alaa2003
SSTP between 2 Mikrotik issue with " verify server certificate " at client
Sat Jun 24, 2017 9:42 pm
Hello
i linked 2 mikrotik with sstp and worked normal without certificate
then followed your method in creating certificate by mikrotik Terminal and also worked
problem come in case i check option " verify server certificate " at client
here is shot of server
how to solve this ?
Van9018
Long time Member
Long time Member
Re: SSTP between 2 Mikrotik issue with " verify server certificate " at client
Sun Jun 25, 2017 12:44 am
Use "Verify Server Address from Certificate" instead of "Verify Certificate".
Otherwise the Mikrotik will want to check the server's certificate against a certificate revocation list or online service. Both of which you may not have defined in your CA certificate if you're using self signed certificates.
Users browsing this forum: evilmiky, LunaticRv, mszru, samasd, Sharaf, Zacharias and 159 guests
