2017-06-25 01:43:04 EVENT: CORE_ERROR PolarSSL: error parsing config private key : PKCS5 - Requested encryption or digest alg not available [ERR]
How I figured this out was because the microphone encrypts the private key with a format that does not support iOS.
[root@ip-172-31-14-92 centos]# openssl asn1parse -in 1_cert_export_test-client-ovpn-12.key
0:d=0 hl=4 l=1311 cons: SEQUENCE
4:d=1 hl=2 l= 73 cons: SEQUENCE
6:d=2 hl=2 l= 9 prim: OBJECT
17:d=2 hl=2 l= 60 cons: SEQUENCE
19:d=3 hl=2 l= 27 cons: SEQUENCE
21:d=4 hl=2 l= 9 prim: OBJECT
32:d=4 hl=2 l= 14 cons: SEQUENCE
34:d=5 hl=2 l= 8 prim: OCTET STRING [HEX DUMP]:249CA7FCEC409541
44:d=5 hl=2 l= 2 prim: INTEGER :0800
48:d=3 hl=2 l= 29 cons: SEQUENCE
50:d=4 hl=2 l= 9 prim: OBJECT :aes-256-cbc
61:d=4 hl=2 l= 16 prim: OCTET STRING [HEX DUMP]:0A3C812B3F915210ADB830EC58C43845
On Linux such a conclusion.
[root@ip-172-31-14-92 centos]# openssl asn1parse -in client_07.key
0:d=0 hl=4 l=1294 cons: SEQUENCE
4:d=1 hl=2 l= 64 cons: SEQUENCE
17:d=2 hl=2 l= 51 cons: SEQUENCE
34:d=5 hl=2 l= 8 prim: OCTET STRING [HEX DUMP]:12700371E88C41C2
48:d=3 hl=2 l= 20 cons: SEQUENCE
50:d=4 hl=2 l= 8 prim: OBJECT :des-ede3-cbc
After my manipulations, the algorithms coincided. But there was another mistake.
2017-06-25 23:01:56 Client exception in transport_recv_excode: PolarSSL: SSL read error : SSL - Processing of the Certificate handshake message failed
I ask to help with the decision of the given problem.
