC or DFS support. The mean EIRP power level for a slave device with TPC must not exceed 24 dBm at the the lowest TPC power level if the device is also capable of radar detection or 17 dBm otherwise. This band can be used for in- and outdoor deployments as well and is comparable to FCC U-NII-2e.
