miltont
VPN, L2TP
Wed Jun 21, 2017 9:24 pm
Greetings
I configured VPN to my mikrotik, i connect but i can only see mikrotik, but im unable to see other devices that are connected to the network,
10.20.x.x ....
What is missing so i can connect to and see devices on the same network?
Discmandj
Re: VPN, L2TP
Wed Jun 21, 2017 10:32 pm
Hi , put the bridge interface an arp-proxy not enable . If that won't work export your config that I can help you
Gesendet von iPhone mit Tapatalk
miltont
Re: VPN, L2TP
Wed Jun 21, 2017 11:43 pm
so i just disable ARP on my bride interface?
Currently is enabled
In my wan interface where i connect to VPN its enabled as PROXY ARP
Discmandj
Re: VPN, L2TP
Wed Jun 21, 2017 11:51 pm
You need to put your bridge on proxy arp not to disabled it !!
Discmandj
Re: VPN, L2TP
Wed Jun 21, 2017 11:52 pm
Export your config i will give you the right one directly
miltont
Re: VPN, L2TP
Wed Jun 21, 2017 11:54 pm
attached pic
Discmandj
Re: VPN, L2TP
Wed Jun 21, 2017 11:55 pm
Yes put this on proxy arp
Discmandj
Re: VPN, L2TP
Wed Jun 21, 2017 11:57 pm
Go to terminal and type this:
Export file=config , then you will have a file called config under file section on mikrotik drag it to your desktop and open it and send me every thing inside without your internet wan ip and I will do the rest for you
miltont
Re: VPN, L2TP
Thu Jun 22, 2017 12:09 am
that did the trick
thanks
Discmandj
Re: VPN, L2TP
Thu Jun 22, 2017 12:11 am
U welcome
idlemind
Re: VPN, L2TP
Thu Jun 22, 2017 1:58 am
Bad proxy ARP'ers bad!
Have a look at this particular post in this otherwise lengthy thread. You can run L2TP and get access to resources on your LAN networks without proxy ARP. Let the router route!
viewtopic.php?p=604274#p603949
Users browsing this forum: cbrown, mciupak, mudhoney, sid5632, unps and 131 guests
