SiByte
Slow WiFi (Mikrotik WAP)
Thu Jul 06, 2017 11:50 pm
I have problem with very slow WiFi speed. I use Mikrotik WAP. I try lot of different settings but no change max speed is about 3MB/s from my NAS to device if I use wired connection I get over 100MB/s.
My reality :( Before WAP I use cheap TP-Link for 10€ and I get much higher speed. Around 20-30MB/s or even more.
effndc
Re: Slow WiFi (Mikrotik WAP)
Fri Jul 07, 2017 2:27 am
You likely need to provide more info, start with telling us what model of access point you are using and then how that connects to the rest of your network. You may also want to include the configuration from your access point (run /export compact hide-sensitive). To make it easier when you paste the configuration use the block quote in the editor here.
Van9018
Long time Member
Long time Member
Fri Jul 07, 2017 6:25 am
I stopped using Mikrotik for wifi as I've never gotten anything better than 25mbps (3MB/s) on 2.4Ghz. I switched to another brand for wifi APs and performance is better.
Lots of people have this issue and no solutions found yet.
viewtopic.php?f=7&t=122853
SiByte
Fri Jul 07, 2017 7:16 am
I'm using Mikrotik WAP, WAP AP is connected to HP switch and directly to that switch is also connected NAS. So WAP and NAS are directly connected to same switch.
My configuration
# jul/07/2017 06:14:03 by RouterOS 6.39.2
# software id = Z031-2NY3
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn channel-width=20/40mhz-Ce \
    disabled=no distance=indoors frequency=2417 mode=ap-bridge ssid=Leutgeb_NET \
    wireless-protocol=802.11 wps-mode=disabled
/ip neighbor discovery
set ether1 discover=no
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=guest
/ip hotspot profile
add address-pool=default-dhcp interface=wlan1 name=defconf
add bridge=bridge1 interface=wlan1
add address=192.168.1.5/24 comment=defconf interface=wlan1 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add comment=defconf gateway=0.0.0.0
set allow-remote-requests=yes servers=192.168.1.1
/ip dns static
add address=192.168.1.5 name=router
add action=accept chain=input comment="defconf: accept established,related" \
# in/out-interface matcher not possible when interface (ether1) is slave - use mas
 er instead (bridge1)
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
    ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
    out-interface=ether1
add distance=1 gateway=192.168.1.1
/system clock
set time-zone-name=Europe/Ljubljana
/system identity
set name=AP1
/tool mac-server
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
freemannnn
Long time Member
Long time Member
Fri Jul 07, 2017 8:37 am
can u test transfer from a pc or laptop to NAS with wired connection.
i remember in the old days that some NAS network chip, speed u could achive was only 5mb/sec
SiByte
Fri Jul 07, 2017 5:33 pm
I use HP ProLiant Microserver Gen8 for NAS, and over wired connection I get around 110-120MB/s.
mistry7
Fri Jul 07, 2017 11:40 pm
Please try Setting band=g/n
Is this Channel clear?
Prof13
Sat Jul 08, 2017 1:32 pm
I have the similar issue with my cAP that is working as CAPsMAN's slave from RB2011.
Wi-Fi speed reaches 40 MB/s via RB2011 and 3 MB/s via cAP. Bandwidth test shows ~100 MB/s between the devices.
I will try g/n and only-n modes, and share results in a few days.
pukkita
Trainer
Trainer
Sat Jul 08, 2017 1:57 pm
I assume the wAP is not your Internet router.
There are several things that can be improved on your wAP configuration.
cAP and wAP are basic APs, conceived for serving as bare APs in high-density deployments. The better you optimize the config for their humble CPU, the better.
If this is serving just as an AP, try this config:
add name=bridge1
set fast-forward=yes 0
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn  \
    disabled=no frequency=2417 mode=ap-bridge ssid=Leutgeb_NET \
    wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
/ip hotspot profile
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=bridge1
/system clock
/system identity
set name=AP1
This programs the wAP to be essentially a wired/wireless "switch", which gets it's management IP from dhcp.
Is it advisable to create a static lease on your LAN router so that wAP always gets the same IP, though you could ever manage it without ip via mac-winbox or RoMON (i.e. without any IP addressing on the wAP).
No firewall, nor anything else, just an optimized config so that CPU requirements on the wAP are the minimum, the better, and everything is handled by hardware where possible.
DHCP to the wireless clients will be handled by your main Internet router.
Pay special attention to the devices Firmware (make sure Upgrade Firmware is the same as Upgrade Firmware @ System > Routerboard)
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
pukkita
Trainer
Trainer
Sat Jul 08, 2017 2:04 pm
Prof13: which ROS/Firmware on CAPs and CAPsMAN?
Deaqui
Sat Jul 08, 2017 9:00 pm
Hello Pukkita,
When I connect with the mobile the map lite shows a connection of 54 mb in tx and 72 mb in rx and I can not exceed more than 20 mb doing a test of speed.I tested it with a unify ac lite and with the Movistar router and the speed test shows 40mb more or less.
It is as if for the download the smartphone will connect in g and for the rise in n.
Has this ever happened to you with some Mikrotik ap?
I have tested with map lite, wap, hap lite and groove, but I always get the same result.
SiByte
Sat Jul 08, 2017 11:41 pm
add name=bridge1
/interface wireless
/ip hotspot profile
/ip dhcp-client
/system clock
/system identity
set name=AP1
Yes I use WAP only as WiFi AP. I have upgraded both Firmware and Software,
I try your settings but no change, before WAP I use TP Link model TL-WR741ND (cheapest model) and I never have problems with speed. It has slower CPU speed and half the RAM of WAP so I really doubt that problem is in CPU.
pukkita
Trainer
Trainer
Sun Jul 09, 2017 12:34 pm
Post
- an export.
- a screenshot of wireless > Registration, open the phone entry, signal tab
I have noticed, specially on devices which were released with only one chain and were later upgraded to two chains, that the second chain1 sometimes is not enabled, watch out for that.
pukkita
Trainer
Trainer
Sun Jul 09, 2017 12:52 pm
Hello Pukkita,
Map lite is a "personal" N device AP, there are two versions of it, one 1x1, latter models are 2x2. That could explain why half of the bw.
Unify Ac Lite is a different range AP, and it's AC, so is very possible you were using the 5GHz band. As ubnt doesn't publish Sensitivity specs but for speakers in their products, I cannot be 100% sure, but would say a more comparable (in hardware terms) product would be the hap AC lite.
That being said, if station is within range, it should be able to get speeds around 35Mbps TCP for 1x1 devices, and around 50-70Mbps for dual chain ones.
That's in N. Try forcing N mode only.
Deaqui
Sun Jul 09, 2017 3:12 pm
Hello Pukkita,
Hello again Pukkita:
I have tested with a low-end ZTE smartphone and I have not had any problems.
I performed the tests in 20 mhz. The connection shows 72 mbps in both tx and rx.
What I have observed is that this smartphone can also connect in 40 mhz. When I connect at 40 mhz the connection shows 150 mbps tx and 150 mbps rx.
I think the problem is in the smartphones that can only connect in 20 mhz. I have tried disabling g and leaving it alone as n, but the connection still shows me 54 mbps tx and 72 mbps rx. With this data I only get a speed of 20-25 mbps doing with speedtest. My smartphone is a low-end Huawey Yumo. I have also tested with wap and groove.
A greeting.
Prof13
Sun Jul 09, 2017 4:48 pm
All devices have RouterOS v6.39 and firmware v3.33.
There is a weirdness in cAP work: first speed test can show dl - 19.93MB, up - 4.91MB and second one that is made in 3 sec after the first one can show dl - 3.28MB, up - 3.91MB...
pukkita
Trainer
Trainer
Sun Jul 09, 2017 5:05 pm
Forget about the Air Rate, and 40MHz in 2.4GHz altogether... what counts is a stable connection, for that 20MHz is a must on 2.4GHz.
AirRate doesn't mean data will be actually flowing at those rates.
pukkita
Trainer
Trainer
Sun Jul 09, 2017 5:11 pm
Prof13: check your spectrum, and make optimal picks for channels for each cAP. In 2.4GHz there are only three non-overlapping in 20MHz channels: 1, 6 and 11.
To troubleshoot, you have too look at the signal screenshot I mentioned on my previous post while doing the transmission tests.
Prof13
Mon Jul 24, 2017 3:32 pm
Sorry for the late reply.
I changed band mode to 2ghz-onlyn and it had no effect.
The freest channel was 3rd one, so I configured cAP with 2422 MHz with Ce extension.
Here is "/export compact" for both devices:
RB2011 - CAPsMAN
# jul/22/2017 12:36:49 by RouterOS 6.39
# software id = 37XX-0ZSC
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=Ce frequency=\
    2437 name=channel6 tx-power=30
    2422 name=channel3 tx-power=20
add name=bridge-guest
add name=bridge-internal
set [ find default-name=ether1 ] comment="ISP - Ukrtelecom"
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master name=ether3-slave
set [ find default-name=ether4 ] master-port=ether2-master name=ether4-slave
set [ find default-name=ether5 ] master-port=ether2-master name=ether5-slave
set [ find default-name=ether6 ] comment="ISP - DataGroup"
set [ find default-name=ether7 ] name=ether7-master
set [ find default-name=ether8 ] master-port=ether7-master name=ether8-slave
set [ find default-name=ether9 ] comment="Inner cAP" master-port=\
    ether7-master name=ether9-slave
set [ find default-name=ether10 ] master-port=ether7-master name=\
    ether10-slave
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
# managed by CAPsMAN
# channel: 2437/20-Ce/gn(30dBm), SSID: Braviy Shveik - Guest, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
/interface pppoe-client
add add-default-route=yes comment="PPPoE - DataGroup" disabled=no interface=\
    ether6 name=pppoe-out1 use-peer-dns=yes user=xxxxxxx
/caps-man datapath
add bridge=bridge-guest client-to-client-forwarding=yes name=datapath-guest
/caps-man security
add name=security-guest
/caps-man configuration
add country="united states" datapath=datapath-guest mode=ap name=cfg-guest \
    rx-chains=0,1,2 security=security-guest ssid="Braviy Shveik - Guest" \
    tx-chains=0,1,2
/caps-man interface
add channel=channel6 configuration=cfg-guest disabled=no l2mtu=1600 \
    mac-address=6C:3B:6B:F9:BF:D7 master-interface=none name=cap1 radio-mac=\
    6C:3B:6B:F9:BF:D7
add channel=channel3 configuration=cfg-guest disabled=no l2mtu=1600 \
    mac-address=6C:3B:6B:8B:C5:6F master-interface=none name=cap2 radio-mac=\
    6C:3B:6B:8B:C5:6F
add name=dhcp_pool1 ranges=10.17.16.100-10.17.16.254
add name=dhcp_pool2 ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp_pool1 disabled=no interface=bridge-internal lease-time=\
    1d name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=bridge-guest lease-time=1h \
    name=dhcp2
/ppp profile
set *0 dns-server=80.91.161.75,80.91.160.5
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes \
    require-peer-certificate=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg-guest
add bridge=bridge-internal interface=ether2-master
add bridge=bridge-internal interface=ether7-master
add bridge=bridge-guest interface=cap2
/interface l2tp-server server
set caller-id-type=ip-address
/interface wireless cap
set bridge=bridge-internal caps-man-certificate-common-names=\
    CAPsMAN-6C3B6BF9BFCC certificate=CAP-6C3B6BF9BFCC discovery-interfaces=\
    bridge-internal enabled=yes interfaces=wlan1 lock-to-caps-man=yes
add address=192.168.0.1/24 interface=bridge-guest network=192.168.0.0
add address=10.17.16.1/24 interface=bridge-internal network=10.17.16.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid interface=ether1
add address=10.17.16.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.17.16.1
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.0.1
/ip firewall address-list
add address=10.17.16.0/24 disabled=yes list=LocalNet
add address=192.168.0.0/24 disabled=yes list=LocalNet
add action=drop chain=input dst-port=53 in-interface=ether1 log=yes \
    log-prefix=53_drop_ether1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether6 log=yes \
    log-prefix=53_drop_ether6 protocol=udp
add action=drop chain=input dst-port=53 in-interface=pppoe-out1 log=yes \
    log-prefix=53_drop_pppoe protocol=udp
/ip firewall mangle
add action=mark-connection chain=input disabled=yes dst-address=10.17.16.5 \
    in-interface=ether1 new-connection-mark="Ukrtelecom -> Input" \
    passthrough=no
add action=mark-routing chain=output connection-mark="Ukrtelecom -> Input" \
    disabled=yes new-routing-mark="ISP - Ukrtelecom" passthrough=no
add action=mark-connection chain=input disabled=yes dst-address=94.232.77.199 \
    in-interface=pppoe-out1 new-connection-mark="DataGroup -> Input" \
    passthrough=no
add action=mark-routing chain=output connection-mark="DataGroup -> Input" \
    disabled=yes new-routing-mark="ISP - DataGroup" passthrough=no
add action=mark-routing chain=prerouting disabled=yes dst-address-list=\
    !LocalNet new-routing-mark="Inner network" passthrough=no src-address=\
    10.17.16.0/24
add action=masquerade chain=srcnat comment="ISP - Ukrtelecom" disabled=yes \
add action=masquerade chain=srcnat comment="ISP - DataGroup" out-interface=\
    pppoe-out1
add disabled=yes distance=1 gateway=10.17.16.1 routing-mark=\
    "ISP - Ukrtelecom"
add disabled=yes distance=1 gateway=195.114.143.0 routing-mark=\
    "ISP - DataGroup"
add check-gateway=arp disabled=yes distance=10 gateway=195.114.143.0 \
add check-gateway=arp disabled=yes distance=11 gateway=10.17.16.1 \
/ip route rule
add action=unreachable dst-address=10.17.16.0/24 src-address=192.168.0.0/24
add action=unreachable dst-address=192.168.0.0/24 src-address=10.17.16.0/24
cAP
# jun/29/2017 13:09:54 by RouterOS 6.39
# software id = ULE6-YZHP
/interface wireless
# channel: 2422/20-Ce/gn(20dBm), SSID: Office - Guest, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce \
    country="united states" frequency=2422 frequency-mode=superchannel \
    guard-interval=long hw-protection-mode=rts-cts hw-retries=15 mode=\
    ap-bridge rx-chains=0,1 ssid="Office - Guest" tx-chains=0,1 \
/interface wireless nstreme
set wlan1 enable-polling=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" \
    supplicant-identity=MikroTik wpa2-pre-shared-key=1234567890
/ip hotspot profile
set admin access=\
set caps-man-certificate-common-names=CAPsMAN-6C3B6BF9BFCC certificate=\
    CAP-6C3B6B8BC56E discovery-interfaces=ether1 enabled=yes interfaces=wlan1 \
add address=10.17.16.99/24 disabled=yes interface=ether1 network=10.17.16.0
add address=192.168.1.1/24 network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/system clock
set time-zone-name=Europe/Kiev
/system identity
set name=AP-inside
Configurations look a bit "dirty" because I tried some new configurations for me.
I would be very grateful if you will tell me where is my mistake.
pukkita
Trainer
Trainer
Mon Jul 24, 2017 3:49 pm
Do a spectral-history on both, are you sure the spectrum is useable? Please post it here.
Can you connect another RB as wireless client to cAPs, and post: wireless interface status, and wireless registration signal tab.
Prof13
Wed Jul 26, 2017 1:28 pm
Spectral history from RB2011: http://imgur.com/xboVlvT
Spectral history from cAP: http://imgur.com/h9YRrN3
I used wAP to connect as a wireless client to the cAP and got the following results.
Wireless interface status: http://imgur.com/LBzuFOT
Wireless registration tab: http://imgur.com/kuwOq4W
Why does Tx/Rx rate reach only1mb/6mb?...
mistry7
Wed Jul 26, 2017 10:35 pm
Channel is crouded
pukkita
Trainer
Trainer
Thu Jul 27, 2017 12:45 pm
it could be it actually isn't able to lock on higher modulations, please re-take the shots while passing traffic with bandwith test, ping speed or whatever.
From what you posted:
1.- Looks like your spectrum is really crowded
2.- Please double click on the registration tab entry, and shot the signal tab while passing traffic between them (e.g. by using bandwidth test between them).
3.- Looks they are using most basic G modulations, which could be explained by #1 (interference forces fallback to using basic rates)
smaritz
Fri Dec 22, 2017 8:01 am
I'm having the exact same issue, and it seems Pukitta is not able to provide any other help than the basic 1 2 3 guide to wifi problems.
* No channel congestion
* Cable from router to AP tested with another device, tested fine
* Another cable used to test, same result.
* B/G/N makes no difference
* Newest firmware/software
* Tested with various clients
Very low latency (30ms+), low speeds (1-2mbps), and I've come to the conclusion that this is just a low quality device that should now have been released to the market, and will be returning it next week and replacing it with a Ubiquiti.
Casper87
Fri Feb 16, 2018 10:09 pm
Same problem here...but i replaced wAP AC with UAP-AC-PRO and my WiFi it's okay now.
Aleksov
Thu Mar 22, 2018 10:48 pm
Hello. Got a same problem. I'm use RB3011 as CAPsMAN controller and CAPac as AP. On 5GHz got maximum 13 Mbit/s download and 89 Mbit/s upload speed. If i use cable connection direct to RB3011, got about 90/90 Mbit/s... Distance between my laptop and CAPac about 150mm (yes, i'm try longer distance)...
https://imgur.com/a/jzHoD
Here my CAPsMAN config:
caps-man export
# mar/22/2018 23:38:55 by RouterOS 6.41.3
# software id = 6WX1-0034
# model = RouterBOARD 3011UiAS
# serial number = 783D08F717B0
/caps-man channel
add band=2ghz-b/g/n frequency=2412 name=CH1
add band=2ghz-b/g/n frequency=2417 name=CH2
add band=2ghz-b/g/n frequency=2422 name=CH3
add band=2ghz-b/g/n frequency=2427 name=CH4
add band=2ghz-b/g/n frequency=2432 name=CH5
add band=2ghz-b/g/n frequency=2437 name=CH6
add band=2ghz-b/g/n frequency=2442 name=CH7
add band=2ghz-b/g/n frequency=2447 name=CH8
add band=2ghz-b/g/n frequency=2452 name=CH9
add band=2ghz-b/g/n frequency=2457 name=CH10
add band=2ghz-b/g/n frequency=2462 name=CH11
add band=2ghz-b/g/n frequency=2467 name=CH12
add band=2ghz-b/g/n frequency=2472 name=CH13
add band=5ghz-a/n/ac frequency=5180 name=CH36
add band=5ghz-a/n/ac frequency=5200 name=CH40
add band=5ghz-a/n/ac frequency=5220 name=CH44
add band=5ghz-a/n/ac frequency=5240 name=CH48
add band=5ghz-a/n/ac frequency=5260 name=CH52
add band=5ghz-a/n/ac frequency=5280 name=CH56
add band=5ghz-a/n/ac frequency=5300 name=CH60
add band=5ghz-a/n/ac frequency=5320 name=CH64
add band=5ghz-a/n/ac frequency=5500 name=CH100
add band=5ghz-a/n/ac frequency=5520 name=CH104
add band=5ghz-a/n/ac frequency=5540 name=CH108
add band=5ghz-a/n/ac frequency=5560 name=CH112
add band=5ghz-a/n/ac frequency=5580 name=CH116
add band=5ghz-a/n/ac frequency=5600 name=CH120
add band=5ghz-a/n/ac frequency=5620 name=CH124
add band=5ghz-a/n/ac frequency=5640 name=CH128
add band=5ghz-a/n/ac frequency=5660 name=CH132
add band=5ghz-a/n/ac frequency=5680 name=CH136
add band=5ghz-a/n/ac frequency=5700 name=CH140
add band=5ghz-a/n/ac frequency=5745 name=CH149
add band=5ghz-a/n/ac frequency=5765 name=CH153
add band=5ghz-a/n/ac frequency=5785 name=CH157
add band=5ghz-a/n/ac frequency=5805 name=CH161
add band=5ghz-a/n/ac frequency=5825 name=CH165
/caps-man datapath
add bridge=BV0101 local-forwarding=yes name=2G-datapath
add bridge=BV0101 local-forwarding=yes name=5G-datapath
add bridge=BV0200 local-forwarding=no name=Public-datapath vlan-id=1
add channel=CH6 country=russia3 datapath=Public-datapath mode=ap name=2G-config-pub rates.vht-basic-mcs="" rates.vht-supported-mcs="" rx-chains=0,1,2 ssid=hotspot.set.local  tx-chains=0,1,2
/caps-man rates
add basic=54Mbps ht-basic-mcs="" ht-supported-mcs="" name=rate-54 supported=54Mbps vht-basic-mcs="" vht-supported-mcs=""
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm,tkip name=public passphrase=password1
add authentication-types=wpa2-psk encryption=aes-ccm,tkip name=local passphrase=password2
add channel=CH6 country=russia3 datapath=2G-datapath mode=ap name=2G-config rx-chains=0,1,2 security=local ssid=hs2.set.local tx-chains=0,1,2
add channel=CH52 channel.tx-power=10 country=russia3 datapath=5G-datapath mode=ap name=5G-config rx-chains=0,1,2 security=local ssid=hs5.set.local tx-chains=0,1,2
/caps-man manager
set enabled=yes package-path=/disk1/packages/routeros upgrade-policy=require-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=VR0600
add action=create-dynamic-enabled hw-supported-modes=gn identity-regexp="spot([0-9]+).hotspot.set.local" master-configuration=2G-config name-format=prefix-identity slave-configurations=2G-config-pub
add action=create-dynamic-enabled hw-supported-modes=ac identity-regexp="spot([0-9]+).hotspot.set.local" master-configuration=5G-config name-format=prefix-identity
Hammer
Mon May 07, 2018 12:10 pm
Is there anything new? I have an RB3011 in two places as CAPsMAN with hAP ac and the WLAN speed is about 10% of what I should have.
Newest stabile RoutOS FW and HW FW on all Device.
yhfung
Mon May 07, 2018 12:58 pm
Have you upgraded your CAP ac to the most newest one v6.43rc6? It includes significant speed improvement on WiFi of CAP ac and hAP ac^2.
Hammer
Mon May 07, 2018 8:08 pm
I saw the notice in another post, so it is an improvement there (not much time to test).
CAPsMAN and its products have been on the market for a long time, what's the problem?
luigim
Mon Jul 09, 2018 10:05 pm
I am having the same issue here. RB3011 as main router and CAP ac as AP. Very slow wireless speed. When I connect directly to 3011, I do get about 99mbs but wireless will only get 1~2. Anyone found a solution for this?
aschulze
Tue Jul 10, 2018 11:59 pm
The same problem here: 2011UiAS as CAPSManager and three hAP ac as CAPs.
All connected with 1GBit on a HP1820 Switch. On the ethernet ports I can transfer up to 108MB/s constantly. On WLAN I can transfer max. 1-2MB/s with strong fluctuations. This is terrible poor and unusable.
SilverNodashi
Thu Jan 10, 2019 11:54 am
I am having the same issue with a RB951Ui-2HnD, acting as "home AP. The wireless devices connect at 150Mbps yet they only get about 1Mbps internet speed on a 30Mbps fiber link. When plugging my laptop directly into the RB951Ui-2HnD LAN ports I get about 18Mbps download and 30Mbps (http://www.speedtest.net/result/7945325110) upload on speedtest.net. Yet, on wifi I only get about 3Mbps (http://www.speedtest.net/result/7944015867)
Does anyone know what could cause this?
flaiale
Thu Oct 17, 2019 6:03 pm
I noticed the association between the devices and the access point is pretty slow comparing to another wifi system ...is there a reason for that ?? And also is there a way to get back the 5Ghz signal after the 2,4Ghz ?? Any device normally connects to 5Ghz frequency when you are close to the router and switch to 2,4 Ghz when you are more far ...but after that it stays connect to 2,4 Ghz even if you are in fron of the router ...Is there a way to fix this issue ??
Van9018
Long time Member
Long time Member
Wed Oct 23, 2019 8:19 am
Your laptop won't change wifi access points unless the connection is broken. So when you leave the 5Ghz range, the connection is broken and it finds the 2.4Ghz wfii. When you come back, it'll stay on the 2.4. This is by design because if your laptop tries to switch APs, your apps will lose connectivity to their respective endpoints and will have to reconnect.
mkx
Wed Oct 23, 2019 1:26 pm
... if your laptop tries to switch APs, your apps will lose connectivity to their respective endpoints and will have to reconnect.
Not necessarily. If the other AP has same SSID and is member of same L2 network, laptop keeps its IP address and connections don't break, there's only a short delay (few seconds) during AP switch.
But yes, usual WiFi mobility is "drop snd reconnect" type of "mobility" ... there are apps (but disappearing as it seems) which try to force wireless client to use 5G AP if available. I've seen such apps for windows laptops and android gadgets ... sadly not recently.
BR,
Metod
dnyl
Fri Oct 25, 2019 10:43 pm
Where is Normis? Where is MiroTik official answer to the problem? I think is a strange problem, what happens with every N chipset mikrotik device. Download can't better than 30 Mbps on every situation.
My problem is:
TP-LINK: 68,9/58,9Mbps
hAP lite / hAP mini: 31,6/76,9Mbps
Same location, same channel, same everything, but MT can't works well.
Users browsing this forum: RogerWilco and 30 guests
