onlineuser
6.40 - no OpenVPN
Fri Jul 28, 2017 8:54 am
after upgrade from 6.39 to 6.40 the OpenVPN client does not work any longer - the connection will be established but the interface will not be created, so most rules do not work any longer (for example: srcnat to openvpn interface).
How can I downgrade to 6.39?
Copying the file to the device and rebooting does not work because a newer firmware is on it.
Thanks.
cdiedrich
Forum Veteran
Forum Veteran
Re: 6.40 - no OpenVPN
Fri Jul 28, 2017 10:15 am
Upload the package, then execute
/system packages downgrade
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
onlineuser
Fri Jul 28, 2017 11:50 am
Thanks!
With 6.39 it works again. :-)
I hope the OVPN interface bug in 6.40 will be fixed soon.
onlineuser
Fri Jul 28, 2017 8:01 pm
The problem is a wrong dynamic route when OVPN connection is established.
screenshot:
6.39: the dynamic set route is set correct
6.40: after upgrading with the wo default routes OVPN connection does not work
6.40 fixed: after removing the DS enrty and adding the AS route, the OVPN connectio nworks again. The dynamic set rule (wrong rule) cannot be removed.
Why did you change this behaviour of OpenVPN in 6.40 in comparision to 6.39?
In OVPN client settings on ROS the automatic "adding of the default route" is disabled (in 6.39 and 6.40)!
onlineuser
Tue Aug 01, 2017 8:14 am
Noone any idea why this behavior was changed?
Or is it an unintentional bug?
emils
Tue Aug 01, 2017 9:27 am
Unfortunately, it is a bug in RouterOS 6.40. We will fix this issue in upcoming versions of RouterOS.
onlineuser
Tue Aug 01, 2017 8:07 pm
Thanks.
emils
Wed Aug 02, 2017 2:37 pm
What's new in 6.41rc7 (2017-Aug-02 09:51):
*) ovpn-client - fixed incorrect netmask usage for pushed routes;
onlineuser
Fri Aug 04, 2017 11:58 am
Thanks, very much. :-)
onlineuser
Fri Aug 04, 2017 9:14 pm
OpenVPN client works with 6.40.1 again. :-)
zippel
Sat Aug 12, 2017 3:38 pm
-Chris
can't upload image.. error when downloading to router os "CANT READ" xD
pe1chl
Sat Aug 12, 2017 6:33 pm
No need to downgrade anymore, you can now upgrade to 6.40.1
Explisit
Thu Apr 05, 2018 11:28 pm
Just upgrade to 6.41.1 and got the exact same problem on the mibse platform. Downgrading to 6.40.7 did not solve the issue so I got back last 6.39 version and everything again started to work like a charm. Is there a new issue in 6.41 ?
Users browsing this forum: lami16 and 53 guests
