PMTech
Feature Request : Wireless Private Passphrase as a Match in Access-List
Fri Jul 14, 2017 9:31 am
Ultimately what we're trying to achieve is identifying users on a wireless SSID by the passphrase they use and then place them on their own VLAN. This is almost possible but not quite :
Currently the private passphrase in access-list for CAPsMAN is only used to check that the passphrase is correct once the other criteria in the access list has been validated. MAC address etc.
The request is to be able to have the passphrase as part of the matching criteria so that the below is possible :
normis
Re: Feature Request : Wireless Private Passphrase as a Match in Access-List
Fri Jul 14, 2017 2:42 pm
You can't do that, in Access List, each entry will have to be made separately for each MAC.
PMTech
Wed Jul 19, 2017 11:54 am
Thanks Normis,
I know, I'd like to submit it as a feature request.
PMTech
Fri Jul 21, 2017 6:38 pm
HI Normis,
Is this technically possible with the OS, is it even worth me submitting as a feature request ?
Mplsguy
Re: Feature Request : Wireless Private Passphrase as a Match in Access-List  [SOLVED]
Thu Aug 31, 2017 1:06 pm
AP does not "check" the passphrase, because client never sends it to AP. AP uses known passphrase in calculations and by means of those checks if client knows the same passphrase. Basically 802.11 PSK is an algorithm that allows both parties to confirm that other party (and this applies to both - AP and client) is using the same passphrase without sending it over the air. This is how protocol works, refer to 802.11 for details.
This means that it is practically* impossible for AP to e.g. send passphrase used by client to RADIUS and/or use it for matching access-list. Also note that access-list matching happens before key exchange that confirms passphrase - access-list can even provide this passphrase to use by means of private-passphrase after access-list rule is matched.
* - I say "practically" because theoretically AP could check info sent by client against every possible passphrase. This could be possible because AP is the first to check data sent by client if proper passphrase was used. Probably such feature could be implemented to some extent where AP could check against fixed set of passphrases and take one action or another, but unfortunately it is impossible to integrate it in current access-list (access-list checking is done before key exchange) or send passphrase to RADIUS server (passphrase is not known).
PMTech
Tue Sep 05, 2017 3:48 pm
Thanks, that explains it.
MtHoodlum
Sat May 11, 2019 8:52 am
This could be possible because AP is the first to check data sent by client if proper passphrase was used. Probably such feature could be implemented to some extent where AP could check against fixed set of passphrases and take one action or another.
I would like to be able to assign a VLAN based on the PSK used. This would be useful in hotel/apartment/condos where each unit has its own passphrase. It would for a single SSID (from every AP on the property) and allow for private Wi-Fi without using MAC addresses or RADIUS or landing pages.
coltonconor
Thu Jun 20, 2019 6:10 am
For clarification, other vendors are doing this today. Examples:
https://www.aerohive.com/technology/ppsk/
https://www.ruckuswireless.com/content/ ... d-key-dpsk
Does Mikrotik have any plans to implement this?
netwpl
Sat Oct 26, 2019 7:14 pm
my customers have exact the same need for this feature..!
have u solved it by a workaround so far? Radius /w VLAN assignment would be possible, but not every client is capable of 802.1x - neither captive portal.
pe1chl
Sat Oct 26, 2019 7:59 pm
You can do this standards-based when using WPA2-EAP. Almost every client supports it.
Zebble
Sat Oct 26, 2019 10:44 pm
This isn't the same as dynamic PSK. Not all devices support EAP, and DPSK is far simpler from a user perspective.
pe1chl
Sun Oct 27, 2019 1:00 am
You can always buy an AP that supports it!
You will never find all features in all possible devices at all price levels.
Zebble
Sun Oct 27, 2019 1:14 am
The problem isn't the AP (we're talking about Mikrotik - they all support EAP), it's the client devices. Not all support EAP, especially consumer devices. The example above of an apartment building is a relevant example where EAP would be ineffective.
UpRunTech
Sun Oct 27, 2019 1:41 am
Yes, devices like Chromecast and printers don't support EAP.
I too in the past have wished for password based VLAN assignment without using RADIUS. In the end I have done it using the hotspot, CAPSMAN and some script fu - as in hotspot logins get put on their own VLAN. It works very well considering there is no RADIUS involved. Using hotspot of course implies there is no Wifi encryption (until WPA3 comes along).
Users browsing this forum: No registered users and 121 guests
