VSAT
LIMITING CONNECTIONS
Wed Nov 22, 2006 12:04 am
Hi all
like many of you, we have a rather annoying problem with clients using various P2P programs to download movies and so on.
We have set up queues so that P2P is limited to very little but I find that the upload speed of some clients is still fairly high and the number of connections is also very high.
My question is: is it possible to limit the number of connections per client? if so could anybody tell me how?
All our clients TX and RX rates are already limited.
David
sergejs
Wed Nov 22, 2006 9:09 am
You can limit numbers of TCP connections, but you need to be careful, that p2p client can generate a lot of connections, and other traffic HTTP, etc. might not work correctly.
chnet
use this and will do what you want
Thu Nov 23, 2006 9:38 am
26 X ;;; drop more than 50 connection /ip
ip firewall filter>
add chain=forward protocol=tcp connection-limit=50,32 action=drop
ajmal
Re: LIMITING CONNECTIONS
Sun Nov 26, 2006 7:25 pm
Hi all
David
You can limit your clients by making number of connection in filter rule forward
add following rule(suppose u wans to allow 6 connection for an IP)
add source ipaddress protocol tcp tcp-flag=synk connection-limit 6,32 action drop
datawlan
seems not OK
Wed Dec 20, 2006 1:03 pm
Hi All!
I've tested the example above, and 18 of 18 of my routers (mainly RB532 and 112), and it seems working as follow:
- the packets are dropped correctly (max. f.e. 20 connections)
- after 3-4 days the complete connection is dropped.
It means that f.re. there is no DNS service available for the client, ping goes out to the world but http://www.mikrotik.com can not be displayed on the WEB, only if he writes IP address.
Regards
Zsolt
janisk
Wed Dec 20, 2006 4:16 pm
and you check in conntrack that? do that show, that there are no connections?
sioux
Thu Dec 21, 2006 9:44 am
when I limiting connections number I do it onlu for ports >1024
of course there is always someone who will try to download an iso image wift 100 or more simultaneous connections but is rare.
and of course it's good that default value for tcp-established-timeout is 1day not like in other linux distributions 5day's :)
