MUM Europe 2020
laxmimikrotik
why my mikrotik pppoe users are using encoding Deflate 15
Mon Jul 24, 2017 1:18 pm
when i am seeing the PPPoE active connections in my nas in that case why some of my PPPoE users are using encoding
as "Deflate 15"
Thanks.
Every problem Has Solution .
ip-noc Team.
MTCNA ,MTCRE,
abn
Re: why my mikrotik pppoe users are using encoding Deflate 15
Fri Oct 05, 2018 11:56 am
hello there,
I am also searching for this solution, but ill not get the answer from anyone then I start RND and got the solution this problem only happened the D-Link routers
  • login win box
  • go to ppp
  • profiles
  • set all profiles
  • profile/protocol
  • use compression default or yes
  • SET NO
U can also email to me if not working yunusmdkhan@gmail.com
Users browsing this forum: Bing [Bot] and 143 guests
