MUM Europe 2020
gtj
Re: v6.41rc [release candidate] is released! New bridge implementation!
Fri Sep 01, 2017 4:23 pm
I tried to upgrade a lab CRS-226-24P-2S+ from 6.40.1 to 6.41.rc18 and had major issues.
The switch is set up as a simple dumb switch, no vlans except the default and all ports switched. After the upgrade I had no IP connectivity to the switch and no connectivity through the switch. The switch was emitting LLDP since the upstream switch (also a CRS226 running 6.40.1) was showing it in the neighbors list but that's it. No mac-telnet either. Hooked up serial port and looked at the config. It "looked" correct (I have a supout which I'll send to support).
Now here's where the fun starts...
The switches are connected via SFP+ direct attach cables. After the upgrade, I lost connectivity to the UPSTREAM switch.
If I unplug the direct attach cable between the 2 switches, I get connectivity back to the upstream switch.
If I plug it back in again, I lose it. If I plug it in and change the bridge protocol on the upgraded switch to "none", I get connectivity back to the upstream switch but still no connectivity to the upgraded switch. After about an hour of playing with different settings, I decided to reset the config on the upgraded switch thinking that maybe the conversion process had an issue. No help.
Finally I did a reset with no default config and set the switch up manually by creating the bridge and adding the ports. YAY! It worked...
Except, I still have an SFP problem, but different. I no longer lose connectivity to the upstream switch but I still can't pass any traffic to the upgraded switch via that SFP port. With the 2 switches connected via ether1, no problem (I should have tried that earlier actually). Also, a Quanta 10G switch that's downstream from the upgraded switch is fine using the upgraded switch's SFP ports.
HMMM. As I'm typing this, I just heard the upgraded switch beep and sure enough, it's rebooting.
Anyway, I'm actually going to downgrade the switch back to 6.40.1 and retry the upgrade again to see if the connectivity issue was solely related to the SFP port or whether there was really a problem with the converted or default config.
JimmyNyholm
Fri Sep 01, 2017 5:08 pm
Unfortunately, currently SXT LTE does not support passthrough mode.
irghost - What is the question about SXT LTE? Are you referring to Passthrough support? if you do, then take a look at this list:
https://wiki.mikrotik.com/wiki/Supporte ... and_modems
Is there a plan for this or even and ETA? SXT LTE is the ultimate platform to get this feature.
w0lt
Fri Sep 01, 2017 5:34 pm
v6.41rc20 has some really cool stuff. I'm still having a problem with IGMP-Snooping where it drops an ACTIVE multicast group (after about 4-5 Min.). I'm not sure why it is doing this and to remedy it, I have to deactivate IGMP-Snooping and redeploy PIM (v6.40.2). I can't seem to find the ability to list the "Master Port" under Interface/Ethernet anymore. This might have been on purpose, just asking. I believe you folks are coming along nicely on IGMP-Snooping though it needs some tweaks (time will tell, right?). Would the ability to "Query" for IGMP Groups help in my case? Just spit-balling there.. :-)
Thanks,
-tp
Still having the same problem with v6.41 rc21
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
irghost
Fri Sep 01, 2017 6:01 pm
+1 For SXT LTE
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
strods
Mon Sep 04, 2017 2:45 pm
What's new in 6.41rc23 (2017-Sep-04 09:07):
Important note!!! Backup before upgrade!
RouterOS (v6.40rc36-rc40 and) v6.41rc1+ contains new bridge implementation that supports hardware offloading (hw-offload).
This update will convert all interface "master-port" configuration into new bridge configuration, and eliminate "master-port" option as such.
Bridge will handle all Layer2 forwarding and the use of switch-chip (hw-offload) will be automatically turned on based on appropriate conditions.
The rest of RouterOS Switch specific configuration remains untouched in usual menus for now.
Please, note that downgrading to previous RouterOS versions will not restore "master-port" configuration, so use backups to restore configuration on downgrade.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
Changes since previous 6.41rc release:
*) address - show warning on IPv6 address when acquire from pool has failed;
*) bridge - fixed connectivity issues when there are multiple VLAN interfaces on bridge;
*) bridge - show bridge interface local addresses in the host table;
*) crs317 - added initial support for HW offloaded MPLS forwarding;
*) dhcp - fixed DHCP services failing after reboot when DHCP option was used;
*) dhcpv4-client - allow to use DUID for client ID;
*) dhcpv6-client - require pool name to be unique;
*) routerboard - fixed "/system routerboard upgrade" for CRS212-8G-4S;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
TmH
Mon Sep 04, 2017 9:26 pm
I gave the new rc a go because of the multiple VLAN option, however after upgrading from the previous rc21 now the link is not stable anymore.
Every few minutes the link goes down and comes up again (from the mikrotik log).
Other than the new rc no changes were made to hardware [mikrotik hAP ac, RB962UiGS-5HacT2HnT] or settings. (same config etc)
Config used is blank, one bridge using all ports no vlans configured, dhcp-client on bridge interface, no firewall rules
nz_monkey
Tue Sep 05, 2017 3:53 pm
DANGER
If you are running CAPSMAN avoid 6.41rc23
6.41rc23 breaks CAP communication with CAPSMAN, at least when using a tunelled datapath. Downgrading to 6.41rc20 does not fix the problem :(
Mikrotik support are aware of this issue.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
anuser
Tue Sep 05, 2017 5:01 pm
DANGER
Too late. My users complain that they are connected to the wifi, but there´s hardly any or only few traffic is getting through the connection.
idlemind
Tue Sep 05, 2017 6:05 pm
You can download prior versions of the RC by manually adjusting the URL from the download page if you wanted to revert back to an RC that it still works at for you to retain the new bridge.
uldis
Tue Sep 05, 2017 6:07 pm
DANGER
How are you connecting the CAP to the CAPsMAN? Are you using Local-forwarding or CAPsMAN forwarding? Are you using VLAN in our setup?
uldis
Tue Sep 05, 2017 6:09 pm
There is bug that after the downgrade from the newest RC you need to do a soft reboot of the board as the dhcp-client doesn't start in the first boot. Powercycle will not help, you need to do a sift reboot.
stucki
Tue Sep 05, 2017 7:44 pm
How many troubles will come with V8?
nz_monkey
Tue Sep 05, 2017 10:54 pm
Hi Uldis, it is Layer3 with CAPsMAN forwarding.
Even downgrading to the previously working 6.41rc20 through Package/Downgrade, the problem still remains :(
anuser
Wed Sep 06, 2017 7:57 am
Well, it doesn't matter what older version I used. I downgraded and then "telnet-mac" into the access point to add an dhcp-client interface which took ~ 30 seconds to be added. After a reboot the access points worked again (I went back to 6.40.3).
uldis
Wed Sep 06, 2017 9:31 am
nz_monkey, are you using VLAN interfaces and Bridge interfaces as in v6.41RC versions there are lot of changes to the Bridge implementation that could cause some problem.
hzdrus
Wed Sep 06, 2017 11:06 am
Can you elaborate on this feature? It applies solely when acting as a transit P router or when encapsulating/decapsulating l2circuit also?
P.S. Congrats on the work to implement multicast snooping. Looking forward to a stable release.
mrz
Wed Sep 06, 2017 2:53 pm
@hzdrus currently only as a P router.
strods
Fri Sep 08, 2017 9:42 am
What's new in 6.41rc26 (2017-Sep-07 13:26):
Before an upgrade:
!) bridge - general development of hw-offload bridge implementation (introduced in v6.40rc36);
*) chr - added KVM memory balloon support;
*) chr - added suspend support;
*) crs1xx/2xx - fixed 1 Gbps forced mode for several SFP modules;
*) dhcp - fixed unresponsive DHCP service caused by inability to read not set RAW options;
*) e-mail - auto complete file name on "file" parameter (introduced in v6.40);
*) eoip - made L2MTU parameter read-only;
*) hotspot - fixed missing "/ip hotspot server profile" if invalid "dns-name" was specified;
*) lte - added Passthrough support (CLI only);
*) lte - added support for ZTE ME3630 E1C;
*) lte - fixed mode initialization after reboot;
*) ppp - fixed missing PPP client interface after reboot (introduced in v6.41rc);
*) rb931-2nd - fixed startup problems (requires additional reboot after upgrade);
*) userman - fixed unresponsive RADIUS server (introduced in v6.40.3);
*) webfig - improved reliability of login process;
irghost
Fri Sep 08, 2017 11:39 am
Before an upgrade:
is there any news about SXT LTE?
HasanAlawlaki
Fri Sep 08, 2017 2:40 pm
In this vertion ..!
What about netcut and ip scanner for who using hotspot and not managed switch with ubnt AP's ?
normis
Fri Sep 08, 2017 2:56 pm
Your question was already answered!
Sorry, I don't understand, what are you talking about?
HasanAlawlaki
Fri Sep 08, 2017 4:05 pm
Sorry i mean
The netcut program and another ip scanner can we control and block them by this new bridge features ?
irghost
Fri Sep 08, 2017 4:29 pm
Does SXT LTE Support passthrough in this version?
the answer is "NO"
Jotne
Sat Sep 09, 2017 7:05 pm
Could you please add Address List to the Queue module.
In firewall you can use Address List to make more flexible rules.
In Queue and Simple Queue you can only use IP or range of IP.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
diasem
Sat Sep 09, 2017 8:49 pm
Strods Please include dns resolution on interface torch.
cXXcoder
Mon Sep 11, 2017 5:37 am
What's new in 6.41rc6 (2017-Aug-01 11:30):
*) ppp - added support for Sierra MC7750, Verizon USB730L;
For the Verizon USB730L / Novatel Global Mode USB730L, would it work if plugged into USB slot of the RB750UPr2? If not, which MikroTik routers compatible? And if yes, please point me to the relevant chapters/sections of documentation, or tutorials?
Please forgive my ignorance: I do software, not networks. :-(
Thank you!
JimmyNyholm
Mon Sep 11, 2017 4:15 pm
Normis could you Elaborate.
Your answer and Wiki is ambiguous:
Saying It's not supported and it can not be done due to hardware limitations.
OR
It is currently not supported, it can be done but we have not yet made a decision If or When?.
Yours J
strods
Mon Sep 11, 2017 4:18 pm
Passthrough is not currently supported on SXT LTE and we do not have plans to implement such functionality in near future.
idlemind
Mon Sep 11, 2017 4:46 pm
strods, breaking hearts on a Monday. Love it.
Siona
Re: RE: Re: v6.41rc [release candidate] is released! New bridge implementation!
Mon Sep 11, 2017 5:00 pm
Why? It would be really nice to have this functionality...
strods
Tue Sep 12, 2017 2:24 pm
What's new in 6.41rc28 (2017-Sep-11 12:37):
Before an upgrade:
*) console - do not stop "/certificate sign" process if console times out in 1 minute;
*) crs317 - added L2MTU support;
*) crs3xx - added port ingress and egress rate limiting;
*) log - added "bridge" topic;
JimmyNyholm
Tue Sep 12, 2017 3:01 pm
Thanks for the elaboration.
Looking at the SXT LTE device it is the perfect fit for this function. We will buy many more of these units when this is available.
JimmyNyholm
Wed Sep 13, 2017 1:51 pm
Got my first Batch of CRS317-1G-16S+ 's unpacking the first and trying out this test version.
Connected Copper (1g) and startet winbox clearing conf. Looking around and tried to change l2mtu.
/interface ethernet set l2mtu=10000 numbers=1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Boom ether1 stoped working (interface nr 0) the switch rebooted and didn't let me in again over winbox.
serialport connect reset conf and back in buissnesss.
I did notice that ether1 is connected to the same switch chip (swtich1) and perhaps this is the wrong way to change mtu. But at the same if I want 10K frames on the sfpports and no switch connectivity to the ether1 how is this accomplished with the new implementation. is there a manual for this new implementation or some pointers to get our heads round to test it properly..
strods
Wed Sep 13, 2017 2:06 pm
JimmyNyholm - Did this happen when you used 6.41rc28?
JimmyNyholm
Fri Sep 15, 2017 11:24 am
Yes!
admin@MikroTik] > system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-arm 6.41rc28
1 system 6.41rc28
2 X ipv6 6.41rc28
3 X wireless 6.41rc28
4 X hotspot 6.41rc28
5 X dhcp 6.41rc28
6 mpls 6.41rc28
7 routing 6.41rc28
8 X ppp 6.41rc28
9 security 6.41rc28
10 advanced-tools 6.41rc28
[admin@MikroTik] >
JimmyNyholm
Fri Sep 15, 2017 2:47 pm
Is this gona be not bridged intefaces can hardware switch depending on label but ldp is running on ip so one would have to configure ip adresses and a routing protocol say ospf to get routes that would be hardware switched on labels without cpu. the cpu would only run routing protocol and ldp and the hardware chip would switch/route incoming mpls packes according to ldp. being a router no l2 domain but doing it true switching on ldp labels... Like the big guys....
Is this Initial something that works now in cli or is it the first door and something to be enabled later in the rc branch.
strods
Mon Sep 18, 2017 12:02 pm
What's new in 6.41rc30 (2017-Sep-15 11:50):
Before an upgrade:
*) crs326 - fixed packet processing speed on switch chip if individual port link speed differs;
*) export - fixed wireless "ssid" and "supplicant-identity" compact export;
*) ppp - fixed situation when part of PPP configuration was reset to default values after reboot;
*) wireless - added "allow-signal-out-of-range" option for Access List entries (CLI only);
Chupaka
Mon Sep 18, 2017 12:12 pm
added "allow-signal-out-off-range" option
should be 'out of range' or 'off-range', but not both, I think :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
strods
Mon Sep 18, 2017 12:39 pm
Chupaka - Thanks! Fixed the typo in changelog.
Chupaka
Mon Sep 18, 2017 1:01 pm
Any use cases for this option?
bajodel
Long time Member
Long time Member
Mon Sep 18, 2017 4:12 pm
Just tested CRS326-24G-2S+ on 6.41rc30
- started from clean config (reset w/o default)
- simple config: all port in a bridge, RSTP active
- ip dhcp client on bridge interface
- set identity and users
Reboot >> device dead
Via console I see the device is booting correctly >> startup services >> login (and after 1 sec) >> System rebooting (but the board stuck there w/o rebooting).
Note: the ether1 was the only cable plugged in and the led was off.
I was not able to create a supout (too fast in locking down); netinstall to 6.40.3 and we are in business again
strods
Mon Sep 18, 2017 4:37 pm
bajodel - Can you please send to support@mikrotik,.com precise commands which you execute to reproduce this problem? We added all ports into bridge, added DHCP client on bridge, rebooted device and it is working just fine.
bajodel
Long time Member
Long time Member
Mon Sep 18, 2017 5:27 pm
Sure, as soon as possible I'll try to redo the same setup.
Now I remember that I also changed default MACs on etherXX interfaces and set admin-MAC on bridge one.
uldis
Mon Sep 18, 2017 5:44 pm
Here is the discussion about that option:
viewtopic.php?f=7&t=124884
idlemind
Mon Sep 18, 2017 6:12 pm
Interesting how fast some options appear compared to others, cough useful IPv6 changes.
Yes, I'm heckling you because well it's apparently needed.
Side-note: It seems the pace is slowing on this RC. I imagine this means we'll be seeing 6.41rc moving to GA and 6.42 started? Will we see a general theme targeted in this next cycle like we say with the new bridge implementation?
juliokato
Mon Sep 18, 2017 6:36 pm
Good observation!
I am waiting until today for a simple reset counter:
viewtopic.php?f=1&t=108552&p=614961&hil ... er#p614961
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
bajodel
Long time Member
Long time Member
Mon Sep 18, 2017 7:11 pm
Board: CRS326-24G-2S+
1) netinstalled 6.40.3
2) upgraded to 6.41rc30
3) reset w/o default
4) create bridge and put all port into it
5) change all Ethernet MACs (sample below)
set [ find default-name=ether1 ] mac-address=CC:4E:24:00:EE:01
set [ find default-name=ether2 ] mac-address=CC:4E:24:00:EE:02
set [ find default-name=ether3 ] mac-address=CC:4E:24:00:EE:03
set [ find default-name=ether4 ] mac-address=CC:4E:24:00:EE:04
set [ find default-name=ether5 ] mac-address=CC:4E:24:00:EE:05
set [ find default-name=ether6 ] mac-address=CC:4E:24:00:EE:06
set [ find default-name=ether7 ] mac-address=CC:4E:24:00:EE:07
set [ find default-name=ether8 ] mac-address=CC:4E:24:00:EE:08
set [ find default-name=ether9 ] mac-address=CC:4E:24:00:EE:09
set [ find default-name=ether10 ] mac-address=CC:4E:24:00:EE:10
set [ find default-name=ether11 ] mac-address=CC:4E:24:00:EE:11
set [ find default-name=ether12 ] mac-address=CC:4E:24:00:EE:12
set [ find default-name=ether13 ] mac-address=CC:4E:24:00:EE:13
set [ find default-name=ether14 ] mac-address=CC:4E:24:00:EE:14
set [ find default-name=ether15 ] mac-address=CC:4E:24:00:EE:15
set [ find default-name=ether16 ] mac-address=CC:4E:24:00:EE:16
set [ find default-name=ether17 ] mac-address=CC:4E:24:00:EE:17
set [ find default-name=ether18 ] mac-address=CC:4E:24:00:EE:18
set [ find default-name=ether19 ] mac-address=CC:4E:24:00:EE:19
set [ find default-name=ether20 ] mac-address=CC:4E:24:00:EE:20
set [ find default-name=ether21 ] mac-address=CC:4E:24:00:EE:21
set [ find default-name=ether22 ] mac-address=CC:4E:24:00:EE:22
set [ find default-name=ether23 ] mac-address=CC:4E:24:00:EE:23
set [ find default-name=ether24 ] mac-address=CC:4E:24:00:EE:24
set [ find default-name=sfp-sfpplus1 ] mac-address=CC:4E:24:00:EE:25
set [ find default-name=sfp-sfpplus2 ] mac-address=CC:4E:24:00:EE:26
>> Reboot
On console you'll see..
BootROM 1.41
Booting from SPI flash
BootROM: Image checksum verification PASSED
RouterBOOT booter 3.41
CRS326-24G-2S+
CPU frequency: 800 MHz
  Memory size: 512 MiB
 Storage size:  16 MiB
Press <delete> key within 4 seconds to enter setup....
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
Rebooting...
Stopping services...
The board is stuck (not really rebooting); unplugging power cable you start again as above.
Chupaka
Tue Sep 19, 2017 10:17 am
so, now it's available in 6.41rc? :)
strods
Tue Sep 19, 2017 10:39 am
Chupaka, juliokato - Yes, it is:
*) interface - added "/interface reset-counters" command (CLI only);
juliokato
Tue Sep 19, 2017 4:01 pm
OK thanks, I'll test if it works I do not need to wait for V.7 .....
I'll just wait for the stable version.
idlemind
Tue Sep 19, 2017 5:11 pm
Weak. Be brave!
juliokato
Tue Sep 19, 2017 5:26 pm
I can't, I have over 400 RB with USB LTE MODEM in production and the RC version has STP bridge bugs. While it is not stable I can wait another year :lol:
JimmyNyholm
Tue Sep 19, 2017 7:11 pm
Just to be on the safe side. Running CRS317-1G-16+ On the 6.41rc30 looking in switch menu there is no ports and no switch is that correct?
The New implementation is doing "switchy stuff" in bridge section but should I make switch settings in switch section and does that work when Ros doesn't find any chip or ports in this menu.
Where does the Dynamic Vlan of 3501 come from?
This bridge1 port is this the routeros entry point? (ie: if I add Ip adtress or vlan interface in interface section?)
bridge1 doesn't need to be in a vlan for that vlan to forward frames to the member ports?.
Why do I ask this silly questions... because I'm experiencing strange behaviour. And the Wiki is utterly outdated on this developing area and there is no other source for this kind of information.
idlemind
Tue Sep 19, 2017 8:47 pm
Wiki has been updated. The links are in the thread. I think it's under interface bridge.
You are correct. The switch menu is a thing of the past. It is all done via the new HW offload VLAN aware bridge.
This provides a single consistent way to use RouterOS and it manages leveraging underlying hardware dynamically. This is visible by the H flag in interface bridge port.
Now let's go to school. A VLAN is a layer 2 technology like a switch. Therefore a VLAN interface is not required for a bridge to forward a frame. The switch simply has to know which ports are a member of that VLAN and whether it should traffic tagged or untagged on that port.
A VLAN interface is a way to perform routing for traffic on a VLAN in RouterOS.
A VLAN interface should have it's master interface set to the bridge interface.
The bridges VLAN and port tables are where you manage which ports transmit tagged and untagged frames on which ports. A dynamic entry is sourced from an entry in one table that's not present in another. This could be seen by placing a bridge ports PVID in a VLAN not present in the VLAN table. A dynamic entry is created in the VLAN table to express that.
Chupaka
Wed Sep 20, 2017 9:06 am
By the way, maybe it's possible to add an action (probably to Bridge DST-NAT - it's suitable, according to Packet Flow diagram) to set/unset VLAN tag on the packet (to do kind of MAC-based/protocol-based VLAN)?
mszru
Wed Sep 20, 2017 10:44 am
...bridge1 doesn't need to be in a vlan for that vlan to forward frames to the member ports?.
It didn't work for me until I added the bridge1 itself to the tagged ports list.
I have temporarily setup hAP lite (RB941-2nD) as a VLAN aware switch which forwards both untagged and tagged (vlan=100) frames. I didn't do anything in the "Switch" menu. The configuration was done in the "Bridge" menu only:
1) Added ether1, ether2, ether3 and ether4 as member ports for bridge1 in "Bridge" -> "Ports" and for each member port I set pvid=1 and frame-types=admit-all
add interface=ether1 bridge=bridge1 pvid=1 frame-types=admit-all hw=yes
add interface=ether2 bridge=bridge1 pvid=1 frame-types=admit-all hw=yes
add interface=ether3 bridge=bridge1 pvid=1 frame-types=admit-all hw=yes
add interface=ether4 bridge=bridge1 pvid=1 frame-types=admit-all hw=yes
2) In the "Bridge" -> "VLANs" made all members ports aware of vlan 100 tagged frames (including bridge1 itself).
interface bridge vlan add bridge=bridge1 vlan-ids=100 tagged=bridge1,ether1,ether2,ether3,ether4 untagged=""
3) Enabled VLAN Filtering for bridge1 in the "Bridge" -> "Bridge" menu.
interface bridge set bridge1 vlan-filtering=yes pvid=1
4) [optional] Added vlan100 interface to the bridge1 to be able to manage the router from that VLAN.
strods
Wed Sep 20, 2017 4:42 pm
What's new in 6.41rc31 (2017-Sep-20 06:56):
Before an upgrade:
*) lte - added "/interface lte apn" menu (Passthrough requires reconfiguration) (CLI only);
*) lte - added support for ZTE ME3630 E1C with additional "/port" for GPS usage;
*) lte - automatically add "/ip dhcp-client" configuration on interface;
*) lte - changed default values to "add-default-route=yes", "use-peer-dns=yes" and "default-route-distance=2";
*) ppp - fixed serial port loading (introduced in v6.41rc);
*) sfp - fixed temperature readings for various SFP modules;
*) snmp - fixed "/system license" parameters for CHR;
*) wireless - improved reliability on "rx-rate" selection process;
cheeze
Thu Sep 21, 2017 12:27 am
Before an upgrade:
strods, are we looking feature complete for 6.41 yet? I'm just curious if it's down to polishing and bug fixes or if there's more that's intending to be added.
I know I'm not the only one very eager for it.
biatche
Thu Sep 21, 2017 12:58 am
one thing that i've never understood about mikrotik is why they add new features to RC.there should be testing or beta channel, rc channel (feature locked), stable(bugfix), mainline(current)
this would make far more sense
pcunite
Thu Sep 21, 2017 2:24 am
One thing that I've never understood about MikroTik is why they add new features to the RC. There should be testing or beta channel, rc channel (feature locked), stable(bugfix), and mainline(current).
Which is why I won't touch updates with a 10 foot pole.
idlemind
Thu Sep 21, 2017 6:53 am
Mmmmm hacker bait. :)
andriys
Thu Sep 21, 2017 9:52 am
This is just a naming convention, you just have to get used to it.
In any case, please do NOT pollute this thread with the naming convention nonsense again. If you feel like you are in absolutely need to discuss, here is one of the many threads to reply to: viewtopic.php?f=2&t=123032.
biatche
Thu Sep 21, 2017 10:37 am
to you its a naming convention, but the rc are often very "alpha status", and rc can be misleading to new users who by norm perceive that rc's are "generally stable". why do you think cheeze asked if its down to polishing and bugfixes? its because rc naming convention makes it confusing for some users. no one would have to question if rc actually meant rc, alpha meant alpha, beta meant beta, and then we won't be having this discussion.
and thanks to polluted nonsense or not, we finally received MSTP after so many years, have you forgotten, mr forum police?
bajodel
Long time Member
Long time Member
Thu Sep 21, 2017 10:47 am
Just updated a CRS125 test unit to 6.41rc31 (from 6.40.3); firmware upgrade and master-port-TO-new-bridge config auto-conversion went smoothly.
NOTE: CRS125 config has custom MAC addresses set for all interfaces and this has not compromised upgrade/conversion, on CRS326 instead custom MAC addresses can be set but IMHO the device hang at first reboot (pay attention).
normis
Thu Sep 21, 2017 10:59 am
We are aware of this, but in RouterOS world, "stable" is the only version you should use in important locations where you don't want new features. We update this branch rarely and only after long and rigorous testing. Current is more like RC (current = running release), and RC is more like Beta or "nightly build" in Windows land.
willglynn
Fri Sep 22, 2017 4:37 am
The previous switch settings supported MAC learning limits:
set ether6 learn-limit=1
set ether7 learn-limit=1
Is this feature still available with the new bridge implementation?
JimmyNyholm
Fri Sep 22, 2017 12:36 pm
Not as faar as I can se for the moment..
And while we speak of it would it be Possible to add this to the new implementation and possibly enhance it with ie: learn-limit=1 learn-clear-at-interface-down=no learn-replace-after-inactivity=15min
and or even cooler lear-radius-auth=yes (with all the magic options as answer properties in the radius answer
strods
Fri Sep 22, 2017 2:24 pm
What's new in 6.41rc32 (2017-Sep-21 13:51):
Before an upgrade:
*) bridge - added initial support for hardware "igmp-snooping" on CRS1xx/2xx;
*) bridge - implemented software based "igmp-snooping";
*) traceroute - improved "/tool traceroute" results processing;
*) wireless - log "signal-strength" when successfully connected to AP;
dschn
Fri Sep 22, 2017 5:10 pm
With v6.41rc31 my LTE connection was very slow, max. 7-10mbit/s and high pings >200ms. Also the E3372 LTE modem (still) loses connection when downloading larger amounts of data (via Steam for example) so you have to reboot the RB.
uldis
Fri Sep 22, 2017 5:12 pm
What version you had before on your router where it was working ok?
pcunite
Fri Sep 22, 2017 5:52 pm
/interface ethernet switch port set ether6 learn-limit=1
While we are speaking about this, could we enhance it with ie: learn-limit=1 learn-clear-at-interface-down=no learn-replace-after-inactivity=15min
and or even cooler lear-radius-auth=yes (with all the magic options as answer properties in the radius answer?
Yes, please. Cisco calls a learned MAC on reboot sticky (I think). Replace after a timeout is good too.
w0lt
Fri Sep 22, 2017 6:30 pm
Is it possible to get a better explanation or detail on the software based "igmp-snooping" ?
MTCNA - 2011
idlemind
Fri Sep 22, 2017 10:17 pm
The bridge will perform IGMP snooping in a way that requires the CPU to process to packets instead of customized and often accelerated (faster) hardware that is meant to do it at line-rate or near line-rate.
w0lt
Sat Sep 23, 2017 2:44 am
Probably should of phrased the question better... How to "correctly" configure software based IGMP-Snooping . :D
-tp
MTCNA - 2011
honzam
Sat Sep 23, 2017 12:32 pm
Very useful feature. Thank you. It could be possible to add the last signal when the state is disconnected?
LAN, FTTx, Wireless. ISP operator
Paternot
Long time Member
Long time Member
Sat Sep 23, 2017 3:40 pm
Excelent idea!
pcunite
Sat Sep 23, 2017 4:48 pm
Very useful feature. Thank you. Would it be possible to add the last signal when the state was disconnected?
That might be extremely useful, if the data correlates to client's disconnecting around full power. We could point blame at something other than coverage.
Chupaka
Mon Sep 25, 2017 10:47 am
interface bridge set bla-bla igmp-snooping=yes
This entry in changelog just means that there were some improvements in already implemented snooping.
dschn
Mon Sep 25, 2017 11:24 am
I reverted back to 6.40.3 where speeds are normal, but that version too has the problem that the E3372 is unstable an looses LTE connection when there is some load. I hoped the latest RC would fix this...
uldis
Mon Sep 25, 2017 12:06 pm
Please contact support@mikrotik.com for more information (include the modem number and revision). Also check what lte band it uses when you have normal speed and when you have slow speed.
Ulypka
Mon Sep 25, 2017 2:11 pm
have you planned add HW offload with vlan-filtering function?
biatche
Mon Sep 25, 2017 6:17 pm
careful now, forum police andyris might warn you to post in feature request thread.
eworm
Mon Sep 25, 2017 6:20 pm
I am having issues with CAPsMAN on 6.41rc13... Looks like cap interfaces with CAPsMAN forwarding do not pass any traffic.
The issue persists with 6.41rc16... Just downgraded to 6.41rc11 and wireless is up and running.
Updated to 6.41rc32 and everything works as expected. I can not tell what intermediate version fixed the issue though.
Thanks Uldis!
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Ulypka
Mon Sep 25, 2017 7:11 pm
this is not a feature request, it's a question
will return the functionality that was lost in the new version.
ZeroByte
Wed Sep 27, 2017 12:23 am
I just put 6.41rc32 onto an RB2011UAS-2HnD and have a question.
The pre-upgrade configuration was with a bridge name=LAN with ports=ether2 and ether6, with those set as masters in the switch menu to ports ether3-5 and ether7-9 respectively.
ether1, ether10, and sfp1 were all stand-alone interfaces.
Long story short: after the upgrade, the bridge ports menu still only lists ether2 and ether6 as ports of the LAN bridge, but I am still able to reach the router from ether3 as if it were a member of the bridge. The bridge > hosts displays my laptop's MAC address on ether3 (correctly) but I can't see anything that would tell me ether3 should be bridged with ether2.
Am I missing something obvious that would show me ether3 as a member of the LAN bridge? (or as a member of some other hardware-accelerated bridge?)
When given a spoon,
you should not cling to your fork.
The soup will get cold.
skuykend
Wed Sep 27, 2017 3:54 am
I had a similar issue with a 951G. First boot with upgrade, was still able to connect from port 5. Rebooted one more time and lost connection until I switched to port 2.
Maybe the initial config needs one more reboot or switch reset to behave as expected.
rapidsky
Wed Sep 27, 2017 7:55 am
On the CRS326 running 6.41rc32 and firmware 3.41, adding some ports to bridge2 disables their hardware offload. This is Is this expected?
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                                BRIDGE                               HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ether1                                   bridge1                              yes    1     0x80         10                 10       none
 1 I H ether2                                   bridge1                              yes    1     0x80         10                 10       none
 2 I H ether3                                   bridge1                              yes    1     0x80         10                 10       none
 3 I H ether4                                   bridge1                              yes    1     0x80         10                 10       none
 4 I H ether5                                   bridge1                              yes    1     0x80         10                 10       none
 5 I H ether6                                   bridge1                              yes    1     0x80         10                 10       none
 6 I H ether7                                   bridge1                              yes    1     0x80         10                 10       none
 7 I H ether8                                   bridge1                              yes    1     0x80         10                 10       none
 8 I H ether9                                   bridge1                              yes    1     0x80         10                 10       none
 9 I H ether10                                  bridge1                              yes    1     0x80         10                 10       none
10 I H ether11                                  bridge1                              yes    1     0x80         10                 10       none
11 I H ether12                                  bridge1                              yes    1     0x80         10                 10       none
12 I H ether13                                  bridge1                              yes    1     0x80         10                 10       none
13 I H ether14                                  bridge1                              yes    1     0x80         10                 10       none
14 I H ether15                                  bridge1                              yes    1     0x80         10                 10       none
15 I H ether16                                  bridge1                              yes    1     0x80         10                 10       none
16 I H sfp-sfpplus1                             bridge1                              yes    1     0x80         10                 10       none
17 I   ether17                                  bridge2                              yes    1     0x80         10                 10       none
18 I   ether18                                  bridge2                              yes    1     0x80         10                 10       none
19 I   ether19                                  bridge2                              yes    1     0x80         10                 10       none
20 I   ether20                                  bridge2                              yes    1     0x80         10                 10       none
21 I   ether21                                  bridge2                              yes    1     0x80         10                 10       none
22 I   ether22                                  bridge2                              yes    1     0x80         10                 10       none
23 I   ether23                                  bridge2                              yes    1     0x80         10                 10       none
24 I   ether24                                  bridge2                              yes    1     0x80         10                 10       none
25 I   sfp-sfpplus2                             bridge2                              yes    1     0x80         10                 10       none
Jotne
Wed Sep 27, 2017 9:03 am
Not sure if this is related to RC build or its a general problem for MikroTik
I have a RB941-2nD for testing. Upgraded to latest RC and its running fine.
Then I see that there are new firmware available. So I click the upgrade button.
RB tells me "Do you really want to upgrade the firmware?"
I click yes, and nothing more happens.
Firmware is still the same, no changes anywhere.
So I did go to Terminal and did try the same.
There I got this message: 07:56:59 echo: system,info,critical Firmware upgraded successfully, please reboot for changes to take effect!
Ahh, Its need a reboot!!
1. Remove the really, its telling me "are you really so stupid that you like to upgrade?", change to "Do you want to upgrade firmware"
2. Add information that reboot is needed after the web upgrade.
MikroTik->Splunk
floeff
Wed Sep 27, 2017 11:40 am
I might have hit a bug wrt. the bridge conversion.
hAP lite, RouterBOOT 3.41, RouterOS 6.40.
Device completely resetted, export only showed configuration of ether interfaces, nothing else (as intended).
ether1 not configured further, ether2 not configured further. ether3-4 configured with ether2 as master port.
My understanding is that the update to 6.41rc should create a HW offload bridge with ether2-5 in
It did create the bridge with a comment that this was created due to the upgrade, but that bridge contained no port at all.
Trivial to fix, but IMHO not as expected?
strods
Wed Sep 27, 2017 2:33 pm
What's new in 6.41rc34 (2017-Sep-27 10:05):
Before an upgrade:
*) crs3xx - improved packet processing in slowpath;
*) defconf - fixed RouterOS default configuration (introduced in v6.40.3);
*) ethernet - removed "master-port" parameter;
*) log - fixed "unknown" interface name in log messages;
*) lte - do not reset modem when it is not possible to access SMS storage;
*) snmp - fixed "ifHighSpeed" value of VLAN, VRRP and Bonding interfaces;
*) snmp - fixed "/caps-man registration-table" uptime values;
*) tile - improved hardware encryption processes;
*) vlan - do not allow VLAN MTU to be higher than L2MTU;
*) wireless - fixed rate selection process when "rate-set=configured" and NV2 protocol is used;
bajodel
Long time Member
Long time Member
Wed Sep 27, 2017 8:14 pm
Previous ROS: 6.41rc32
Status: quite stable, all port in bridge w/ RSTP enabled and 2 active link to CRS125 (active/alternate)
Upgraded to 6.41rc34, every 3-5 minutes my laptop (direct patch cord to a CRS326 port) detects lost link; on a separate windows I've constant ping to my firewall and I can see ping fail (General Error = link down / no laptop eth conn). After some seconds link is back and ping go normal.
On 6.41rc32 (tested in the last 3 days) I've not seen any similar behaviour (and I've made no topology changes).
Now I've disabled RSTP (and removed redundant link to CRS125) and it'seems to be stable again (consider it's only 30 minutes now I'm testing this).
Even if these are lab equipments, I'm considering going back to 6.40.3 and stay there for some weeks ..probably this switch_2_bridge conversion is something which needs time to consolidate.
Some days ago I've netinstalled 2 time the CRS326 because it doesn't like MAC changes.
bajodel
Long time Member
Long time Member
Thu Sep 28, 2017 1:03 am
(see previous post) Confirmed.. after some hours, disablig RSTP it's now stable.
bajodel
Long time Member
Long time Member
Thu Sep 28, 2017 3:12 am
I've noticed one more thing (CRS326 - 6.41rc34 - RSTP now enabled):
>> keeping winbox logged to CRS326 the problem does not show up
>> closing winbox .. flapping starts
fanMikroTik
Sat Sep 30, 2017 10:07 am
Hw. Offload
After reboot I have this in log...
hardware offloading activated on bridge "bridge1" ports: wlan1,ether2
hardware offloading activated on bridge "bridge1" ports: wlan1,ether3
But port wlan1 status is inactive and not Hw. Offload... Is is correct?
0 XI ether1 bridge1 yes 1 0x80 10 10 none
1 H ether2 bridge1 yes 1 0x80 10 10 none
2 H ether3 bridge1 yes 1 0x80 10 10 none
3 XI ether4 bridge1 yes 1 0x80 10 10 none
4 wlan1 bridge1 yes 1 0x80 10 10 none
JimmyNyholm
Sat Sep 30, 2017 8:33 pm
Hw. Offload
Not stating your board but from what I can tell wlan1 is a wlan interface right? this interface maybe is not connected in hardware to the same switch chip. Hence it's not hardware enabled. Look att the Block diagrams of your unit an you will se how it's built.
fanMikroTik
Sat Sep 30, 2017 9:09 pm
I think You are right (RB951Ui-2HnD), but I don't understand the log message including wlan1 port...
idlemind
Sat Sep 30, 2017 10:53 pm
MikroTik can correct me on Monday but that's probably referring to the bridge level hardware offload feature or the port hw=yes setting. You can set it to yes regardless of it being a wlan or Ethernet interface.
teleweb
Mon Oct 02, 2017 3:56 am
Hi, we have a question about the new bridge / hw offloading implementation in CRS 317-1G-16S+
I have created 2 bridges: most ports added to bridge1, two ports added to bridge2.
Now I only see the H (or "Hw offload" checked) with the ports of bridge1.
Can you only have one bridge making use of hw offloading?
We have enabled "Fast forward" at the bridge level, and "Hardware offload" at the port level.
Thanks!
strods
Mon Oct 02, 2017 11:23 am
What's new in 6.41rc37 (2017-Oct-02 06:47):
Before an upgrade:
*) bridge - initial support for "/interface list" as a bridge port (CLI only);
*) fetch - accept all HTTP 2xx status codes;
*) ike2 - fixed initiator DDoS cookie processing;
*) ike2 - fixed responder DDoS cookie first notify type check;
*) lte - fixed modem initialization after reboot;
*) ntp-client - properly start NTP client after reboot if manual server IP is not configured;
*) sfp - fixed OPTON module DDM information readings;
*) wireless - added "etsi1" regulatory domain information;
*) wireless - improved WPA2 key exchange reliability;
*) wireless - updated "norway" regulatory domain information;
bajodel
Long time Member
Long time Member
Mon Oct 02, 2017 2:11 pm
Upgraded CRS326-24G-2S+ to 6.41rc37 , after reboot in the log I've noticed all ports have been removed from bridge hw-offloading and re-inserted.
I've also noticed Firmware 3.43 was available for CRS326-24G-2S+ and I've upgraded it also and rebooted.
Now I've enabled RSTP again and I'm going to re-insert the redundant patch cord to CRS125 ..and see what happen now
pcjc
Mon Oct 02, 2017 6:36 pm
I decided to try the 6.41rc release on my new CRS326-24G-2S+.
Two notes..
1. Same with 6.40 release firmware, the LAN activity light on Port 1 RJ45 blinks on (appears to reflect activity on the bridge link?), which appears to be a bug (or is this a hardware fault I should return the unit for?)
2. I cannot set the MTU of the bridge (which replaced the old switch configuration) to support jumbo frames. (I can create a new bridge with high MTU, but get an error "Couldn't change Interface <bridge1> - could not set mtu (6)" when attempting to do so on the bridge with all my ports on.
The ports are all hardware offloaded. Do I need to set a high MTU on the bridge / interfaces within the bridge in order to be able to pass jumbo frames? (That is what I am trying to achieve).
bajodel
Long time Member
Long time Member
Mon Oct 02, 2017 6:40 pm
It's been 4 hours and the CRS326-24G-2S+ (on 6.41rc37) is now beheaving well:
- RSTP now works stable between CRS326 and CRS125 (also on 6.41rc37)
- it's now possible to edit MAC addresses on CRS326 ethernet ports (and the device doesn't stuck on reboot)
- no port flapping (yet)
very curious about this:
eriitguy
Tue Oct 03, 2017 11:33 am
Thank you for this fix!
I don't know how it was planned but noticed that it failed at 204 status code:
[admin@CHR] > /tool fetch url="http://httpstat.us/204"
  status: failed
action failed (6)
eriitguy
Tue Oct 03, 2017 11:40 am
normis, thank you for observation:
[admin@CHR] > /tool fetch url="https://httpstatuses.com/204"
      status: finished
  downloaded: 3KiBC-z pause]
    duration: 1s
It working as expected!
normis
Tue Oct 03, 2017 11:44 am
There actually is a bug with 204, we will address it. Your previous URL works with "curl -v" so it should work in Fetch too.
msatter
Tue Oct 03, 2017 12:31 pm
Maybe it is possible to extra spaces to end of the "KiB" to erase the remainder of the previous text: "C-z pause]" with fetch.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46.1 / Winbox 3.20 / MikroTik APP 1.3.9
Android device owners, use https://github.com/M66B/NetGuard/releases (no root required)
jrpaz
Tue Oct 03, 2017 2:32 pm
I have a Novotel 730 which was added in 6.41r6 & it still is function it reboots when ever I try to pass traffic through it. I already emailed support hopefully they can help me figure this out.
niqx
Tue Oct 03, 2017 3:34 pm
Hello Friends,
A small note, but very important for us that uses ALOT of vlans.
We're currently benching CRS317 and we're missing out the option to set notes/comments under /interface bridge vlan.
This is because we'll have alot of config here and since we're alot of people managing the same devices it's key to leave notes. :-)
strods
Tue Oct 03, 2017 4:00 pm
What's new in 6.41rc38 (2017-Oct-03 11:51):
Before an upgrade:
*) arm - minor improvements on CPU load distribution for RB1100 series devices;
*) bgp - added 32-bit private ASN support;
*) upnp - add "src-address" parameter on NAT rule if it is specified on UPnP request;
*) upnp - deny UPnP request if port is already used by the router;
lukoramu
Tue Oct 03, 2017 4:46 pm
Try this:
/in bridge port add interface=all
It's fun! (Spoiler alert - netinstall.exe) ;-)
But actually, this feature is really what I was waiting for for a long time. I just hope these interface lists will be available for "tagged" and "untagged" attributes in "/in br vlan" section !
eriitguy
Tue Oct 03, 2017 5:55 pm
strods,
What is difference between earlier RC, for example:
nescafe2002
Long time Member
Long time Member
Tue Oct 03, 2017 6:00 pm
viewtopic.php?f=21&t=123936&start=100#p614799
If you see the same changelog entry in multiple rc versions then it is a new feature which is being implemented and changelog entry is simply moved up on each rc when additional work on it has been done.
eriitguy
Tue Oct 03, 2017 6:14 pm
Thank you!
uldis
Tue Oct 03, 2017 6:16 pm
strods,
We are constantly improving and fixing bugs for this feature.
Jotne
Wed Oct 04, 2017 8:16 am
Then the correct should be:
*) lte - updated Passthrough support (CLI only);
MikroTik->Splunk
hapi
Wed Oct 04, 2017 8:58 am
Why our sfp modules don't show tx power in mikrotik? Same module in signamax switch show tx power. THX.
Signamax
Connector Type	SFP - LC
Fiber Type	Reserved
Tx Central Wavelength	1310
Baud Rate	1G
Vendor OUI	00:00:00
Vendor Name	Mikrotik
Vendor PN	S-35LC20D
Vendor Rev	1.0
Vendor SN	SK151211B35234
Date Code	151205
Temperature [Degrees Centigrade]	33.75
Vcc [Volt]	3.30
Mon1 (Bias) [mA]	1
Mon2 (TX PWR) [dBm]	-5.19
Mon3 (RX PWR) [dBm]	-17.42
CRS326-24G-2S+
[admin@BS568] > interface ethernet monitor sfp-sfpplus1
                  status: link-ok
        auto-negotiation: disabled
                    rate: 1Gbps
             full-duplex: yes
         tx-flow-control: yes
         rx-flow-control: yes
      sfp-module-present: yes
             sfp-rx-loss: no
            sfp-tx-fault: no
                sfp-type: SFP-or-SFP+
      sfp-connector-type: LC
     sfp-link-length-9um: 20000m
         sfp-vendor-name: Mikrotik
  sfp-vendor-part-number: S-53LC20D
     sfp-vendor-revision: 1.0
       sfp-vendor-serial: SK151211B54444
  sfp-manufacturing-date: 15-12-05
          sfp-wavelength: 1550nm
         sfp-temperature: 40C
      sfp-supply-voltage: 3.296V
     sfp-tx-bias-current: 0mA
            sfp-rx-power: -9.752dBm
         eeprom-checksum: good
                  eeprom: 0000: 03 04 07 00 00 00 02 00  00 00 00 01 0d 00 14 c8  ........ ........
                          0010: 00 00 00 00 4d 69 6b 72  6f 74 69 6b 20 20 20 20  ....Mikr otik
                          0020: 20 20 20 20 00 00 00 00  53 2d 35 33 4c 43 32 30      .... S-53LC20
                          0030: 44 20 20 20 20 20 20 20  31 2e 30 00 06 0e 00 e4  D        1.0.....
                          0040: 00 1a 00 00 53 4b 31 35  31 32 31 31 42 35 34 34  ....SK15 1211B544
                          0050: 34 34 20 20 31 35 31 32  30 35 20 20 68 f0 04 34  44  1512 05  h..4
                          0060: 1f a0 7b 0b 1a 66 2c 8c  00 00 52 52 52 52 00 52  ..{..f,. ..RRRR.R
                          0070: 00 40 52 52 00 40 52 52  52 52 52 ff ff ff ff 00  .@RR.@RR RRR.....
                          0080: 55 00 d8 00 46 00 00 00  8d cc 74 04 88 b8 79 18  U...F... ..t...y.
                          0090: af c8 00 00 88 b8 00 00  13 94 04 eb 13 94 04 eb  ........ ........
                          00a0: 18 a6 00 10 13 94 00 10  00 00 00 00 00 00 00 00  ........ ........
                          00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                          00c0: 00 00 00 00 3f 80 00 00  00 00 00 00 01 00 00 00  ....?... ........
                          00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 40  ........ .......@
                          00e0: 28 64 80 c6 00 65 0b b3  05 89 7d 7d 7d 7d 00 7d  (d...e.. ..}}}}.}
                          00f0: 00 00 7d 7d 00 00 7d 7d  7d 7d 07 ff ff ff ff 00  ..}}..}} }}......
skylark
Wed Oct 04, 2017 9:15 am
Hello hapi,
DDM info seems quite good from SFP transceiver, why do you have auto-negotiation disabled and what is connected to opposite side? Have you tried to turn auto-negotiation=on?
hapi
Wed Oct 04, 2017 9:41 am
oh my mistake, it is CRS326-24G-2S+. Modul not function on 10Gbit = auto-negotation is disable and force 1Gbit otherwise they will not join on fiber.
TX power still not show.
v6.41rc38
strods
Wed Oct 04, 2017 10:12 am
Jotne - Main idea of rc changelog is to see the difference between current and rc version. Think of an upgrade like you would upgrade from 6.40.4 to 6.41rc no from 6.41rc to 6.41rc.
Anyway, if you have more questions about changelog structure, then please create new forum topic about this or write to support@mikrotik.com
Main idea of this topic is to polish new features in 6.41rc version so that the version would become 6.41 (current) release.
Grickos
Wed Oct 04, 2017 6:19 pm
After upgrade to 6.41RC38, WAP R-2nD processor 100%, self nonstop reboot the system. I used Netinstall to run it.
The others Roterboard are work ok
hapi
Wed Oct 04, 2017 6:46 pm
Another sfp modul, also no tx power, why? Will be fixed?
                  status: link-ok
                    rate: 1Gbps
             full-duplex: yes
             sfp-rx-loss: no
            sfp-tx-fault: no
     sfp-link-length-9um: 3000m
         sfp-vendor-name: UBNT
  sfp-vendor-part-number: UF-SM-1G-S
       sfp-vendor-serial: FT17012008409
  sfp-manufacturing-date: 17-01-12
          sfp-wavelength: 1550.32nm
         sfp-temperature: 39C
      sfp-supply-voltage: 3.263V
     sfp-tx-bias-current: 19mA
            sfp-rx-power: -7.271dBm
                  eeprom: 0000: 03 04 07 00 00 00 40 00  00 00 00 01 0d 00 03 1e  ......@. ........
                          0010: 00 00 00 00 55 42 4e 54  20 20 20 20 20 20 20 20  ....UBNT
                          0020: 20 20 20 20 00 00 00 00  55 46 2d 53 4d 2d 31 47      .... UF-SM-1G
                          0030: 2d 53 20 20 20 20 20 20  20 20 20 20 06 0e 20 37  -S           .. 7
                          0040: 20 0a 00 00 46 54 31 37  30 31 32 30 30 38 34 30   ...FT17 01200840
                          0050: 39 20 20 20 31 37 30 31  31 32 00 00 68 90 01 79  9   1701 12..h..y
                          0060: 20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20
                          0070: 20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20
                          0080: 5a 00 d3 00 55 00 d8 00  94 70 69 78 90 88 6d 60  Z...U... .pix..m`
                          0090: c3 50 00 00 af c8 00 32  18 a6 03 e8 13 94 04 eb  .P.....2 ........
                          00a0: 27 10 00 28 1f 07 00 32  00 00 00 00 00 00 00 00  '..(...2 ........
                          00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 99  ........ ........
                          00e0: 27 c3 7f 78 25 76 0a 81  09 cd 00 00 00 00 22 00  '..x%v.. ......".
                          00f0: 00 40 00 00 00 40 00 00  00 00 00 ff ff ff ff 00  .@...@.. ........
bajodel
Long time Member
Long time Member
Wed Oct 04, 2017 9:25 pm
..cut.. SFP transceiver, why do you have auto-negotiation disabled and what is connected to opposite side? Have you tried to turn auto-negotiation=on?
On RB3011 sfp to a CRS326-24G-2S+ via DAC cable doesn't work if you set auto-negotiation , furthermore the RB3011 doesn't detect if link go down (CRS instead correctly detects it).
All this on latest rc but also in previous 6.41rc and also 6.40.3/4
JimmyNyholm
Thu Oct 05, 2017 2:07 pm
Is it me or how do I search for learned mac-addresses with this new bridge implementation. Host table is almost always empty but local mac's but everything works.
This has been the same all this 41rc branch....
Is there a way to increase timeout on learning ( I have also asked for the option to disable learning or limit number of addresses learned.)
EDIT: Found all macs in /interfaces ethernet switch host
In this new implementation shouldn't these to tables be the same /bridge host and /interface ethernet switch host ???
JimmyNyholm
Fri Oct 06, 2017 10:25 am
In ROS this 6.41rc (38) branch with new bridge implementation with (H)ard ware flag. if I want to use switch chip's filter function.
is this rules applied to (I want the Silicon Hardware ones...)
/interface/bridge/filter
or
/interface/ethernet/switch/rule
Am I right to believe that the switch menu will go away completely and all stuff there will be moved/added to bridge menu. My concern is where we currently stand?
pe1chl
Fri Oct 06, 2017 12:33 pm
I am a bit lost on the direction and state of the new bridge implementation...
I use the switch on (mostly RB2011) routers fully configured with VLAN tagging, and with VLAN subinterfaces on the CPU port, like this:
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
/interface vlan
add interface=ether2 name=ether2.vlan12 vlan-id=12
add interface=ether2 name=ether2.vlan19 vlan-id=19
add interface=ether2 name=ether2.vlan20 vlan-id=20
add interface=ether2 name=ether2.vlan24 vlan-id=24
add interface=ether2 name=ether2.vlan44 vlan-id=44
add interface=ether2 name=ether2.vlan58 vlan-id=58
set 2 vlan-mode=secure
set 3 vlan-mode=secure
set 4 default-vlan-id=58 vlan-header=always-strip vlan-mode=secure
set 5 default-vlan-id=58 vlan-header=always-strip vlan-mode=secure
add independent-learning=no ports=switch1-cpu,ether2,ether3  switch=switch1 vlan-id=44
add independent-learning=no ports=switch1-cpu,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=58
add independent-learning=no ports=switch1-cpu,ether2 switch=switch1 vlan-id=20
add independent-learning=no ports=switch1-cpu,ether3 switch=switch1 vlan-id=19
add independent-learning=no ports=switch1-cpu,ether3 switch=switch1 vlan-id=12
add independent-learning=no ports=switch1-cpu,ether2 switch=switch1 vlan-id=24
What is the current state of the "switch to bridge" migration in 6.41rc? Is it going to convert such a configuration properly
and will it still work the same way? I.e. with hardware switching between the ports on tagged and untagged VLANs even
when some ports are tagged and others untagged in the same VLAN? And will it still drop traffic from VLAN tags not
configured for that port?
Denkinger
Sun Oct 08, 2017 12:24 am
Good evening,
Same problem here...
And I think router os runs a little bit slow on that device.
C3H5N3O9
Sun Oct 08, 2017 10:49 pm
Can't use proxy-arp fonctionality on bridge with new bridge implementation in 6.41rc, in fact, when we try to use ppptp tunnel with proxy-arp on bridge, host behind tunnel on lan can't ping. After a downgrade in 6.40.4 everything work well.
poizzon
Sun Oct 08, 2017 11:59 pm
Hello, after upgrading RBwAPR-2nD & R11e-LTE to version 6.41rc38, I received a critical error after which the router has been permanently rebooting.
if you want a relative version older than that, you need to log in with a static IP address, quickly roll over the main package, and quickly downgrade, or use netsintall
p.s. firmware version : 3.39.
Does upgrade to firmware up to version 3.41, does the RC start up normally?
poi
ivicask
Mon Oct 09, 2017 10:18 am
Can confirm this, same new WAP LTE constant reboots, Critical process died, etc in logs, works fine with older version.
strods
Wed Oct 11, 2017 12:35 pm
What's new in 6.41rc44 (2017-Oct-11 08:21):
Before an upgrade:
!) detnet - implemented "/interface detect-internet" feature;
https://wiki.mikrotik.com/wiki/Manual:Detect_internet
*) bridge - added comment support for VLANs;
*) bridge - added support for "/interface list" as a bridge port;
*) crs3xx - fixed 100% CPU usage after interface related changes (introduced in v6.41rc31);
*) dhcpv4-client - add dynamic DHCP client for mobile clients which require it;
*) firewall - do not NAT address to 0.0.0.0 after reboot if to-address is used but not specified;
*) ike1 - fixed RSA authentication for Windows clients behind NAT;
*) interface - added default "/interface list" "dynamic" which contains dynamic interfaces;
*) interface - added option to join and exclude "/interface list" from one and another;
*) ipsec - added DH groups 19, 20 and 21 support for phase1 and phase2;
*) ipsec - fixed lost value for "remote-certificate" parameter after disable/enable;
*) ipsec - fixed policy enable/disable;
*) ipsec - improved reliability on certificate usage;
*) ipsec - skip invalid policies for phase2;
*) l2tp - improved reliability on packet processing in FastPath;
*) log - fixed interface name in log messages;
*) log - properly recognize MikroTik specific RADIUS attributes;
*) lte - added "/interface lte apn" menu (Passthrough requires reconfiguration);
*) lte - limited minimal default route distance to 1;
*) mac-server - use "/interface list" instead of interface name under MAC server settings;
*) neighbor - show neighbors on actual bridge port instead of bridge itself
*) sms - include timestamps in SMS delivery reports;
*) sms - properly initialize SMS storage;
*) snmp - show only available OIDs under "/system health print oid";
*) winbox - allow shorten bytes to k,M,G in Hotspot user limits;
*) winbox - do not show duplicate "Switch" menus for CRS326;
*) winbox - fixed "/certificate sign" process;
*) wireless - added "allow-signal-out-off-range" option for Access List entries;
pe1chl
Wed Oct 11, 2017 2:18 pm
What about configurations like mentioned in posting #275 in this topic? Are they supported now?
idlemind
Wed Oct 11, 2017 2:45 pm
Fairly in depth post, to highlight a few things (community and strods correct me if I'm wrong).
The independent learning = no option doesn't exist anymore. You're going to get independent MAC databases per VLAN. I'm curious as to why you weren't doing that before, was it a hardware limitation?
Frame tagging exists in the implementation:
/interface bridge port set 0 frame-types=
FrameTypes ::= admit-all | admit-only-untagged-and-priority-tagged | admit-only-vlan-tagged
I'd argue that setting a PVID and "admit-only-untagged-and-priority-tagged" is better than VLAN mode secure and always-strip.
The rest of the configuration is just basic VLAN configuration which is well supported.
The only two points I personally can't speak for is how well the automatic conversion will go during the upgrade and the state of each of those features on the RB2011. I don't own that hardware.
Personally, I'd make sure I have a back-door after the upgrade. Maybe take a port out of the "switch-chip" by removing master-port and set it up as a routed interface that you can plug a laptop into and easily get access to the device. This also could be a WAN port, allow SSH to the device from your home or another office's IP so you can hop in that way if needed (or leave it open by src IP and use a good password / ssh key and come in via a mobile hotspot or starbucks). This would allow you to tweak the bridge config as needed.
Cha0s
Forum Veteran
Forum Veteran
Wed Oct 11, 2017 3:36 pm
Is this feature feature optional if someone does not want their router to contact cloud.mikrotik.com every minute?
Is it just cosmetic (ie: "this interface is 'WAN' just FYI") or is it actually used somewhere (ie: in firewall rules as an interface list) ?
Does in any way affect the functionality of other features in ROS?
eriitguy
Wed Oct 11, 2017 3:44 pm
Specifying our own host instead of 8.8.8.8 and cloud.mikrotik.com, may be usefully in the future.
Thank you!
andriys
Wed Oct 11, 2017 3:49 pm
My understanding is it will populate the interface lists you specify with the actual interfaces. Those lists can then be used in firewall filter, NAT, etc.
I'd also expect this feature to be used in the defconf, but we'd better wait for an official announcement.
Cha0s
Forum Veteran
Forum Veteran
Wed Oct 11, 2017 3:51 pm
Thank you!
Yes that would actually be cool IMHO.
I generally don't like features that 'call the vendor's home'. I prefer solutions that respect the user's privacy.
idlemind
Wed Oct 11, 2017 4:05 pm
Is the test IPv6 compliant. It needs to be. The address 8.8.8.8 is an IPv4 static, fail. The DNS name cloud.mikrotik.com only has an A record.
If you truly want to detect for Internet you need to use both IPv4 and IPv6 literals and a dual-stacked DNS name. We (the networking community) MUST NOT design features that are IPv4 only. The standards bodies have adopted an IPv6 first approach. I'm very sad to see this feature does not follow that stance. Some ISPs have already had to go to an IPv6 only design due to IPv4 exhaustion. Many others are doing layered IPv4 NAT (CGN) to provide psuedo IPv4 connectivity. (Look at the US cellular market). As a customer, this lack of market awareness is troubling. A feature that clearly targets home or small business routers should be IPv6 aware given the climate of connectivity.
As many forum members will likely state, this feature is of little value to them. It may find some play in the home router arena but even then it seems like overkill. I am curious as to how this test is valid. Packets sourced from my LAN IP all have access to 8.8.8.8 and cloud.mikrotik.com via the static default route and NAT rules. Does the special interface have coding that inspects the routing table?
All in all, seems like another case of MikroTik's roadmap being out of touch with actual customer needs. You don't drive sales by developing features that don't provide any value. You need to provide features that demonstrate how MikroTik routers can be used to develop solutions that create positive business outcomes. We can sell business outcomes to purchasers. Simplifying VLAN configuration and implementing RSTP and MSTP. Those are great examples of features that create value that can be translated into positive business outcomes.
pe1chl
Wed Oct 11, 2017 4:33 pm
The defconf already changed in version 6.40! It now uses the "WAN" interface list in the firewall instead of ether1.
jrpaz
Wed Oct 11, 2017 4:48 pm
The Novotel 730L is still unable to stay connected it constantly loses DHCP leases even after this release.
pe1chl
Wed Oct 11, 2017 5:01 pm
Well that setting is not so important, I think. I probably unchecked it once because it would be like the switches I am accustomed with, and then just copied the same setting over and over.
Are you sure? I do not yet see the option to restrict certain tagged VLANs to certain ports. And what about tagging untagged frames with a certain VLAN tag?
My config does not use the untagged VLAN at the CPU port, but it does have untagged external ports. Those have to be in some VLAN.
Now, the switch easily manages that with the default-vlan-id=xx vlan-header=always-strip setting, but can the bridge do the same thing? And will it
be hardware accellerated? (I do not want traffic between an untagged port and the tagged VLAN with the same ID on another port to be CPU-bridged)
Well it hopefully will not be very different between models that have a switch chip so I could do some experiments on a RB750.
Normally there is a local network with DHCP service on port 10 for emergency maintenance and of course these routers also have a serial port, but unfortunately they are located on sites all over the country that have limited access. We will clearly have to be very careful when updating to 6.41
Zaffo
Wed Oct 11, 2017 5:05 pm
After an upgrade from the previous rc38 to v6.41rc44 my mAP lite crashes when the ethernet cable is plugged in. First log entry after unplugging the cable states "router rebooted because some critical program crashed". Device is configured as a pocket router/AP and has one L2TP/IPsec and two ovpn clients.
After disabling the PPP clients I can connect ether1 without problems. When I now enable either one of the ovpn clients the device crashes some time after the connection is established. The L2TP/IPsec client gives no problem.
strods
Wed Oct 11, 2017 5:13 pm
As for detect-interface feature. Please take a look at wiki page which was provided in changelog:
https://wiki.mikrotik.com/wiki/Manual:D ... figuration
"detect-interface-list (interface list; Default: none) All interfaces in the list will be monitored by Detect Internet"
As you can see - default value is none
R1CH
Forum Veteran
Forum Veteran
Wed Oct 11, 2017 5:18 pm
Thank you!
Changing the hosts is not just useful, it's a requirement. Just imagine, you can DDoS cloud.mikrotik.com and every router using this feature goes offline!
Chupaka
Wed Oct 11, 2017 5:28 pm
ports still will be 'WAN', so nothing terrible should happen :)
idlemind
Wed Oct 11, 2017 6:00 pm
Opposite, inject a route to 8.8.8.8 into a dynamic protocol running on someones environment that relies on this feature. It'll toggle the interface to WAN, apply security policies, likely dropping all traffic until detect-interface flaps back to LAN. Then it flaps to WAN when it relearns the route and flap and flap and flap.
Dumb feature.
It's like VTP, was great on the drawing board and then it was used to wipe peoples VLAN databases. It took a few years but now Cisco disavows that feature.
idlemind
Wed Oct 11, 2017 6:12 pm
PVID = Default VLAN (Primary VLAN ID).
So you can accomplish an untagged port by changing the PVID of a bridge port to whatever VLAN ID you need. You also have the /interface bridge vlan table. In that table you specify which ports have a VLAN tagged or untagged. So like secure mode, you set admit-only-tagged-frames and then only add that bridge port to the VLANs tagged lists that you want.
As far as the acceleration goes, it is model dependent. The goal is to manage hardware offload based on the switch chips available features. I got that answer from MikroTik support. The translation is that if it can do it now in the switch chip it should do it in the future with HW offload on dynamically. How long it takes to get to that state for all models, well time will tell.
The master-port option is removed so you can't really use the old configurations. MikroTik has been tight lipped about which switch chips it has enabled HW offload for. None of my test gear (hex, wap ac and cap lite) are setup in a way that I'm seeing HW offload actually turned on yet for the Ethernet ports. That said I can still pull over 300mbps across VLANs on my hex. InterVLAN routing was and always will be CPU bound and I don't really have much traffic that hits the bridges, I used software bridges in the past because the switch chip in the hex is basically a single flat layer 2 domain (no vlans).
Without meaningful release notes that tell us when each switch chip is enabled for HW offload the only thing we know is that they are developing off of CRS3xx in house. The best thing might be to target a single location that uses a RB2011 or setup a lab RB2011 and monitor the RCs progress for your particular set of options so you know when that happens or cool your heals until 6.41 goes GA.
lukoramu
Wed Oct 11, 2017 6:19 pm
Dumb feature.
Hmm.. Why do you guys think that "detect-internet" feature will do ANY of that?...
What I'm getting from wiki page, it's just an informational feature: you type
/interface detect-internet state
and you get some info, that this feature gathered..
idlemind
Wed Oct 11, 2017 6:31 pm
Dumb feature.
The magic is in the other settings:
[admin@211-rtr1] > interface detect-internet set
Change properties of one or several items.
detect-interface-list --
internet-interface-list --
lan-interface-list --
wan-interface-list --
If you see the wiki the lists is what does the work, set Internet interface list to something like WAN, add all interfaces to the detect-interface-list and boom you have a problem. If the LAN interface is detected to be a WAN interface it can then be elevated to an Internet interface. I'd have to setup a lab but I'd imagine it's possible to do the necessary spoofing just with routing.
andriys
Wed Oct 11, 2017 6:52 pm
My understanding is detect-internet is aimed to be used on home-users' routers, which are definitely not supposed to be running any of the dynamic routing protocols (and are not by default). Honestly, I don't see anything wrong with it. Much better to have all ports protected, and treat some of them as WAN-facing (and others as LAN-facing) when certain criteria is met, than exposing your router to the DNS amplification attacks by simply adding PPPoE interface without also modifying the existing (default) firewall rules (a common problem that multiple people complained about up until recently).
pe1chl
Wed Oct 11, 2017 7:20 pm
Ok, that sounds good. From earlier discussion I got the impression that from now on the bridge would be one big VLAN-transparent thing, whereas in my existing practice (not the above example) I would normally put VLAN subinterfaces on ports and make the subinterfaces part of a bridge, rather than putting entire ports in the bridge and adding VLAN subinterfaces to the bridge.
However, with detailed VLAN configuration for bridge ports that could be a good solution.
I think I'll have to experiment with converting some setups on a test router...
pe1chl
Wed Oct 11, 2017 10:27 pm
I enabled the detection for "all" interfaces on a CHR test system that has 2 ethernet interfaces that both have internet connectivity,
but their status remains at "wan" and does not go to "internet".
There are two default routes, one in the main table and one in an extra table which is selected by an IP route rule on the
source address of the second interface. Pinging 8.8.8.8 and cloud.mikrotik.com works fine.
I would have expected at least one of them to show "internet", maybe not both when this policy routing is not recognized yet.
boyko
Thu Oct 12, 2017 12:20 am
I just updated to the latest RC and the bridge conversion did not take in account the spoofed MAC address on the WAN port. I had to manually adjust that on the newly created bridge. This needs to be handled before the final release or people are going to have issues with it.
ShturmN
Re: v6.41rc [release candidate] is released! New bridge implementation!
Thu Oct 12, 2017 3:00 am
I'm update to 6.41rc44 my sxt 5 and now:
https://s.mail.ru/6XPP/7BwY2UJm3
pe1chl
Thu Oct 12, 2017 10:16 am
Another issue: although the interfaces have been setup with static addresses, after enabling this feature
the router is sending DHCP requests at a rate of 1 per second.
Chupaka
Thu Oct 12, 2017 11:06 am
so, some peering partner injects a route to block himself? it's either bad or dumb peering partner :)
whitbread
Thu Oct 12, 2017 2:52 pm
I am stuck with new bridge implementation using VLAN's either. What I want to accomplish is to pass tagged traffic through the router while reaching the router through the same VLAN.
I am using RB2011's and a RB951G with v.6.41RC44.
R1 is connected via cable to R2. R2 is connected via wireless bridge to R3. I need connection from R1 to R2 on VLAN's 3 and 1013 and from R1 to R3 on VLAN's 3 and 1002.
R3 is configured as station bridge with VLAN's 3 and 1002. Both VLAN's are terminated with IP-Adresses at R3.
/interface vlan
add interface="WLAN1" name="WLAN1 VLAN1002" vlan-id=1002
add interface="WLAN1" name="WLAN1 VLAN3" vlan-id=3
add address=192.168.88.3/24 interface="WLAN1 VLAN1002" network=192.168.88.0
add address=192.168.3.3/24 interface="WLAN1 VLAN3" network=192.168.3.0
I can connect to both VLAN's from R1 but not from R2.
R1 is configured the same way using VLAN-interfaces.
/interface vlan
add interface="P05  Trunk R2" name="P05 R2 VLAN3" vlan-id=3
add interface="P05  Trunk R2" name="P05 R2 VLAN1002" vlan-id=1002
add interface="P05  Trunk R2" name="P05 R2 VLAN1013" vlan-id=1013
add address=192.168.88.1/24 interface="P05 R2 VLAN1002" network=192.168.88.0
add address=192.168.89.1/24 interface="P05 R2 VLAN1013" network=192.168.89.0
add address=192.168.3.1/24 interface="P05 R2 VLAN3" network=192.168.3.0
I can connect R3 from R1 on both VLAN's. Connection to R2 works only on VLAN1013 as this interface is not part of the bridge. VLAN1002 has no IP on R2.
R2 is where I get stuck. I am trying to use a single bridge on this one as I am into using R2 as a CAP with local forwarding. So no parent VLAN interfaces will be possible.
Actually forwarding tagged traffic through R2 and connection to a Client physically connected to R2 (VLAN3) works fine.
But how do I reach R2 itself on VLAN3 ?
<1> If I use VLAN interfaces on Trunk port and bridge VLAN inferface I can not connect.
/interface vlan
add interface="P2  Trunk R1" name="P2 R1 VLAN1002" vlan-id=1002
add interface="P2  Trunk R1" name="P2 R1 VLAN1013" vlan-id=1013
add interface="P2  Trunk R1" name="P2 R1 VLAN3" vlan-id=3
add fast-forward=no igmp-snooping=no name="Bridge one4all" protocol-mode=none vlan-filtering=yes
add bridge="Bridge one4all" ingress-filtering=yes interface="P3" pvid=3
add bridge="Bridge one4all" interface="WLAN2 AP" pvid=3
add bridge="Bridge one4all" frame-types=admit-only-vlan-tagged interface="WLAN3  Bridge"
add bridge="Bridge one4all" interface="P2 R1 VLAN1002" pvid=1002
add bridge="Bridge one4all" interface="P2 R1 VLAN3" pvid=3
add bridge="Bridge one4all" tagged="WLAN3  Bridge" vlan-ids=3
add bridge="Bridge one4all" tagged="WLAN3  Bridge" vlan-ids=1002
add address=192.168.89.2/24 interface="P2 R1 VLAN1013" network=192.168.89.0
add address=192.168.3.2/24 interface="P2 R1 VLAN3" network=192.168.3.0
<2> I tried it without VLAN inferfaces but I don't see any possibility to reach R2 then.
/interface vlan
add bridge="Bridge one4all" frame-types=admit-only-vlan-tagged ingress-filtering=yes interface="P2  Trunk R1"
add bridge="Bridge one4all" tagged="WLAN3  Bridge,P2  Trunk R1" vlan-ids=3
add bridge="Bridge one4all" tagged="WLAN3  Bridge,P2  Trunk R1" vlan-ids=1002
Either way I can connect to R3 on both VLAN's and to a Client physically connected to R2 (VLAN3).
R2 is reachable on VLAN1013, but this interface is not part of the bridge.
How can I reach R2 via VLAN3?!?
Any help is highly appreciated. 8)
idlemind
Fri Oct 13, 2017 1:32 am
/interface vlan
/interface vlan
/interface vlan
/interface vlan
Long story short, read the bridge wiki page.
You need to tag the VLANs on the bridge itself in /int bridge vlan and the VLAN interfaces need to have the interface property set to the bridge in question not some random Ethernet interface.
whitbread
Fri Oct 13, 2017 11:06 am
Oh boy - you are right: RTFM!
The bridge itself is kind of an interface. Now everything works.
But I am still curious if I choose the correct way to work with untagged i.e. PVID1-traffic. Both trunk ports have PVID1. The whole configuration works only if I set both trunk ports as tagged in bridge vlan setting for PVID1.
As soon as I set both trunk ports as untagged in bridge vlan settings for PVID1 no connection is possible. This situation persists until I do a reboot or disable and enable the whole bridge. Is this meant to be like this?
Gennadiy51
Fri Oct 13, 2017 11:18 am
I'm blocking the provider port, because of the high number of requests on the WAN port. The provider is very unhappy with this!
What should I do?
X86 (Intel 566 MHz Slot1), RB450G, RB493G, hAP ac lite, hAP ac^2, hAP ac, wAP ac.
blimbach
Fri Oct 13, 2017 12:34 pm
This Version is really bad on my hapac capsman:
oct/12/2017 17:11:40 system,error,critical router rebooted because some critical program crashed
oct/12/2017 17:41:47 system,error,critical router rebooted because some critical program crashed
oct/12/2017 17:52:04 system,error,critical router rebooted because some critical program crashed
oct/13/2017 06:56:57 system,error,critical router rebooted because some critical program crashed
oct/13/2017 07:01:37 system,error,critical router rebooted because some critical program crashed
oct/13/2017 07:20:52 system,error,critical router rebooted because some critical program crashed
oct/13/2017 07:24:24 system,error,critical router rebooted because some critical program crashed
oct/13/2017 07:37:33 system,error,critical router rebooted because some critical program crashed
<peep>.....<peep peep> every few minutes....
How to downgrade to an older rc? I cannot find a download-link.
kamillo
Fri Oct 13, 2017 1:13 pm
Go to https://mikrotik.com/download
Grab a link to latest RC for your platform and edit url to the version you want.
https://download2.mikrotik.com/routeros/6.41rc38/routeros-mipsbe-6.41rc38.npk
blimbach
Fri Oct 13, 2017 1:39 pm
Thank you, downgrading fixed the Problem to me.
jrpaz
Fri Oct 13, 2017 3:43 pm
Same issue with the RB750gr3 had to downgrade back #sad
emils
Fri Oct 13, 2017 4:06 pm
If you experience critical program crashes or kernel panics on latest release candidate versions, please send supout.rif (autosupout.rif) files to support@mikrotik.com before downgrading.
pe1chl
Fri Oct 13, 2017 5:36 pm
What should I do?
I would advise keeping the detect-internet feature disabled until this problem is fixed.
For now it is only safe when your internet port obtains its address using DHCP. When the detect-internet sees
a DHCP reply it then remains quiet (probably for half the leasetime at least). But when there is no DHCP reply
it goes haywire.
whitbread
Fri Oct 13, 2017 6:36 pm
imho it is actually only good for a LAN router not for a router with direct uplink.
What I do like actually is that it gives information about the ports open via MAC. :D
strods
Mon Oct 16, 2017 9:03 am
Version 6.41rc release includes fixes in WPA2 protocol:
viewtopic.php?f=21&t=126695
alkar
Mon Oct 16, 2017 1:27 pm
when v6.41rc will be as "current" ?
We bought 2 x CRS317-1G-16S+RM and couldn't set up harware vlan via winbox.
It is difficult to manage hundreds of vlans in a text teminal.
andriys
Mon Oct 16, 2017 3:02 pm
Based on experience with some previous RouterOS versions, I'd say that hitting the Current update channel and receiving WinBox support for some options are two unrelated things. It's possible that 6.41 becomes current with these options still being CLI-only.
I'm wondering though, what stops you from staying on 6.40.x or 6.39.x and configuring what you need in a "traditional" way?
Kubuxu
Mon Oct 16, 2017 3:18 pm
I am trying to set up VLAN bridge for upstream and access to the router on RB3011 running 6.41rc44 but also offload the switching to the hardware switch.
I am able to successfully do one or the other but if I combine both setups for local pings I get 3 DUPs.
Setup in question:
Main router: 3011 running 6.41.rc44 with PPPoE upstream. For simplicity two LAN ports: eth2-PC trunk port VLANs: 100 and 200, eth3-notebook access port VLAN 100.
Bridge setup:
/interface add bridge auto-mac=no comment="main bridge" igmp-snooping=no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=bridge-vlan100 vlan-id=100
add interface=bridge name=bridge-vlan200 vlan-id=200
add bridge=bridge interface=eth2-PC
add bridge=bridge interface=eth3-notebook pvid=100
add bridge=bridge tagged=bridge,eth2-PC untagged=eth3-notebook vlan-ids=100
add bridge=bridge tagged=eth2-PC,bridge vlan-ids=200
This works but traffic from eth2-PC to eth3-notebook always goes through CPU bridge (hardware offload is disabled as for the vlan-filtering=yes which is not supported on switch chip in 3011.
This is true, switch chip in 3011 can't add VLAN tags to packets but it can use 'Default VLAN ID' for access ports.
port set eth2-PC vlan-mode=check
port set eth3-notebook vlan-mode=check vlan-header=always-strip default-vlan-id=100
vlan add switch=switch1 ports=eth2-PC,eth3-notebook,switch1-cpu vlan-id=100
vlan add switch=switch1 ports=eth2-PC,switch1-cpu vlan-id=200
If I add this part of the setup I get 3 DUPs on pings between eth2-PC <-> eth3-notebook (VLAN100<->VLAN100) and it is generally unstable. This is because the RouterOS disabled hardware offloading and the host table of hardware switch is empty (and stays that way) and then it works as a hub (that is only explanation I have), thus pushing the packets through all connected interfaces.
If I remove swich1-cpu from 'vlan add' statements connection between PC and notebook via VLAN 100 works (no DUPs) and is switched in hardware but packets are still broadcasted on every connected interface (same issue, hw-offload disabled, switch host table not populated). If I also remove VLAN filtering from the software bridge, which makes it enable hw-offload, the switch host table gets populated but then there is no separation in the software bridge.
This setup shows that switch chip in 3011 is able to perform basic VLAN filtering in hardware but using VLAN filtering on bridge makes in unusable (DUPs, loops or no hardware acceleration).
I really hope this can be resolved, this significantly cuts down on capabilities of 3011 which might as well have no VLAN aware switch chip/swich host table at this point.
idlemind
Mon Oct 16, 2017 4:22 pm
Setup in question:
Bridge setup:
/interface vlan
If I add this part of the setup I get 3 DUPs on pings between eth2-PC <-> eth3-notebook and it is generally unstable. This is because the RouterOS disabled hardware offloading and the host table of hardware switch is empty (and stays that way) and then it works as a hub (that is only explanation I have), thus pushing the packets through all connected interfaces.
Per a case I opened with MikroTik support, expect existing hardware features to slowly be turned on in the new environment. That said, any inter-VLAN traffic, traffic from VLAN100 to VLAN200 from a routing perspective will always be done across the CPU. I believe the reference platform they are using for development is the CRS3xx products. I'd expect to see other platforms covered over time. I run a 750Gr3 (hex) to perform inter-VLAN routing and it gets 300mbps+ throughput and has worked fine in my LAN considering everything else is constrained by a much slower Internet connection. Your mileage may very with other platforms and their CPU.
Kubuxu
Mon Oct 16, 2017 5:23 pm
I know that, but this is VLAN100<->VLAN100 which should be possible to be done in the switch.
Let's hope in future it will allow to use 3011 switch capabilities with any VLAN.
alkar
Tue Oct 17, 2017 4:04 pm
A "traditional" way in CRS317 not working. Switch menu shown all ports as Unknown.
viewtopic.php?f=17&t=125758
idlemind
Tue Oct 17, 2017 5:00 pm
I'd have to see your configuration to be certain but it shouldn't be a problem as long as VLAN1 is only untagged or tagged not both on the port. Additionally, VLAN1 either needs to be untagged (default) or tagged for the bridge interface as well.
strods
Thu Oct 19, 2017 12:42 pm
What's new in 6.41rc47 (2017-Oct-18 10:38):
Important note!!! Backup before upgrade!
RouterOS (v6.40rc36-rc40 and) v6.41rc1+ contains new bridge implementation that supports hardware offloading (hw-offload).
This update will convert all interface "master-port" configuration into new bridge configuration, and eliminate "master-port" option as such.
Bridge will handle all Layer2 forwarding and the use of switch-chip (hw-offload) will be automatically turned on based on appropriate conditions.
The rest of RouterOS Switch specific configuration remains untouched in usual menus for now.
Please, note that downgrading to previous RouterOS versions will not restore "master-port" configuration, so use backups to restore configuration on downgrade.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
Changes since previous 6.41rc release:
!) bridge - general implementation of hw-offload bridge (introduced in v6.40rc36);
!) routerboot - RouterBOOT version numbering system merged with RouterOS;
*) bridge - assume "point-to-point=yes" for all Full Duplex Ethernet interfaces when STP is used (as per standard);
*) console - removed "/setup";
*) crs3xx - added ingress/egress rate input limits;
*) discovery - use "/interface list" instead of interface name under neighbour discovery settings;
*) ethernet - fixed missing "sfp-tx-power" option (introduced in v6.41rc14);
*) ipsec - fixed incorrect esp proposal key size usage;
*) lte - temporarily disabled user authentication using user/password PAP/CHAP support for R11e-LTE (introduced in v6.41rc44);
*) lte - fixed PIN option after setting up the band;
*) lte - fixed error when trying to add APN profile without name;
*) lte - fixed rare crash when initializing LTE modem after reset;
*) netinstall - fixed missing default configuration prompt on first startup after reset/netinstall;
*) ssh - do not use DH group1 with strong-crypto enabled;
*) ssh - enforced 2048bit DH group on tile and x86 architectures;
*) winbox - added support for "_" symbol in terminal window;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
planetcoop
Thu Oct 19, 2017 5:41 pm
"/ip neighbors" seems to not work on 6.41rc47 on tile...
mrz
Thu Oct 19, 2017 5:49 pm
go to
/ip neighbor discovery-settings menu
and set discover-interface-list=all
raffav
Thu Oct 19, 2017 5:54 pm
go to
this function is not available on winbox yet correct ?
mrz
Thu Oct 19, 2017 5:58 pm
yes, currently only terminal. Default value is "!dynamic", but you can set it to "all".
raffav
Thu Oct 19, 2017 6:00 pm
thanks
pe1chl
Thu Oct 19, 2017 7:22 pm
Discovery packets are now sent with source 0.0.0.0 instead of interface address as before. Maybe due to this change?
This causes firewall issues, we drop "bogon" packets (packets from an address list with certain reserved addresses including 0.0.0.0)
before the rule that accepts discovery packets.
raffav
Thu Oct 19, 2017 9:45 pm
Mikrotik team
is it difficult to create some type of address-list or something similar to use on ipsec polices in future release ?
alexsolovyev
Thu Oct 19, 2017 10:49 pm
Applying the default configuration seems to be broken in 6.41rc47. I'm getting an empty config after clicking on the "OK" button after resetting the configuration. It's working in 6.40.4
chubbs596
Fri Oct 20, 2017 2:26 am
Has anyone tested ROMON in 6.41rc47?
Seems that is not working.
Also, can someone explain how QinQ vlans would be programmed in the new Bridge vlan implementation?
idlemind
Fri Oct 20, 2017 3:18 am
Put a bridge in your bridge?
roswitina
Fri Oct 20, 2017 9:43 am
I use 2011UiAS-2HnD with firmware 3.41.
After Urgrade to firmware v6.41rc44 and/or v6.41rc47 the router reboots every one to two hours.
in the log I have the following entry:
memory system,info router rebooted
memory system,error,critical router rebooted beause some critical program crashed
I go back to the current firmware 6.40.4.
rosi
uldis
Fri Oct 20, 2017 10:09 am
rosi
Please make a support output file after the crash and send it to support@mikrotik.com
bajodel
Long time Member
Long time Member
Fri Oct 20, 2017 11:24 am
and if I need a single service tag on packets ?
I've never played with new bridge but I suppose there is a place where I can set the tag type..
roswitina
Fri Oct 20, 2017 1:09 pm
rosi
I'm doing it. I install v6.41RC47 and wait for the next crash.
Rosi
linek1980
Fri Oct 20, 2017 1:30 pm
oct/19 15:40:31 system,info router rebooted
oct/19 15:40:31 system,error,critical router rebooted because some critical program crashed
oct/19 15:40:39 bridge,info hardware offloading activated on bridge "bridge" ports: ether2
oct/19 15:40:39 bridge,info hardware offloading activated on bridge "bridge" ports: ether3
oct/19 15:40:39 bridge,info hardware offloading activated on bridge "bridge" ports: ether4
oct/19 15:40:39 bridge,info hardware offloading activated on bridge "bridge" ports: ether5
oct/19 15:40:41 interface,info ether1 link up (speed 100M, full duplex)
Chupaka
Fri Oct 20, 2017 2:11 pm
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
becs
Fri Oct 20, 2017 3:09 pm
In RouterOS v6.41 everything QinQ related has to configured with bridge "vlan-filtering=no" using VLAN interfaces and their "use-service-tag" option.
JimmyNyholm
Fri Oct 20, 2017 6:19 pm
And if one do that all qinq switching will get software switched or what?
idlemind
Fri Oct 20, 2017 7:00 pm
Wouldn't it have been in software before? Are their models that supported QinQ in hardware under the switch chip menu?
whitbread
Sat Oct 21, 2017 8:15 am
I am still curious which devices will support HW-offloading when VLAN-Filtering is enabled. I understand, that most devices need to run inter VLAN switching via CPU, but currently all my devices (RB2011 et. al.) don't do HW-offloading at all.
Is this a software limitation of the current RC development and will be implemented in the near future?
guipoletto
Sun Oct 22, 2017 1:46 am
I would like to know if this new bridge implementation affects something on hardware that does not have an integrated switch-chip (Rb333, CCR, rb1200{ports5-10}, etc).
Are any performance gains to be expected?
hapi
Sun Oct 22, 2017 2:00 pm
*) wireless - log "signal-strength" when successfully connected to AP;
Can you add a signal to the log and to the client when it was disconnected?
biatche
Mon Oct 23, 2017 9:37 am
Do that for capsman too.
darencrew
Mon Oct 23, 2017 8:24 pm
On previous releases, a way to flush neighbor discovery entries was to disable and re-enable discovery interfaces.
Now, it has no more effects, entries disappear only after aged out.
If that's an expected behavior, as "/ip neighbor discovery" menu has disappeared on CLI, winbox "neighbor discovery interfaces" should probably go, and be replaced by the new "discovery-settings".
In my opinion, the new "/ip neighbor discovery-settings set discover-interface-list" is not totally useless but is too generic, so it should better be a new feature (or more exactly a macro) and not a replacement feature.
darzupan
Tue Oct 24, 2017 9:11 am
Hi
Yesterday i bought wap-lte kit eu upgraded to version 6.41rc47 I have a problem snmp lte not working I tried to custom oid not work
When it will be repaired
mtxrltemodem interface index 1.3.6.1.4.1.14988.1.1.16.1.1.1
mtxrltemodem signalrssi 1.3.6.1.4.1.14988.1.1.16.1.1.2
mtxrltemodem signalrsrq 1.3.6.1.4.1.14988.1.1.16.1.1.3
mtxrltemodem signalrsrp 1.3.6.1.4.1.14988.1.1.16.1.1.4
mtxrltemodem cell id 1.3.6.1.4.1.14988.1.1.16.1.1.5
mtxrltemodem signalsinr 1.3.6.1.4.1.14988.1.1.16.1.1.7
Another problem
On the SIM card I have private APN xxxx.si and APN internet but I can not connect to APN xxxx.si .. tried all possible settings but the connection is not established .. apn internet works
For APN xxxx.si I use the Huawei E3372 usb modem to MT CCR1009 this works fine in the same usb modem running on MT x86 ESXi is work. But the Wap-lte kit eu private apn doesn't work.
APN xxxx.si use to connect to the official network.
What could be a problem?
Best regards
c02
Tue Oct 24, 2017 5:46 pm
need user auth and custom apn for wap lte eu - please relase 6.41rc48 - thx !
frakas
Wed Oct 25, 2017 3:28 pm
Products: CRS326-24G-2S+RM
RouterOS: 6.41rc47
This is my configuration: ether1 is untagged vlan 40 and ether24 is Trunk (all vlan is tagged)
add fast-forward=no igmp-snooping=no name=bridge-vlans vlan-filtering=yes
/interface vlan
add interface=bridge-vlans name=vlan40 vlan-id=40
add interface=bridge-vlans name=vlan41 vlan-id=41
add interface=bridge-vlans name=vlan42 vlan-id=42
add bridge=bridge-vlans interface=ether1 pvid=40
add bridge=bridge-vlans interface=ether24-Trunk
add bridge=bridge-vlans tagged="bridge-vlans,ether24-Trunk"  vlan-ids=40
add bridge=bridge-vlans tagged="bridge-vlans,ether24-Trunk" vlan-ids=41
add bridge=bridge-vlans tagged="bridge-vlans,ether24-Trunk" vlan-ids=42
add address=192.168.40.254/24 interface=vlan40 network=192.168.40.0
add address=192.168.41.254/24 interface=vlan41 network=192.168.41.0
add address=192.168.42.254/24 interface=vlan42 network=192.168.42.0
set name=R1
Ether24 connects to another CRS326 with the same configuration. The only difference is the only ip on vlan40 (192.168.40.253).
It seems to work everything until it connects servers and clients to different vlan. Packet routing does not always work.
Is there any known bug in my configuration?
Is there any other configuration possible to achieve the same goal?
AC
chubbs596
Thu Oct 26, 2017 10:18 am
Yea sure that will work but cant see that that is the correct way to do this as you loose the hardware offload on this type off config.
Any ideas? Maybe Mikrotik can comment on this
chubbs596
Thu Oct 26, 2017 10:27 am
Has anyone tested ROMON in 6.41rc47? Doesn't seem to work
nescafe2002
Long time Member
Long time Member
Thu Oct 26, 2017 1:05 pm
RoMON works fine here (both router and endpoint on 6.41rc47).
Have you tried playing with new discovery settings? Not sure if these are related. RoMON works fine even with discovery-interface-list=none..
go to
eworm
Fri Oct 27, 2017 8:43 pm
The support promised the next rc release will have a fix for my crash. That was one and a half week ago...
Will we have a release any time soon?
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Sat Oct 28, 2017 9:15 am
It will be released when its ready.
RC is for test only. Not ment for production environment.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
skuykend
Sat Oct 28, 2017 7:02 pm
Hopefully a new RC early next week, but they pretty much shut down development during a MUM, which started Thursday.
skuykend
Sat Oct 28, 2017 7:14 pm
CRS317 running 6.41rc47 for about 5 days then fault led came on, and other LED's stopped responding (seemed left at their previous state). I also lost access to the my management vlan/IP, but the switch seemed to be otherwise still working passing traffic. Just no access to the CPU.
I didn't think to try a console cable to see if I could get access to generate a support out, but will if it happens again.
I unplugged both power cords then powered it back up and has been running fine for the last 12 hours.
skuykend
Sun Oct 29, 2017 7:17 pm
No ports/wlan working with default config for RB951G on rc47. Pretty sure was working on rc44 Will have to Netinstall.
mhugo
Mon Oct 30, 2017 6:00 pm
Hardware offload for Vlans using the bridge ports on CRS212 does not seem to work?
add igmp-snooping=no name=bridge1
add igmp-snooping=no name=bridge2
/interface vlan
add interface=sfp10 name=sfp10-vlan100 vlan-id=100
add interface=sfp10 name=sfp10-vlan101 vlan-id=101
add bridge=bridge1 interface=sfp2
add bridge=bridge1 interface=sfp10-vlan100
add bridge=bridge2 interface=sfp5
add bridge=bridge interface=sfp10-vlan101
The actual non-vlan members seems to be enabled for the hwoffload, but not the VLANS. Should this be done in another way?
Running 6.41rc47 on CRS212-1G-10S-1S+
/Mikael
JimmyNyholm
Mon Oct 30, 2017 6:57 pm
/interface vlan
/Mikael
/inteface bridge vlan (here you define bridge vlan and member ports att taged or untaged. Here tag bridge self to.......
/interface vlan is routeros os routing capable interface... connect to bridge interface to connect routeros to underlying switch infrastructure.
mhugo
Wed Nov 01, 2017 1:26 am
Seems to be some chip issue when adding vlans in bridge on 212. Verified by Mikrotik trainer who will contact MT tomorrow.
strods
Wed Nov 01, 2017 3:04 pm
What's new in 6.41rc50 (2017-Oct-30 10:13):
Before an upgrade:
*) bridge - set "igmp-snooping=no" by default on new bridges;
*) dhcp-client - limited DHCP client "default-route-distance" minimal value to 1;
*) dhcp-server - added "option-set" argument (CLI only);
*) discovery - use "/interface list" instead of interface name under neighbor discovery settings;
*) health - fixed bogus voltage readings on CCR1009;
*) ike1 - fixed crash after downgrade if DH groups 19,20,21 were used for phase1;
*) ike1 - fixed crash on xauth if user does not exist;
*) ipv6 - fixed IPv6 addresses constructed from prefix and static address entry;
*) lte - added Passthrough support;
*) lte - fixed user authentication for R11e-LTE when new firmware is used;
*) m11g - improved ethernet performance on high load;
*) netinstall - fixed missing "/flash/etc" on first bootup;
*) quickset - renamed router IP static DNS name to "router.lan"
*) radius - limited RADIUS timeout maximum value to 3 seconds;
*) sms - fixed minor problem for SMS delivery;
*) webfig - added favicon file;
*) webfig - fixed terminal graphic user interface under Safari browser;
*) winbox - do not show unnecessary tabs from "Switch" menu;
*) wireless - new driver with initial support for 160 and 80+80 MHz channel width;
jondavy
Wed Nov 01, 2017 7:40 pm
do not do this, our system on average 1~5 seconds to process the radius package
please leave this field customizable
doneware
Trainer
Trainer
Thu Nov 02, 2017 3:26 am
stop right there. this stuff above literally translates to wave2, right?
#TR0359
brwainer
Thu Nov 02, 2017 6:07 am
I thought 802.11ac Wave2 was MU-MIMO as well as 160MHz / 80+80MHz channels? And to date, I believe all the the wireless chipsets that Mikrotik has shipped in products are Wave1. But maybe this is a little accidental show-of-hand towards new products, which of course would need software support.
nz_monkey
Thu Nov 02, 2017 8:03 am
Wave2 you say... You mean like this:
https://fccid.io/TV7CPGI5ACD2ND/Interna ... os-3602640
:D
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Mackiavelly
Thu Nov 02, 2017 12:50 pm
a very bad idea, this field generally needs to remove the limits, so that I myself can set the desired value, for example, even 15-20 seconds
ivanfm
Thu Nov 02, 2017 1:18 pm
We also have to use 5 seconds.
mducharme
Trainer
Trainer
Thu Nov 02, 2017 5:46 pm
We currently have to use 6 seconds for RADIUS timeout in many cases - a limit of 3 seconds is not enough.
We have some sites on bidirectional satellite links with local PPPoE servers - in case a UDP accounting packet was missed and the RADIUS server thinks the customer trying to log in was already logged in (ex. sharing their credentials with a neighbor), it has to connect to the router to pull the list of PPPoE interfaces via SNMP to see if the customer is actually still logged in before sending a reply. Due to the satellite link, this process takes up to 6000 ms.
juliokato
Thu Nov 02, 2017 6:14 pm
just wanted to understand who thought the 3-second limit is enough.
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
idlemind
Thu Nov 02, 2017 6:20 pm
Yup, seems like MT was overstepping. Seems like something that should be a default value adjustment that is still configurable.
mhugo
Thu Nov 02, 2017 7:25 pm
Is it just me or did the new bridge implementation just vanish in 6.41rc50 - On CRS212-1G-10S-1S+ Im back with masterports and no hardware offload in menu?
/Mikael
cmekcik
Thu Nov 02, 2017 9:38 pm
/Mikael
having the same issue on CRS317. i use classic RouterOS vlan trunking on crs317 because i can not pass VLANs to routers with current version of RouterOS
BTW anybody share you config for this situation (VLANs from current to RC). documentation about CRS317 is like "Warning: This article applies to CRS1xx and CRS2xx series switches and not to CRS3xx series switches."
cmekcik
Thu Nov 02, 2017 9:40 pm
del
stackflow
Fri Nov 03, 2017 7:33 am
When would the final version to be released?
Does the hardware off-load feature supports wireless bridging of HAP AC PRO?
upower3
Fri Nov 03, 2017 2:49 pm
Just wanted to tell you guys implementing very good thing, but new RC seems to be very long in development so far. It is not common to see 50 (!) RCs per release (and not yet 6.41 released this far), and this looks like it will be just dangerous to install in into prod for too many changes (beside new bridge implementation).
Would you mind to hear if I ask you to introduce two releases at the end: say, 6.41 with all changes but without new bridge implementation (so new changes will be tested beside all mess that can be involved with new bridging) , and another one, say 6.42 (or 6.411) with just bridge 'revolution'? This appears to be wise to monitor the effect of new bridge implementation without any other changes. Just in case, you know!
idlemind
Fri Nov 03, 2017 4:00 pm
They've done that already. This was initially implemented in 6.40 (rc36 I believe) and and then pulled for 6.40 stable. I really don't think it will be necessary to that again.
I don't disagree with you that upgrading production environments will be precarious at best. This is a big change. That said with solid for thought and good evaluation of your configs you should be able to identify ways to safely perform the upgrade. An example would be pulling a port out of the bridge (switch chip) as a stand alone routed port. This would protect you from the conversion code. This could directly connect to another network path or simply be an Ethernet port you can plug a laptop into in a hurry.
JimmyNyholm
Fri Nov 03, 2017 4:27 pm
+1 we are using OTP that validates a bit slow sometimes we want 10 seconds... Don't do this.
upower3
Fri Nov 03, 2017 10:26 pm
Done what? In released version? With no roll back? Hey, you must be kidding me! :)
What I talk about is the we shoudl split new bridge implementation from all these other changes, for good reason: bridge change is BIG one so this alone should be tested very serious. When it comes to big RB-based network, we'd want to check any consequnces and react accordingly. 6.40rc36 introduced h/w bridging but then it was rolled back, so no tests in the wild was done.
6.42 is full of other changes. This is why if you just upgrade RB to 6.42, you'll never know whay caused problem should they arise: new h/w bridge code or any of these changes you can see in the changelog.
And yes, when it comes to upgrade, say, 100 remote devices, I'd prefer to turn on serious new feature one at the time, don't you like this approach?
I do appreciate MT for their passion to create better platform but big changes is something risky, so isolating BIG changes is kind of good idea, I think.
skuykend
Fri Nov 03, 2017 10:44 pm
They had some of the new bridge code in 6.40rc and reverted it for the final 6.40, then put it back in for 6.41rc. At this point a lot of their new devices are starting to rely on it though.
6.39rc went up to rc80, sometimes it takes a while to get it done.
There is also a bugfix only channel (currently at 6.39.3) which may be more stable for production implementations, so they have given other options.
idlemind
Fri Nov 03, 2017 10:52 pm
Yes, look at the forum thread for 6.40rc, in 6.40rc36 the new bridge implementation was introduced. It was reverted in 6.40rc41 so that 6.40 could be released to stable without it. We are now in 6.41rc and it is here to stay. In that release you got exactly what you were asking for. The bridge was brought in, you should've installed it, tried out and then when 6.40 went into production you'd get the old master implementation back. The way this particular change works, it's very difficult to keep both implementations in the code base and swap between them especially without introducing new confusion and issues.
To your point about feature isolation during upgrades. Network engineers are categorically terrible at this. I can't tell you how many devices I touch that have the firmware that was shipped on them still. The mentality of "but it works" just doesn't cut it. This turns into devices that are hacked with multiple year old vulnerabilities.
With that in mind do you mean to tell me that when you upgrade your Linux kernel you break out any major feature and only compile that single feature into your existing code-base, test for 6 months and then bring in other maintenance fixes? I guarantee you don't. Get real, updates are fast and frequent now.
You are literally asking MikroTik to maintain 2 branches of code, 1 with the new bridge and 1 without. At some point they'd have to reconcile any patch from 1 branch to the other. While version control tools definitely make this possible it's a stupid level of work especially when most customers need more than just the new bridge code. Not to mention all of the interdependent code. I for one wouldn't want my new bridge branch to be frozen and not get updates for 6 months just like I wouldn't want to stay on the old architecture just for updates only to be forced to flash cut over at some point in the future. While this branch management works and is used for some projects the common idea is that feature is merged into the rest of the changes for a particular release. That's industry standard across projects a lot bigger than RouterOS code wise. At some point reconciliation of code has to happen, it might as well be as early as possible. It's easy to pull a patch in a version control system and have a new build released or just fix the bug forward.
TLDR; the bridge is here to stay barring any catastrophic issues. I'd grab a test router of each model you have in production and start practicing the upgrade. Call the bugs out now, early, so you don't have to be submitting cases at midnight to MikroTik when you do try. I know change is hard and scary but with a robust testing process it can be far less scary. If you have a lot of hardware of various models and configurations across a big infrastructure you may want to take a look at a tool like Quali. It can be leveraged to build automated testing scenarios in a fashion that is commonly seen in the software world (automated build and release testing with a tool like Jenkins). The better your tests the safer every upgrade going forward will be.
amorsen
New bridge keeps IP addresses up
Sat Nov 04, 2017 12:32 am
If you start with the standard configuration, ether2 has ether3-5 as slave ports, and none of the ports ether2 through ether5 have cables attached, any IP addresses assigned to ether2 will be inactive. After the upgrade to rc and the switch to the new bridge implementation, any addresses assigned to a bridge interface are always active, even if all ports are down.
This may seem like a trivial difference, but in our case it isn't. When a customer is moving sites, we can give them a router on the new site with the same LAN IP addresses as the old site. The addresses will not become active until someone actually plugs equipment into the router, but in the meantime we can test that the WAN link performs correctly. As soon as the customer is ready, often on a weekend or at night or some other time when I would rather avoid working, they move their equipment from the old site to the new site, and everything just works.
After the upgrade, that workflow breaks, and I or someone else has to be ready to configure the new router at precisely the moment the customer moves their equipment.
Please make an option to keep the bridge interface down until at least one port is active.
Cha0s
Forum Veteran
Forum Veteran
Sat Nov 04, 2017 1:08 am
Has the routerboot firmware version naming changed in 6.41rc?
I put 6.41rc50 on a couple of routerboards to try it out and I see the routerboot firmware version can be upgraded to '6.41rc50' from 3.xx.
A huge jump! I don't recall seeing this in any of the changelogs for 6.41rc.
If routerboot firmware now follows the ROS version, I would very much like it to automatically get upgraded too during the upgrade of ROS.
Or at least give the user an option to do that in one go.
Having to do double reboots on every upgrade would not be very convenient :)
It would also be nice to keep the routerboot changelog up to date, or include the changes into ROS changelog itself (since you get the fw update via ROS anyway).
https://wiki.mikrotik.com/wiki/RouterBOOT_changelog
andriys
Sat Nov 04, 2017 11:49 am
Yes, it has. It happened in 6.41rc47 (see here):
I'd rather vote for keeping it separate. I believe it's simply safer, and if you have a boot-loop you will at least have an idea of what failed- loader or OS.
Cha0s
Forum Veteran
Forum Veteran
Sat Nov 04, 2017 2:48 pm
I missed that entry in the changelog :oops:
That's why I specifically mentioned to have it as an option.
Personally I've upgraded tons of routerboards' routerboot firmware over the years. I've never ever had a single issue with it nor I've ever read anyone else having a bootloop or any other problem with routerboot firmware.
upower3
Sat Nov 04, 2017 7:48 pm
I know that. I'm awre of new bridge implementation and keep my eyes on it, but you missed the point: when MT ships the release I'd prefer to keep two releases, one with just new bridging, another one with the rest of current changelog but without bridging (or in reversed order, first one with just changes, then with just bridge).
I've played with 6.40rc36 a bit but I can not take it for granted that it shown me the same behavior of system that it will be in the release so I can not rely on my observations. There are several side effects connected with new bridges, so customers need to do some tests an d may want to distinguish between effects from bridge and from other changelog entries (the changelog is huge this time, isn't it?)
upower3
Sat Nov 04, 2017 7:56 pm
...and yes, maybe I missed that, but I'd love to know the exact algorithm ROS will use to convert master-slave port configs into bridge-based one, and which changes be done as well to the whole config. If, for example, I have some routes that targeted to port name, will it be substituted with newly created bridge name?
It'll be wise to state that in some reference document and maybe discuss it so those who use RBs in large scale may predict what'll be done.
Else some companies/users may ban the upgrade to newly version for their older infrastructure, just to be on the save side. This appears risky, to do that step without any rollback possibility (so you may lost you remote device).
eworm
Sun Nov 05, 2017 2:09 am
For me the more important question about boot firmware is: Will the firmware version change with every RouterOS release even if no changes are made? Suppose you installed RouterOS 6.41, then upgraded firmware to 6.41. RouterOS 6.41.1 ships with no changes to the firmware. Is the available firmware version 6.41 or 6.41.1?
upower3
Sun Nov 05, 2017 7:32 am
Good question. If you look at f/w changelog you'll notice there is not that many changes that affects your device. So apply each firmware upgrade released is an overkill, and should be bound to specific models.
At the same time, I've never heard about need to downgrade the f/w.
So I'd like to have a noitification inside ROS, that for my hardware I should upgrade firmware, and if my hardware if unaffected then why should I do that f/w upgrade?
anuser
Mon Nov 06, 2017 8:50 pm
So, is this an updated driver (kernel module) from the ASIC vendor (e.g. Atheros) which has also some bugfixes/features from the vendor?
biatche
Tue Nov 07, 2017 2:33 pm
at the moment, is bridge+vlan still cli only?
is the new bridge implementation without issues now?
upower3
Tue Nov 07, 2017 2:38 pm
I'd say we'll when 1) it'll be released and 2) when we'll live with it at least several releases.
Just to be on the safe side.
strods
Tue Nov 07, 2017 3:20 pm
What's new in 6.41rc52 (2017-Nov-07 08:48):
Before an upgrade:
*) hotspot - fixed Walled Garden IP functionality when address-list is used;
*) ovpn-server - do not periodically change automatically generated server MAC address;
*) poe - added new "poe-out" status "controller-error";
*) poe - fixed false positive excessive logs in auto-on mode when connected to 100 Mbps device powered from another power source;
*) poe - log PoE status related messages under debug topic;
*) ppp - do not disconnect PPP connection after "idle-timeout" even if traffic is being processed;
*) quickset - added support for "/interface list" in firewall, neighbor discovery, MAC-Telnet and MAC-Winbox;
*) quickset - fixed situation when Quickset automatically changes mode to CPE;
*) w60g - general work on PtMP implementation for 60 GHz connections;
*) wireless - added "indonesia3" regulatory domain information;
*) wireless - added passive scan functionality (CLI only);
fposavec
Tue Nov 07, 2017 3:41 pm
Any info on this?
soulflyhigh
Tue Nov 07, 2017 3:51 pm
Any info on this?
It does scan but it isn't passive.
"/interface wireless> scan 0 passive=yes" and the wlan is disconnected immediately.
@Mikrotik
Is this the same issue that this works only with pure 802.11 protocol and not with nstreme and nv2?
Regards,
M.
MTCRE, MTCTCE, MTCSE
idlemind
Tue Nov 07, 2017 5:21 pm
Before an upgrade:
!) detnet - implemented "/interface detect-internet" feature;
https://wiki.mikrotik.com/wiki/Manual:Detect_internet
MikroTik Support Number: 2017110722001161
Client devices affected for sure: Roku 3 (2.4GHz), Motorola G Gen3 (2.4GHz)
After upgrading one of my WAP AC's to 6.41rc50 from 6.41rc44 this has been happening. I'll be trying 6.41rc52 to see if it resolves the issue before reverting back to 6.41rc44.
nov/06 18:36:22 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
nov/06 18:37:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 18:37:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 18:37:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
nov/06 18:37:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
nov/06 18:37:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 18:51:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 18:51:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 19:04:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
nov/06 19:04:24 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, group key exchange timeout
nov/06 19:04:39 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -90
nov/06 19:04:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -61
nov/06 19:35:22 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -65
nov/06 19:35:22 wireless,info E8:DE:27:14:C5:39@wlan1: disconnected, registered to other interface
nov/06 19:54:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
nov/06 19:54:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 19:54:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 19:54:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 20:02:20 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:02:20 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -77
nov/06 20:05:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:05:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -68
nov/06 20:09:24 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, group key exchange timeout
nov/06 20:09:34 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -80
nov/06 20:09:36 wireless,info AC:18:26:4C:A6:EC@wlan1: reassociating
nov/06 20:09:36 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, ok
nov/06 20:09:36 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -75
nov/06 20:09:41 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, unicast key exchange timeout
nov/06 20:10:00 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -76
nov/06 20:10:15 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:10:16 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 20:10:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 20:10:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
nov/06 20:10:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received deauth: class 2 frame received (6)
nov/06 20:10:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -61
nov/06 20:19:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:19:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 20:19:24 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, group key exchange timeout
nov/06 20:19:29 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 20:20:47 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 20:20:50 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -82
nov/06 20:22:32 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:22:32 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -75
nov/06 20:27:05 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:27:11 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
nov/06 20:27:16 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 20:27:25 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 20:29:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
nov/06 20:29:25 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 20:31:39 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:31:44 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 20:34:24 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, group key exchange timeout
nov/06 20:34:44 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -79
nov/06 20:34:47 wireless,info AC:18:26:4C:A6:EC@wlan1: reassociating
nov/06 20:34:47 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, ok
nov/06 20:34:47 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -84
nov/06 20:34:52 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, unicast key exchange timeout
nov/06 20:35:28 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -76
nov/06 20:36:51 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:36:52 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 20:36:57 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
nov/06 20:36:57 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
nov/06 20:36:57 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 20:39:11 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:39:11 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 20:48:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 20:49:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 21:33:26 wireless,info E8:DE:27:14:C5:39@wlan2: reassociating
nov/06 21:33:26 wireless,info E8:DE:27:14:C5:39@wlan2: disconnected, ok
nov/06 21:33:26 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -65
nov/06 21:44:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
nov/06 21:44:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
nov/06 21:44:27 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -72
nov/06 21:44:27 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -60, wants bridge
nov/06 21:44:31 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
nov/06 21:44:31 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
nov/06 21:44:31 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 21:45:54 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 21:45:54 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 21:49:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
nov/06 21:49:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
nov/06 21:49:25 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
nov/06 21:49:26 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -59, wants bridge
nov/06 21:53:43 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 21:53:44 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 21:57:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 21:57:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 22:01:16 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:01:17 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 22:01:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 22:01:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 22:04:36 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:04:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 22:04:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
nov/06 22:04:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
nov/06 22:04:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 22:07:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:07:25 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 22:11:45 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:11:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 22:11:51 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 22:11:51 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 22:11:51 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received deauth: class 2 frame received (6)
nov/06 22:12:04 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 22:19:15 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:19:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -59
nov/06 22:19:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 22:19:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 22:31:40 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:31:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -75
nov/06 22:39:04 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:39:05 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -69
nov/06 22:39:10 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 22:39:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 22:51:22 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 22:51:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 22:59:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
nov/06 22:59:24 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, group key exchange timeout
nov/06 22:59:40 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -76, wants bridge
nov/06 23:03:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:03:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
nov/06 23:03:29 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:03:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -61
nov/06 23:12:12 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:12:13 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -68
nov/06 23:12:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
nov/06 23:12:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
nov/06 23:12:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 23:12:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:12:31 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
nov/06 23:15:43 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -71
nov/06 23:16:00 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:16:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
nov/06 23:16:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:16:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -72
nov/06 23:16:29 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:16:48 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
nov/06 23:16:50 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -44
nov/06 23:17:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 23:17:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
nov/06 23:17:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
nov/06 23:17:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -72
nov/06 23:17:11 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:17:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -75
nov/06 23:18:50 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:18:56 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 23:19:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:19:14 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 23:19:19 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:19:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:19:28 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 23:20:15 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:20:16 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
nov/06 23:20:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:20:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 23:21:08 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:21:09 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 23:24:49 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:24:53 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -52
nov/06 23:24:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -61
nov/06 23:25:39 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -64
nov/06 23:28:13 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -52
nov/06 23:28:28 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:28:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
nov/06 23:28:47 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
nov/06 23:29:04 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -50
nov/06 23:29:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
nov/06 23:29:24 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, group key exchange timeout
nov/06 23:29:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:29:36 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:29:58 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -69, wants bridge
nov/06 23:30:00 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
nov/06 23:30:09 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -60
nov/06 23:30:12 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -79
nov/06 23:30:15 wireless,info AC:18:26:4C:A6:EC@wlan1: reassociating
nov/06 23:30:15 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, ok
nov/06 23:30:15 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -83
nov/06 23:30:17 wireless,info AC:18:26:4C:A6:EC@wlan1: reassociating
nov/06 23:30:17 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, ok
nov/06 23:30:17 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -79
nov/06 23:30:18 wireless,info AC:18:26:4C:A6:EC@wlan1: reassociating
nov/06 23:30:18 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, ok
nov/06 23:30:18 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -82
nov/06 23:30:23 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, unicast key exchange timeout
nov/06 23:30:43 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
nov/06 23:33:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:33:59 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
nov/06 23:34:04 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:34:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
nov/06 23:34:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:34:29 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -59
nov/06 23:34:40 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -64, wants bridge
nov/06 23:35:01 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -78
nov/06 23:35:06 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, unicast key exchange timeout
nov/06 23:35:33 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -74
nov/06 23:35:34 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, received deauth: class 2 frame received (6)
nov/06 23:38:46 wireless,info AC:18:26:4C:A6:EC@wlan1: connected, signal strength -77
nov/06 23:38:53 wireless,info AC:18:26:4C:A6:EC@wlan1: disconnected, unicast key exchange timeout
nov/06 23:39:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:40:18 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -64
nov/06 23:40:39 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
nov/06 23:41:50 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -59
nov/06 23:42:22 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
nov/06 23:42:24 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -50
nov/06 23:43:00 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
nov/06 23:43:13 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
nov/06 23:44:07 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:44:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:44:30 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 23:45:29 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
nov/06 23:45:49 wireless,info E8:DE:27:14:C5:39@wlan2: reassociating
nov/06 23:45:49 wireless,info E8:DE:27:14:C5:39@wlan2: disconnected, ok
nov/06 23:45:49 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -65
nov/06 23:45:49 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -64
nov/06 23:45:49 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -67
nov/06 23:46:01 wireless,info E8:DE:27:14:C5:39@wlan1: connected, signal strength -66
nov/06 23:46:01 wireless,info E8:DE:27:14:C5:39@wlan2: disconnected, registered to other interface
nov/06 23:49:29 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:49:34 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
nov/06 23:52:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
nov/06 23:53:21 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -45
nov/06 23:54:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:54:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
nov/06 23:55:00 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:55:32 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
nov/06 23:55:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
nov/06 23:56:32 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
nov/06 23:58:28 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -44
nov/06 23:59:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
nov/06 23:59:31 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
00:02:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:02:47 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
00:02:53 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
00:02:54 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
00:04:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:04:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
00:06:40 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:07:22 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
00:09:15 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -43
00:09:20 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, unicast key exchange timeout
00:09:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
00:09:28 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -71, wants bridge
00:10:51 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -46
00:11:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:11:56 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
00:12:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
00:12:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
00:12:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -73
00:12:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
00:12:28 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
00:12:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
00:13:25 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:13:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
00:13:28 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
00:13:59 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:14:00 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
00:17:05 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -52
00:17:10 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, unicast key exchange timeout
00:17:19 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:17:44 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -87
00:17:44 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
00:18:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -76
00:18:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
00:18:20 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
00:20:29 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
00:25:26 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
00:25:39 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
00:25:47 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -78
00:28:09 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:29:09 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
00:31:50 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
00:33:04 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:33:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
00:34:43 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
00:36:37 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
00:36:45 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:36:50 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
00:36:58 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
00:41:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:41:47 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
00:41:52 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
00:42:28 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
00:43:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:43:32 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
00:43:59 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
00:44:06 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -75
00:44:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
00:44:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
00:44:29 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:44:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
00:44:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
00:44:42 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -69, wants bridge
00:44:43 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
00:47:02 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:47:07 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
00:49:05 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
00:51:33 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:51:39 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
00:58:36 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
00:59:20 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
00:59:25 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
00:59:29 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -79
01:00:36 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
01:04:15 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
01:05:30 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:05:31 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -67
01:05:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
01:05:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
01:05:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -59
01:09:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:09:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -61
01:09:51 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -66
01:12:10 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:12:16 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
01:14:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
01:16:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:16:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -60
01:16:53 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -65
01:19:15 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
01:19:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
01:19:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
01:19:24 wireless,info E8:DE:27:14:C5:39@wlan1: disconnected, group key exchange timeout
01:19:39 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -65, wants bridge
01:19:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
01:20:00 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -65
01:20:16 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -68
01:20:32 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:21:10 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
01:21:15 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
01:21:33 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
01:24:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
01:26:12 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:26:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -61
01:26:48 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
01:26:58 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
01:28:41 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
01:31:10 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -66
01:31:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:32:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -58
01:32:06 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
01:32:33 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
01:32:36 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
01:32:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: reassociating
01:32:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, ok
01:32:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
01:32:40 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
01:34:36 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:34:37 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
01:35:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:35:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -68
01:37:39 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -67
01:39:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:39:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
01:39:26 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
01:40:44 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:40:45 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
01:41:44 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -66
01:43:01 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
01:43:39 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
01:43:44 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
01:43:46 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
01:44:02 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
01:51:20 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
01:56:28 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
02:03:30 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
02:07:27 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -66
02:08:36 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
02:09:04 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
02:12:32 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
02:13:26 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
02:13:35 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
02:13:40 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -59
02:16:29 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
02:21:36 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
02:24:24 wireless,info 10:02:B5:B0:AD:47@wlan2: disconnected, group key exchange timeout
02:28:10 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -69
02:29:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
02:33:33 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -66
02:34:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
02:41:05 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
02:41:10 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
02:41:15 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
02:44:55 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -63
02:46:23 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
02:47:47 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
02:47:53 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
02:49:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
02:51:07 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
02:51:08 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -58
02:53:25 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
02:54:24 wireless,info 00:0F:60:08:1F:5B@wlan1: disconnected, group key exchange timeout
02:54:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
02:54:28 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
02:56:09 wireless,info 00:0F:60:08:1F:5B@wlan1: connected, signal strength -53
02:56:14 wireless,info 00:0F:60:08:1F:5B@wlan1: disconnected, unicast key exchange timeout
02:56:15 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
02:56:38 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
02:58:35 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
02:59:25 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -66
03:04:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
03:04:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
03:04:36 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
03:07:12 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
03:10:22 wireless,info 00:0F:60:08:1F:5B@wlan1: connected, signal strength -55
03:12:23 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
03:15:39 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
03:17:00 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
03:17:19 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
03:22:30 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
03:31:02 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
03:32:36 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
03:34:45 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
03:36:05 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -70
03:39:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
03:39:50 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
03:46:38 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
03:48:09 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
03:50:55 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
03:50:56 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
03:51:43 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
03:52:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
03:52:48 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
03:55:40 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
03:55:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
04:04:20 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -61
04:04:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
04:04:24 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
04:04:28 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
04:07:16 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -80
04:09:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
04:09:29 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
04:19:36 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -78
04:19:37 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
04:28:35 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
04:33:40 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
04:34:46 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -65
04:40:34 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
04:40:37 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -82
04:47:01 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
04:52:10 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
04:56:33 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -65
05:01:40 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
05:10:05 wireless,info B8:A1:75:48:3C:29@wlan1: connected, signal strength -64
05:10:10 wireless,info B8:A1:75:48:3C:29@wlan1: disconnected, unicast key exchange timeout
05:10:42 wireless,info B8:A1:75:48:3C:29@wlan1: connected, signal strength -76
05:11:48 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -81
05:11:51 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
05:14:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
05:14:37 wireless,info B8:A1:75:48:3C:29@wlan1: disconnected, received disassoc: sending station leaving (8)
05:14:38 wireless,info B8:A1:75:48:3C:29@wlan1: connected, signal strength -75
05:16:33 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -72
05:16:48 wireless,info B8:A1:75:48:3C:29@wlan1: disconnected, received disassoc: sending station leaving (8)
05:17:48 wireless,info B8:A1:75:48:3C:29@wlan1: connected, signal strength -69
05:17:53 wireless,info B8:A1:75:48:3C:29@wlan1: disconnected, unicast key exchange timeout
05:18:04 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
05:18:25 wireless,info B8:A1:75:48:3C:29@wlan1: connected, signal strength -86
05:19:48 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
05:19:48 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
05:20:17 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
05:20:26 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -77
05:22:44 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -63
05:23:35 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -75
05:25:54 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
05:25:54 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -62
05:27:52 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
05:31:33 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -84
05:31:33 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
05:44:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
05:46:52 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -64
05:48:56 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -64
05:49:54 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
05:49:57 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -78
05:50:02 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
05:50:09 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -81
05:54:05 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
05:55:14 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
05:56:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -64
05:56:28 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
05:56:39 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -80
05:56:42 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -71
05:56:42 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
05:56:45 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
05:56:47 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
05:56:48 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -78
05:56:49 wireless,info B8:A1:75:48:3C:29@wlan1: disconnected, extensive data loss
05:57:00 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -74
05:57:05 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
05:57:22 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
05:57:23 wireless,info DC:3A:5E:95:9B:BF@wlan2: connected, signal strength -77
06:01:07 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -78
06:01:07 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
06:02:37 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -73
06:03:37 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
06:04:01 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -65
06:09:12 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
06:13:16 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
06:16:31 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
06:16:39 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -79
06:17:02 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -73
06:17:03 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
06:18:00 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -75
06:18:21 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
06:19:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
06:23:34 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -80
06:24:23 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
06:24:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
06:24:34 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -72
06:26:38 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, received deauth: sending station leaving (3)
06:26:41 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -83
06:33:36 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -87
06:41:37 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
06:44:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
06:44:29 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -65, wants bridge
06:46:41 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
06:49:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
06:49:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
06:49:26 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -68, wants bridge
06:49:34 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -76
06:54:24 wireless,info 00:0F:60:08:1F:5B@wlan1: disconnected, group key exchange timeout
06:54:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
06:54:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
06:54:28 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -67, wants bridge
06:54:54 wireless,info 00:0F:60:08:1F:5B@wlan1: connected, signal strength -55
07:00:00 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -72
07:00:32 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
07:00:33 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -73
07:01:08 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
07:01:21 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -79
07:08:28 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -62
07:09:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
07:09:25 wireless,info E8:DE:27:14:C5:39@wlan2: reassociating
07:09:25 wireless,info E8:DE:27:14:C5:39@wlan2: disconnected, ok
07:09:25 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -65
07:11:52 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -70
07:13:59 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, received disassoc: sending station leaving (8)
07:16:38 wireless,info 68:C4:4D:EE:F0:DF@wlan1: connected, signal strength -84
07:16:41 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, registered to other interface
07:16:57 wireless,info 68:C4:4D:EE:F0:DF@wlan2: connected, signal strength -87
07:16:57 wireless,info 68:C4:4D:EE:F0:DF@wlan1: disconnected, registered to other interface
07:17:05 wireless,info 68:C4:4D:EE:F0:DF@wlan2: disconnected, extensive data loss
07:19:24 wireless,info 00:0F:60:08:1F:5B@wlan1: disconnected, group key exchange timeout
07:19:24 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
07:19:24 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
07:19:26 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -58
07:19:26 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -66, wants bridge
07:19:56 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
07:19:58 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -55
07:20:10 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
07:20:18 wireless,info 00:0F:60:08:1F:5B@wlan1: connected, signal strength -54
07:20:55 wireless,info 2C:F0:A2:1F:56:4B@wlan2: connected, signal strength -61
07:24:24 wireless,info 2C:F0:A2:1F:56:4B@wlan2: disconnected, group key exchange timeout
08:52:30 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -65
08:53:11 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, received deauth: sending station leaving (3)
08:54:58 wireless,info 2C:F0:A2:1F:56:4B@wlan1: connected, signal strength -79
08:56:18 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -76
08:56:51 wireless,info E8:DE:27:14:C5:39@wlan2: disconnected, extensive data loss
08:57:22 wireless,info 10:02:B5:B0:AD:47@wlan2: connected, signal strength -70
08:57:30 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -62
Update, problem persists in 6.41rc52.
09:39:09 system,info verified routeros-mipsbe-6.41rc52.npk
09:39:09 system,info installed routeros-mipsbe-6.41rc52
09:39:09 system,info router rebooted
09:39:12 bridge,info "br1" mac address changed to F6:20:18:E8:60:F6
09:39:15 wireless,info F4:30:B9:B3:0F:ED@wlan1: connected, signal strength -59
09:39:16 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
09:39:16 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -69, wants bridge
09:39:21 wireless,info 00:0F:60:08:1F:5B@wlan1: connected, signal strength -54
09:39:23 wireless,info B8:3E:59:B3:9B:0B@wlan2: connected, signal strength -46
09:39:24 interface,info ether1 link up (speed 1G, full duplex)
09:39:33 wireless,info E8:DE:27:14:C5:39@wlan2: connected, signal strength -65
09:40:00 wireless,info E8:DE:27:14:C5:39@wlan2: disconnected, received deauth: sending station leaving (3)
09:40:11 system,info,account user admin logged in from 10.211.11.11 via ssh
09:40:13 wireless,info 10:02:B5:B0:AD:47@wlan2: connected, signal strength -70
09:41:47 system,info cloud change time Nov/07/2017-09:40:30 => Nov/07/2017-09:41:47
09:43:21 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, received disassoc: sending station leaving (8)
09:43:27 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -70
09:44:37 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -68
09:44:42 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, unicast key exchange timeout
09:44:46 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -70
09:44:51 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, unicast key exchange timeout
09:45:13 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -73
09:45:36 wireless,info F4:30:B9:B3:0F:ED@wlan1: disconnected, group key exchange timeout
09:45:36 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, group key exchange timeout
09:45:36 wireless,info 6C:3B:6B:EB:59:99@wlan1: disconnected, group key exchange timeout
09:45:36 wireless,info 84:10:0D:B0:12:8F@wlan1: disconnected, group key exchange timeout
09:45:51 wireless,info 6C:3B:6B:EB:59:99@wlan1: connected, signal strength -69, wants bridge
09:45:55 wireless,info 84:10:0D:B0:12:8F@wlan1: connected, signal strength -79
09:46:00 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -66
09:46:05 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
09:46:46 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
09:46:51 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
09:48:18 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -72
09:48:23 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
09:49:04 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
09:49:09 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
09:49:22 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -63
09:49:27 wireless,info DC:3A:5E:95:9B:BF@wlan1: disconnected, unicast key exchange timeout
09:49:41 wireless,info DC:3A:5E:95:9B:BF@wlan1: connected, signal strength -65
Final Update: Reverting to 6.41rc44 fixed my issues. I'll wait until >6.41rc52 before trying again on those devices. 6.41rc52 is functioning fine on my test 750Gr3 though (no wifi chips there).
strods
Re: v6.41rc [release candidate] is released! New bridge implementation!
Tue Nov 07, 2017 11:34 pm
RADIUS timeout value was reduced due to the fact that there is no point of higher value than 3s. Neither of RouterOS RADIUS services would wait more than 3s for a reply from RADIUS server. If you had value higher than 3 seconds, then either configuration will work with timeout set to 3s or it was not working properly even with higher value.
Anyway, RADIUS timeout (even set to 3s) is too high and requires debugging and network improvements since router should not wait so long for a reply from RADIUS server.
eworm
Wed Nov 08, 2017 12:18 am
RouterOS 6.41rc52 ships with firmware version 6.41rc50... So looks like nothing changed except the version bump.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
idlemind
Wed Nov 08, 2017 6:44 pm
Or people had other RADIUS services (devices) connecting to it. You know, because that never happens. #genius. Depending on the IOS version Cisco will timeout at 5 seconds. MikroTik employees. If you are confronted with the choice between allowing something to be configurable with a sensible default vs a static unchanging value always choose configurable.
Cha0s
Forum Veteran
Forum Veteran
Wed Nov 08, 2017 7:49 pm
I've upgraded a mAP-Lite from 6.40.4 to 6.41rc52.
The firmware prior to the upgrade was on v3.41.
So it showed me that the upgrade firmware is 6.41rc50.
But after I upgraded the firmware I got this:
Current Firmware: 6.41rc52
Upgrade Firmware: 6.41rc50
http://prntscr.com/h7w38h
eworm
Wed Nov 08, 2017 10:44 pm
Oh, funny... I have a system that is running RouterOS 6.41rc52, with current and upgrade firmware at 6.41rc50. Started a firmware upgrade, after a reboot I can confirm your results.
Well, that will make my upgrade notification scripts go crazy... :-p
JimmyNyholm
Fri Nov 10, 2017 11:34 am
When do we get LACP with Hardware offload in this new bridge implementation in routeros on switch devices such as CRS326-24G-2S+ and CRS-317-1G-16s+
Creating a bond and attaching it to the bride is done in software now and good know the cpu's in the switches is weak as hell.
kamillo
Fri Nov 10, 2017 1:06 pm
To add to JimmyNyholm's comment: I'm still waiting for LACP hardware support (offload) in CRS125
biatche
Sat Nov 11, 2017 5:00 am
Forum police @andirys will probably ask you to post in feature request.
But yes, this is definitely needed in urgency.
ryba84
Sun Nov 12, 2017 3:38 pm
*) interface - added option to join and exclude "/interface list" from one and another;
How this works? Firewall is not using included list.
pe1chl
Mon Nov 13, 2017 10:37 am
The default firewall is using lists now. When you have upgraded from versions previous to 6.40 all the time and never
reset the configuration, your firewall is still using the old method. However, when you reset everything to defaults you
will find it uses lists WAN and LAN to identify the interfaces.
It depends on the amount of work you have put in your config if it is worth the trouble, of course.
ryba84
Mon Nov 13, 2017 6:36 pm
Firewall uses interface lists, and this work for long time. But in new implementation You can include list in list, to use "master" list in firewall. This isn't working as expected. When Vpn clients are connecting, their dynamic interfaces are added to vpn-clients list. This list is included in some other list, which is used in firewall. Firewall should automaticly use this dynamic list to filter/nat/etc.., but this doesn't happen. Interfaces only from "master" list are working.
Wysłane z mojego SM-J710F przy użyciu Tapatalka
mrz
Mon Nov 13, 2017 6:53 pm
@ryba84 report problem to support and attach supout rif file.
rac
Tue Nov 14, 2017 12:09 pm
I tryed to configure VLANs using the bridge hw offloading feature (CRS326). Basically:
add bridge=bridge interface=ether2 pvid=200
add bridge=bridge tagged=... untagged=ether02,.. vlan-ids=200
/interface bridge set bridge vlan-filtering=yes
I stuck in two tasks.
A) How to I secure the ports like "/interface ethernet switch port set ether3 vlan-mode=secure vlan-header=always-strip" on https://wiki.mikrotik.com/wiki/Manual:S ... Offloading?
I tried
/interface bridge port add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether03 pvid=200
but I do not really understand if it does what I want.
B) I cannot access the RouterOS using a VLAN port. But I didn't found, how to configure VLAN for the switch host port?
biatche
Tue Nov 14, 2017 7:47 pm
I tried
you need to add your bridge interface to tagged ports.
raffav
Tue Nov 14, 2017 10:03 pm
Hi
i am unable set a untagged management ip address using a RB450G and a CRS125
i had followed the wifi but i dont get it
any one can help
marekm
Wed Nov 15, 2017 12:05 am
*) w60g - general work on PtMP implementation for 60 GHz connections;
Devices in the Wireless Wire kit come with Level 3 licenses - will it work with more than one client, or is it necessary to buy a Level 4 license to test 60GHz PtMP?
biatche
Wed Nov 15, 2017 1:03 am
Been a long day.
I'm tasting my first time experience on 10gbit sfp+ on CRS326. I have a 10gbit nic (also first time) connected directly to the CRS326 and couldn't figure out why iscsi rates to a single client in my test environment were unstable 10-40MB/sec, at times less than 10MB/sec, FAR slower than gigabit nic. Rates are stable on the gigabit ports (80MB/sec). I tested samba transfers on the sfp+, and speeds appear quick. So it's just iscsi where transfer rates are quite quirky.
After a lot of testing, trying to figure out where the point of issue is -- ixgbe driver, iscsi initiator/target, etc etc.. it finally hit me it could be the 6.41 bridge implementation.
Simply reverting to 6.40.5 gave me good stable expected rates.
So I'm simply reporting that sfp+ DEFINITELY have some hw offload issues or some other sort of issues. Sorry if my feedback isn't as clear as can be.
I hope you fellas are able to solve this on your own because I will not be able to test this again as the switch will be in live production this week.
Update: Contacted support and MT is already aware of the issue.
blajah
Wed Nov 15, 2017 7:15 pm
For me the more important question about boot firmware is: Will the firmware version change with every RouterOS release even if no changes are made? Suppose you installed RouterOS 6.41, then upgraded firmware to 6.41. RouterOS 6.41.1 ships with no changes to the firmware. Is the available firmware version 6.41 or 6.41.1?
Same here, 951g2hnd
 routerboard: yes
             model: 951G-2HnD
     serial-number: 4F4********
     firmware-type: ar9344
  factory-firmware: 3.10
  current-firmware: 6.41rc52
  upgrade-firmware: 6.41rc50
I have bigger routing table.
pe1chl
Wed Nov 15, 2017 8:28 pm
I have installed it on an old RB750 I use for some test.
It shows:
Firmware type: ar7240
Factory firmware: 3.02
Current firmware: 3.33
Update firmware:
I.e. there is nothing after upgrade firmware and the upgrade button does nothing (no log entry).
Edit: I installed 6.40.5, upgraded the firmware to 3.41 from there, then went back to 6.41 (2 partitions on the router...) and
the issue is still the same.
eworm
Thu Nov 16, 2017 11:34 am
Possibly a read-only property "upgrade-available" is the easiest way to solve this?
kait
Thu Nov 16, 2017 11:53 am
Hi, I raise a new topic Bridge HW-Offload and VLAN-Filtering with CRS226-24G-2S+RM at v6.41rc52 here viewtopic.php?f=1&t=127805 , maybe someone can explain issue.
mducharme
Trainer
Trainer
Thu Nov 16, 2017 11:49 pm
This makes no sense to me whatsoever. We have had it happen several times (in a particular scenario documented further below) where we had the timeout at first set to 3000 ms and the customer could not connect (due to the unusually high latency for bidirectional satellite Internet), but immediately after increasing the timeout, the customer connected successfully (after repeated automated connection attempts up until the instant of change). You are saying this is a coincidence? It seems really hard to believe given how many times it failed before making the change (several hours) and how immediately the change corrected the issue (after hours of trying to connect every minute and failing, the first connection after the change (30 seconds later) was successful).
We are dealing with bi-directional satellite so we have 600ms latency just to get up into orbit and back again with a ping, and we are dealing with very limited bandwidth. We cannot do "network improvements" to fix this.
Here is the precise justification for why 3000 ms is not enough with all attainable 'network improvements' implemented:
The initial RADIUS request from the satellite site takes 300-400 ms to get to the radius server due to limitations of the speed of light, then it has to look up the customer etc, probably half a second or second later it sends a reply which takes another 300-400ms to get back to the satellite site (again due to the limitations of the speed of light). This is now two seconds. This part is fine with your new limit, but the next part is not:
If the RADIUS server thinks the customer is already logged in, it contacts the MikroTik with SNMP to find out if there is actually an interface named <pppoe-customername>, this contact begins to happen at around the 2000 ms mark.
At this point, the RADIUS server has to send the SNMP request over satellite, receive the SNMP response over satellite, parse the list to determine whether the customer is logged in or not, and send the Access-Accept or Access-Reject reply back to the MikroTik. This entire process cannot happen in 3000 ms total from the opening authentication, when the basic authentication already uses 2000ms, and where each one way satellite transit thereafter takes 300-400 ms due to the limitation of the speed of light.
Suggesting that we make "network improvements" to fix this is basically asking us to move the satellite in orbit closer to the planet, or make the speed of light faster. It is not something that we can do. We are already doing queueing everywhere to prioritize the RADIUS and SNMP requests. 3000 ms is just not enough when you start taking satellite setups like ours into account. We really need this change reverted, or at least a more reasonable maximum of 5000 or 6000ms used. We have fixed this issue successfully by increasing the timeout on our routers to 6000ms but you have removed this repair from us by limiting this setting.
pe1chl
Fri Nov 17, 2017 10:38 am
I would say your network could be redesigned so that the RADIUS requests do not have to go over the satellite. Apparently you are using the MikroTik as a local access concentrator for several customers that then use the same satellite link. It would help a lot to have the RADIUS service local to that location. Of course usermanager is very limited, but a small computer with a RADIUS server and maybe some other services for the customer (a webproxy, a local webserver, VoIP PBX, etc) could help the customers living with this high-latency link.
mducharme
Trainer
Trainer
Fri Nov 17, 2017 11:48 am
It is not just one location - we have 15 such locations. We would need 15 RADIUS servers. These locations have no air conditioning and so the internal shelter goes up to 40C in the summer and down to -30C in the winter. Local RADIUS server is NOT a good idea.
What am I supposed to do, go and tell my manager "yes, it is great that MikroTik is forcing us to buy 15 local RADIUS servers for 15 sites that will probably fail within a year or two due to inadequate environmental controls, all because they decided to limit an integer to 3000 that previously allowed 6000"??
Every time there is a failure at one of those 15 sites we have to fly in for a cost of more than a thousand dollars round trip. There are only usually between 2 and 15 customers at a given site, so in many cases we are losing money because what we charge customers in total is much less than what we have to pay for service; although we are a non profit we should still be trying at least to break even.
Putting in a local RADIUS server is not a good solution, so if this is not reverted, we will need to stay at RouterOS 6.40.x and under permanently at 15 sites, never being able to upgrade. This makes me a bit nervous, but is preferable to the alternative of having to buy 15 RADIUS servers each of which will be put in remote areas in outdoor shelters with no environmental controls.
Chupaka
Fri Nov 17, 2017 12:03 pm
One more solution: if it works good - do not upgrade :)
Worked for me when MikroTik broke VLANs over bonding :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
biatche
Fri Nov 17, 2017 12:35 pm
I atest to mducharme's complaints. There's no harm reverting the RADIUS timeout value change is there? Could issue a warning of some sort for those who set values in excess of recommended.
Waiting for MT's good news now.
mducharme
Trainer
Trainer
Fri Nov 17, 2017 9:48 pm
FYI, Cisco docs say the maximum RADIUS timeout on their gear is 1000 seconds. Juniper maximum is 90 seconds. Both seem a bit extreme, but that just shows how far from a 3 second maximum other vendors are.
idlemind
Fri Nov 17, 2017 10:00 pm
These complaints are exactly why arbitrary hard setting a value is bad when it can be valid within a range. This includes what a developer personally feels is acceptable.
neg2led
Sat Nov 18, 2017 4:58 am
I think we might be missing the forest for the trees here, guys.
MT say that the reduction here shouldn't make a difference. In this post by strods from page 7, strods says that neither of the routerOS RADIUS client processes will wait more than 3 seconds even if the timeout setting is greater than 3 seconds - important part in bold for emphasis;
Ignoring the part about RADIUS taking more than 3 seconds being unacceptable for the time being, as described by strods, this change should not have resulted in a regression of functionality, as the RADIUS client inside routerOS was not honoring timeouts above 3 seconds to begin with. Based on what mducharme says above, this does not appear to be the case.
He reports that he's seeing different behavior with the timeout hard-set to 3sec, when compared to the 6sec available before. This is a regression in functionality and directly contrary to the information given by MT (strods) - in short, this is a bug. Either MT themselves are incorrect about the behaviour of the client when given timeouts above 3s (and mducharme's 6s timeout on older FW versions was making a difference), or something else has changed that otherwise breaks his admittedly unusual but completely valid configuration.
As mducharme has demonstrated, while unusual, it's not unreasonable for RADIUS to take some seconds to reply, and alternate vendors appear to have max timeouts in the 30-90 second range at the very least. We can argue about arbitrary configuration constraints until we're blue in the face, but it's not relevant to the issue at hand here.
MT: What's your explanation for why mducharme's configuration here works on 6.40 but not on 6.41?
mducharme: Have you opened a support ticket for this regression & provided supout.rifs etc? This isn't an official support channel, and it sounds like you should be talking to support if you aren't already.
blajah
Sat Nov 18, 2017 5:39 pm
It shows:
Update firmware:
Regarding all this with firmware, i have found this in changelog in RC channel:
!) routerboot - RouterBOOT version numbering system merged with RouterOS;
pe1chl
Sat Nov 18, 2017 10:12 pm
That is why I mention that there is an issue with the RB750 firmware - as this is the release candidate topic and developers are hopefully reading it before doing a release.
mducharme
Trainer
Trainer
Sun Nov 19, 2017 3:09 am
Exactly, my own observations of the behavior of earlier versions do not jibe with what strods claims to be the case. It seems extremely unlikely that it was coincidental that the issue vanished when I made the change, given the circumstances.
No I haven't, only because I would have to upgrade to 6.41 at one of those satellite sites (15 of our 45 sites are connected via satellite). However I don't need a test to tell me what effect limiting the maximum value will have when we are currently using 6000 ms, and given my previous experiences. We could maybe get by with 5000ms, possibly even 4000ms, but if the RADIUS server thinks the customer is still logged in, it will only authenticate in 3000ms if the stars are in perfect alignment due to the extra time required to pull the list of logged in customers. Due to the power requirements of the satellite amplifiers they cannot be connected to the UPS, so when the power goes down at the site (some sites are on unreliable diesel) the satellite feed goes down immediately. If customers log off during this time (common b/c they usually lose power as well), the RADIUS disconnect notification doesn't make it to the RADIUS server because, with the satellite link down, there is no way for the packet to reach its destination. When the site comes back up again, the RADIUS server sees the customers trying to log in again and it thinks they are already logged in, so before it sends the 'accept' or 'reject' it has to go to the router and check to see if they actually are still logged in. Customers sometimes share their PPPoE credentials with friends to try to give them free service, so this check is necessary to protect against that.
We try to centralize as much as possible and minimize the equipment at the site, less equipment means less that can break - it is cheaper for me to fly to Hawaii than to go to some of our sites. The central RADIUS server is a necessity for us, and it is just not viable to optimize it more than we already have. We have already had to change some FreeRADIUS code to use snmpbulkwalk instead of snmpwalk to avoid needing 25-30 second timeouts, and I do not think we can reduce this any further given our previous efforts to provide QoS to prioritize RADIUS packets.
pe1chl
Sun Nov 19, 2017 11:24 am
You have 15 sites of a problematic type for which it costs $1000 to make a support visit and you don't have a way to test a similar site from home (a subscription to the same satellite service)?
Really? It all does not seem very professional...
mducharme
Trainer
Trainer
Sun Nov 19, 2017 9:05 pm
The dishes are 2.4 or 3.8 meters, so they are big (larger than a home satellite service). It is not easy like putting up an Xplornet dish on a home, these are very big and very heavy, they cannot be roof or wall mounted, unless maybe the roof was concrete and very thick, able to support the weight. So the dish would generally need to be on the ground with a concrete pad for stability and fencing to avoid people standing in front of the beam. Even if we had a place to install such a thing in our downtown urban office building, each dish has its own upload channel, so there would need to be one assigned to a "test dish" but all are in use since actual sites are priority. Therefore to operate a test dish with no channels we would need to shut down one of the 15 sites to free up a channel to bring up a test dish. It would be great to have a test system, it would make certain things easier, but it is just not feasible for all those reasons, so we have lived without it.
msatter
Sun Nov 19, 2017 11:54 pm
I see a lot of postings about the Radius timeout and maybe Mikrotik is willing to add an option to choose for extended timeout.
Normal 3 seconds and when the extended timeout option is ticked let's say 90 seconds.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46.1 / Winbox 3.20 / MikroTik APP 1.3.9
Android device owners, use https://github.com/M66B/NetGuard/releases (no root required)
troffasky
Mon Nov 20, 2017 7:18 pm
Don't need a satellite dish to emulate the behaviour of a typical satellite link:
https://wiki.linuxfoundation.org/networking/netem
LynxChaus
Mon Nov 20, 2017 11:10 pm
125ms need to reach satellite and 125ms to reach earth. Why you need HUGE timeout ? You bounce signal multiple times to orbit and back?
You need only ONE snmpget to understand what happens with equipment and connected users - check sysUpTimeInstance (.1.3.6.1.2.1.1.3.0) and if it goes back - assume "power lost, all users disconnected" and drop it manually in radius. it's not rocket science.
mducharme
Trainer
Trainer
Tue Nov 21, 2017 1:19 am
Ping to the site across the satellite link is at least 600ms round trip, so 300ms each way. I have never seen latency drop below that. You are suggesting that round trip latency should be 250 ms or slightly higher, but that is just not realistic.
That requires extra programming, and won't work in some scenarios. The RADIUS server itself (FreeRADIUS) already has the SNMP check built in to poll the list of interfaces in event that it thinks the customer is already logged in - this did not need to be scripted as it is a built in feature, the RADIUS server does this SNMP check while the NAS is waiting for the 'accept' or 'reject'. What you are describing is an external script that would keep track of the uptime for each router and be able to tell if one went back and just disconnect the sessions for that router. It is certainly possible but such a script would have to be carefully tested. That also wouldn't help with a scenario where the router did not go down but the satellite lost power. A brief power outage would not knock the router offline, so the sysuptime would not go back. Unfortunately this also happens fairly frequently, so a solution that doesn't address this would not help.
A safer way would be to clear sessions if the interim-update interval is exceeded by, say, 4 times, but with an interim update interval of half an hour, customers could be down for up to two hours before the old session would clear.
sup5
Tue Nov 21, 2017 4:20 am
Another issue with a max. of 3 seconds radius timeout is this:
When the NAS reboots or a bunch of users is handed over from one NAS to another (PPPoE failover scenarios), reauthentication of these users will take ages. So users will complain.
The NAS kicks the users before the radius was able to reply. With enhanced radius timout of like let's say 7 seconds the users are authenticated very quickly.
This 'issue' is caused by a quite loaded Radius and Database server during this peak duration (NAS reboots => several thousand users to aithenticate immediatelly). A radius timout of max. 3 seconds only makes things worse here. The load on the radius increases!
strods
Fri Nov 24, 2017 3:09 pm
What's new in 6.41rc56 (2017-Nov-24 10:03):
Important note!!! Backup before upgrade!
RouterOS (v6.40rc36-rc40 and) v6.41rc1+ contains new bridge implementation that supports hardware offloading (hw-offload).
This update will convert all interface "master-port" configuration into new bridge configuration, and eliminate "master-port" option as such.
Bridge will handle all Layer2 forwarding and the use of switch-chip (hw-offload) will be automatically turned on based on appropriate conditions.
The rest of RouterOS Switch specific configuration remains untouched in usual menus for now.
Please, note that downgrading to previous RouterOS versions will not restore "master-port" configuration, so use backups to restore configuration on downgrade.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
Changes since previous 6.41rc release:
!) bridge - general implementation of hw-offload bridge (introduced in v6.40rc36);
*) dhcp-client - limit and enforce DHCP client "default-route-distance" minimal value to 1;
*) dhcpv4-server - strip trailing "\0" in "hostname" if present;
*) filesystem - implemented additional system integrity checks on reboots;
*) firewall - added "tls-host" firewall matcher (CLI only);
*) hotspot - fixed "dst-port" to require valid "protocol" in "walled-garden ip";
*) ike2 - fixed PH1 lifetime reset on boot;
*) lte - fixed authentication for non LTE modes;
*) tr069-client - fixed "/interface lte apn" configuration parameters;
*) userman - allow to generate more than 999 users;
*) wireless - added passive scan option for wireless scan mode;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Chupaka
Fri Nov 24, 2017 3:14 pm
Sweet. No more Layer 7 for HTTPS blocking :)
How it works? Which packet matches? Does it support wildcards?
pietroscherer
Trainer
Trainer
Fri Nov 24, 2017 3:24 pm
+1 :D
Pietro Scherer
http://www.tchesolutions.com.br [ISPs Consulting and Training]
http://www.routermage.com [Backup and Automation System]
:D
pe1chl
Fri Nov 24, 2017 4:23 pm
I presume this is just a special case of a Layer 7 with some pre-defined pattern, and only works when SNI is used.
Cha0s
Forum Veteran
Forum Veteran
Fri Nov 24, 2017 4:27 pm
It could be an iptables module specific to that function instead of abstracting a L7 filter. Like this https://github.com/Lochnair/xt_tls
honzam
Fri Nov 24, 2017 4:46 pm
Any info about this? passive scan has been implemented for a long time
LAN, FTTx, Wireless. ISP operator
troffasky
Sat Nov 25, 2017 12:53 am
No need for SNI, CN of certificate is in plaintext whether SNI is used or not.
bjornr
Sat Nov 25, 2017 12:59 am
Upgrading a CRS326-24G-2S+ to 6.41rc56 broke DHCP relaying through it, the requests are passed through but the responses (OFFERs) are never seen by the client. Reverting to rc52 fixed this issue.
Don't know exactly what caused this, but if it helps identifying the issue I'm employing VLANs, bonding interfaces, and DHCP relaying. Configs or supout can be available upon request.
Paternot
Long time Member
Long time Member
Sat Nov 25, 2017 3:28 am
It's not clear, from the changelog, but: If I remember it right, Mikrotik didn't support passive scan with 802.11ac, only b, g, n. Maybe this is it, at long last. :D
nz_monkey
Sat Nov 25, 2017 11:47 am
At a guess, its based on xt_tls which can support wildcards, see https://github.com/Lochnair/xt_tls
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
nkourtzis
Mon Nov 27, 2017 12:24 pm
If this is it, then we only now have to wait for spectral scan and power adjustment in 802.11ac and we will be seeing sweet dreams.
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
nkourtzis
Tue Nov 28, 2017 3:07 pm
Dear all, has the development of ROS slowed down or is it my wrong impresion? One RC sub-version every one to two weeks where it used to be every two to three days and even then, very sparse changelog. Even this thread has become relatively quiet.
Can it possibly be that we approaching the end of v6 development? Just wondering...
pe1chl
Tue Nov 28, 2017 3:28 pm
I am wondering when they dare to release 6.41 as a "current" version with this risky "New bridge implementation" that will likely cause problems once it is widely deployed into many different field configurations (that combine VLAN tagging on switch and bridge now).
You may be right in that this could actually be released as part of "v7" so people are aware there are many changes and testing (rather than routine updating) is required.
Users browsing this forum: No registered users and 15 guests
