loverboy
get active user hotspot by php api hlep me
Sun Jul 09, 2017 1:50 am
haloo evry body
i need show user and active users for hotspot
iam try by this code but not work
use PEAR2\Net\RouterOS;
require_once 'system/autoload/PEAR2/Autoload.php';
 $util = new RouterOS\Util($client = new RouterOS\Client('8.8.8.2', 'admin', ''));
 $printRequest = new RouterOS\Request('/ip/hotspot/active/print');
echo $printRequest
boen_robot
Re: get active user hotspot by php api hlep me
Sun Jul 09, 2017 3:50 am
Either the Request must be sent using Client, or you could use Util's methods. You have everything ready, just haven't actually asked the router.
Using Util f.e.
 $activeUsers = $util->setMenu('/ip/hotspot/active')->getAll();
 //Display the usernames of each active user
 foreach ($activeUsers as $user) {
 echo $user('name'), '\n';
loverboy
Sun Jul 09, 2017 9:18 am
Using Util f.e.
thank u for help me
this code is good but
user name not print
loverboy
Sun Jul 09, 2017 11:21 am
iam edit code
now it's work
but i cant get hotspot user
ineed get user limit-bytes-total
 echo $user('user');
 $userlimit = $util->setMenu('/ip/hotspot/user/')->getAll();
 foreach ($userlimit as $xxx){
 echo $xxx('limit-bytes-total');}
boen_robot
Sun Jul 09, 2017 6:56 pm
Oh, right... "user", not "name". I keep forgetting which menu has which property name... And yeah, I used single quotes when I should've used double (which would've created a few new lines in the output), sorry.
The "/ip hotspot user" menu is for all users (and that's where the property is called "name"), while "/ip hotspot active" is for all "active" (as in, "logged in") users. If you're trying to read data from there, that's the only menu you should be reading out of. The limit-bytes-out should be readable from there if you add the "stats" argument, i.e.
$activeUsers = $util->setMenu('/ip/hotspot/active')->getAll(array('stats'));
 //Display the username and limit-bytes-total of each active user
 echo $user('user') . ' - ' . $user('limit-bytes-total') . ";\n";
(or if that doesn't work, try to replace "stats" with "detail")
kvee
Wed May 10, 2023 1:17 pm
The /ip/hotspot/active is good but can retrieve all active hotspot users included duplicate users who online with more than one devices.
To find only active users without duplicated, use `:put [find active-sessions]`.
With Node package aluisiora/node-routeros, use
conn.write('/tool/user-manager/user/print', ['?active-sessions'])
Users browsing this forum: No registered users and 138 guests
