troykelly
BGP supplied route marked unreachable
Thu Jul 27, 2017 9:40 am
I'm trying to redistribute routes to our internal devices - but as the routes are all marked as unreachable they are not being advertised.
41404  Db  dst-address=2c0f:fd90::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,2914,3356,37084,37185" bgp-origin=igp
        bgp-communities=64515:44 received-from=peer6_vultr
41405  Db  dst-address=2c0f:fda8::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,4826,6939,37349" bgp-origin=igp
41406  Db  dst-address=2c0f:fdb0::/48 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,2914,37100,33765" bgp-origin=igp
41407  Db  dst-address=2c0f:fdc0::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,2914,6453,36930" bgp-origin=igp
41408  Db  dst-address=2c0f:fdc8::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,4826,6939,37105,37049" bgp-origin=igp
Is there a way I can ignore the fact the router thinks they are unreachable?
Is there a way I can convince the router they are reachable? (it all works, and the next hop is reachable)
/ping 2001:19f0:ffff::1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 2001:19f0:ffff::1                          56  64 0ms   echo reply
    1 2001:19f0:ffff::1                          56  64 0ms   echo reply
    2 2001:19f0:ffff::1                          56  64 0ms   echo reply
    3 2001:19f0:ffff::1                          56  64 0ms   echo reply
    4 2001:19f0:ffff::1                          56  64 0ms   echo reply
    5 2001:19f0:ffff::1                          56  64 0ms   echo reply
    6 2001:19f0:ffff::1                          56  64 0ms   echo reply
    sent=7 received=7 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
savage
Re: BGP supplied route marked unreachable
Thu Jul 27, 2017 12:10 pm
If this is for recursive routing, you need to manually add a static route in the tables for the gateway IP address. MT doesn't do recursive routing correctly in IPv6, it's a known bug.
Regards,
Chris
mrz
Thu Jul 27, 2017 12:34 pm
@savage it does not apply in this case. Recursive routing does not work only with link-local gateways.
@troykelly See here to solve your problem
https://wiki.mikrotik.com/wiki/Manual:U ... attributes
savage
Thu Jul 27, 2017 1:04 pm
I beg to differ....
[cknipe@WCLH-BR01.cpt.za.as203319.net] > /ipv6 route print detail where gateway=2a07:b2c5::3
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
 0 ADb  dst-address=2002::/16 gateway=2a07:b2c5::3 gateway-status=2a07:b2c5::3 recursive via 2a07:b2c5::61 GRE - SMARTDC-BR01.rtd.nl distance=200 scope=40 target-scope=30 bgp-as-path="6939"
        bgp-local-pref=1000 bgp-med=0 bgp-origin=igp bgp-communities=65000:4703 received-from=AS203319v6 - WCLH-CR01.cpt.za
 1 ADb  dst-address=2026:10c:6003::/48 gateway=2a07:b2c5::3 gateway-status=2a07:b2c5::3 recursive via 2a07:b2c5::61 GRE - SMARTDC-BR01.rtd.nl distance=200 scope=40 target-scope=30
        bgp-as-path="6939,34224,51830" bgp-local-pref=1000 bgp-med=1 bgp-origin=igp bgp-communities=65000:3020 received-from=AS203319v6 - WCLH-CR01.cpt.za
 2 ADb  dst-address=2400:1000::/32 gateway=2a07:b2c5::3 gateway-status=2a07:b2c5::3 recursive via 2a07:b2c5::61 GRE - SMARTDC-BR01.rtd.nl distance=200 scope=40 target-scope=30 bgp-as-path="6939,10021"
[cknipe@WCLH-BR01.cpt.za.as203319.net] > /ipv6 route disable [ /ipv6 route find where dst-address=2a07:b2c5::3 ]
 0  Db  dst-address=2002::/16 gateway=2a07:b2c5::3 gateway-status=2a07:b2c5::3 unreachable distance=200 scope=40 target-scope=30 bgp-as-path="6939" bgp-local-pref=1000 bgp-med=0 bgp-origin=igp
 1  Db  dst-address=2026:10c:6003::/48 gateway=2a07:b2c5::3 gateway-status=2a07:b2c5::3 unreachable distance=200 scope=40 target-scope=30 bgp-as-path="6939,34224,51830" bgp-local-pref=1000 bgp-med=1
Not only link locals... It's a sad, sad day when MT does not even know the extent of their own bugs.
Regards,
Chris
alp
Tue Aug 14, 2018 11:56 am
I have a similar problem.
With HE.net and NetAssist I make BGP by tunnel method. At the same time, I start a direct BGP session with Vultr.
The Full Table from Vultr is unfortunately listed as "unreachable".
Could you support this issue?
mrz
Wed Aug 15, 2018 5:07 pm
Probably you need to resolve gateway recursively, but for it to work properly it must be resolved over route with global address (link local will not work).
mafiosa
Mon Jun 01, 2020 4:15 pm
@mrz @savage I am facing same issue with vultr. Please help me.
kevinM
Mon Jun 01, 2020 8:29 pm
for ipv6 recursive routing we use route filters and set the next hop link local gateways with a check gateway ping. That way if one of the paths goes down it doesn't blackhole traffic and it's still dynamic (we dont use static routes unless absolutly neccessary).
mafiosa
Mon Jun 01, 2020 8:34 pm
So I can use the link local of eth1 interface as next hop using filter and remove the static route to the peer ip of vultr?
Users browsing this forum: No registered users and 9 guests
