stmx38
Long time Member
Long time Member
Dude v6 - Backup locally
Sun Jul 16, 2017 7:26 pm
Requirements
Dude v6 and above
Note: Please be aware, Dude is stopping during database export/import!
Configuration
1. Create a script.
System --> Scripts:
Policy: ftp, read, write, test
Source:
# Backup Dude locally
# Define variables
:local dudeconffilename "Dude_configuration_backup"
:local dudedbfilename "Dude_db_backup"
:local dudeconffileext "rsc"
:local dudedbfileext "db"
:local localbackuppath "disk1"
# Get date and time
:local curDate [/system clock get date]
:local curTime [/system clock get time]
:local systemName [/system identity get name]
:local curMonth [:pick $curDate 0 3]
 :set curMonth ( [ :find key="$curMonth" in="jan,feb,mar,apr,may,jun,jul,aug,sep,oct,nov,dec" from=-1 ] / 4 + 1)
 if ( $curMonth < 10 ) do={
  :set curMonth ( "0".$curMonth )
 } else={
  :set curMonth $curMonth
:local curDay   [:pick $curDate 4 6]
:local curYear  [:pick $curDate 7 13]
:local curHour  [:pick $curTime 0 2]
:local curMin   [:pick $curTime 3 5]
:local now ("$curYear"."$curMonth"."$curDay" ."-"."$curHour"."$curMin")
# Make Dude backup
:log warn message="Dude backup locally started";
/dude export file="$localbackuppath/$dudeconffilename_$now.$dudeconffileext"
/dude export-db backup-file="$localbackuppath/$dudedbfilename_$now.$dudedbfileext"
:log warn message="Dude backup locally finished";
2. Create a schedule.
System --> Scheduler:
Start Day: Nov/07/2017
Start Time: 02:00:00
Interval: 1d 00:00:00
On Event: dude-backup-locally
3. See the result
Files
Restore backup
In case of need, you can restore Dude v6 from recently created backup:
/dude set enabled=no
/import disk1/Dude_configuration_backup_20170716-0200.rsc
/dude import-db backup-file=disk1/Dude_db_backup_20170716-0200.db
/dude set enabled=yes
Used materials
1. Export to File - Filename Variable
2. Manual:The Dude v6/DB import export
Related solutions
1. Dude v6 - Backup to FTP
excession
Re: Dude v6 - Backup locally
Thu Aug 16, 2018 5:12 pm
This saved me a lot of time, thanks for sharing.
simogere
Wed Jan 04, 2023 1:11 am
Hi @stmx38, thanks for the tips.
A simple question:
Why the backup db is half the size of the original db?
stmx38
Long time Member
Long time Member
Thu Jan 05, 2023 6:37 am
Hello @simogere, I'm out of the topic now and can't reproduce and check it.
Can it be related to the DB vacuum effect?
Manual:The Dude v6/DB import export does not provide so much details.
If you have an assumption that you lose some data, probably it can be better to restore that backup on another device and check if all is in place.
Users browsing this forum: No registered users and 4 guests
