amitkw
The Userman : Simple Hotspot User Manager
Fri Jun 30, 2017 5:15 am
Hello guys.
I just created an application that can be used to manage hotspot users. This application can be an alternative to series routerboard that does not support user manager (userman) one of them is RB941-2nD-TC series (hAP-Lite2) and the like. this app is implementation of RouterOS Delphi API (http://forum.mikrotik.com/viewtopic.php?t=31555).
Indeed when compared to the userman this application lost far away. This application is desktop based and runs on windows & linux operating system. Here is a list of features in this app:
now available on android https://play.google.com/store/apps/deta ... theuserman
- Cross Platform (Windows, Linux & Android)
- Change Language (Custom Language);
- Validity;
- QR Code Login;
- Change Tempate Voucher Hotspot (Custom Voucher);
- Generate users and passwords randomly;
- Users can be grouped using group limit bandwidth (user profile);
- Add user: for users who have no time limit;
- Export user list to Excel file (* .xls);
- Export user list to pdf file (* .pdf);
- Export user voucher to pdf file (* .pdf): for easier distribution process;
- Users who have reached the time limit are marked with a red line;
- Clear counter: so that users who reach the time limit can login again;
- Displays the list of currently active users;
- Delete user and user export can be done based on group limit bandwidth;
- Support all series of mikrotik that supports API or API-SSL;
Interested to try please check on the web development blog of this application at http://theuserman.blogspot.co.id/p/tentang.html
Below are some examples of screenshots
ukitnam
Re: The Userman : Simple Hotspot User Manager
Thu Aug 10, 2017 4:58 pm
hello sir.
thank you for making such a helpful program for those routers that doesnt support the official userman.
im currently using and enjoying your app.
however, i want to request a new feature wherein you can input byte-limits or atleast total-byte-limits
thank you.
please continue developing your app.
amitkw
Wed Aug 16, 2017 4:51 am
hello sir.
thank you.
Thank you for using the userman.
Your request will be added to the next release (17/08/2017) along with other features.
ukitnam
Wed Aug 16, 2017 9:05 pm
hello sir.
thank you.
i already saw your announcement.
qr code login, very nice.
thank you!
ukitnam
Thu Aug 17, 2017 11:44 am
i have now downloaded your latest version.
how ever im facing a problem with the validity settings
after generating users with validity
in comment section, its not complete. instead of month/date/year
its just showing /month/year
example:
/8/2017
amitkw
Sat Aug 19, 2017 5:25 am
I just did a test on windows and linux OS and there is no problem. Please note that the app uses date format dd/MM/yyyy. Try changing the date format of your computer.
darkillusion
Wed Sep 13, 2017 6:36 am
sir are u using lazarus right i would like to ask how to share the mikrotik connection to all additional forms you created in lazarus because i have problem on making the connection to be global in each for so that i will not connect again in mikrotik can you please help me
alialiraqi2
Tue Dec 19, 2017 9:29 am
Possible to download please
buildmasterglobal
Fri May 18, 2018 4:26 am
Code: Select all
please helpe me i cant log in
Please login first
ip address:
user login:
password:
buildmasterglobal
Fri May 18, 2018 4:40 am
hi i cant login can u give me the right
ip address:
login:
password:
thanks
mandybejar
Sun May 27, 2018 4:32 am
Thank you very much.
mikrotikNeo
Sun Dec 16, 2018 6:20 am
can you share the source code for the userman program? I would like to customize it.
ukitnam
Fri Jan 11, 2019 7:23 pm
this is rather useful for hotspot than the official userman+hotspot which is so buggy.
marlonz2
Sat Mar 23, 2019 8:25 am
Code: Select all
Please login first
ip address:
user login:
password:
Im stuck on this part also, Which password and user login does this mean?
amitkw
Tue Mar 24, 2020 1:19 am
now available on android device. check this out https://play.google.com/store/apps/deta ... theuserman
Nirox
Mon Jul 20, 2020 11:57 am
Hello. How can I use this without android. On web or Winbox? Thanks a lot.
Users browsing this forum: Pandik and 3 guests
