hengst
Re: Probe Thread
Fri Feb 03, 2017 5:34 pm
Seriously nice work figuring that all out.
I figured out with bits and bytes gathered from others. its more of an endless trial and error which leads me often to the right results.
some call it "obsessive" ...
such a good feeling when code starts working eh..
Thnks for the help Lebowski , if you want to or like to play with the real device i can give you access just send me a pm.
anyway i going to check your hints this weekend.
thomsen
Re: Probe Thread
Fri Apr 14, 2017 3:09 pm
Hello all!
I'have a lot of point of sale where we use the mikrotik routers. Some shops have dual WAN interfaces for failover by recursive routing. I want to monitor each of WAN interface thru ping to google DNS. How can i do that by dude?
thomsen
Re: Probe Thread
Fri Apr 14, 2017 4:35 pm
Hello all!
In other words, it is necessary to start the ping from the device to 8.8.8.8
Shadeofspirit
Re: RE: Re: Probe Thread
Fri May 05, 2017 4:53 pm
Hello all!
Why ping? What kind of wan connection do you have? In some cases you can monitor state (running or not) or count tx/rx packets in particular period of time.
When i was looking for the same probe (ping from different wans in device from dude) i didn't find. But if you want to ping, you can use not dude, but netwatch on device (add route to google DNS from particular wan and write script on down event)
Отправлено с моего Redmi 3S через Tapatalk
MTCNA, MTCWE
thomsen
Fri May 05, 2017 5:23 pm
Hello all!
Shadeofspirit, can i explain my situation in russian language? How to write private messages here?
Shadeofspirit
Fri May 05, 2017 5:34 pm
Hello all!
there are no private messages on this forum try skype (victorspirit) ot telegram (+375445fourfour340five)
MTCNA, MTCWE
spasko
Re: Probe Thread
Fri Aug 04, 2017 11:23 am
Check if a certain program is running on a Windows system ('OUTLOOK.EXE' in this example):
Type: function
Available: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"OUTLOOK.EXE")>0, 1, -1)
Error: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"OUTLOOK.EXE")>0, "", "OUTLOOK.EXE not detected by SNMP probe")
Value: 1 (or anything else, is purely for charting purposes and I return 1 if the service is running)
Unit: running (or whatever you want to call the above values)
Rate: none
This of course requires the SNMP agent is running and configured properly on the Windows system.
This works great but is it possible to monitor if an application is in "Not responding" state?
Could it be that you use the wrong OID. I check Windows services as following:
Available: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"), "db2sec.exe")>0, 1, -1)
Error: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"), "db2sec.exe")>0, "", "DB2_db2sec.exe not detected by SNMP probe")
Value: 1
Unit: running
Rate: none
Change "db2sec.exe" with the name of the service you like to monitor. One thing I also noticed is, that the name is case-sensitive! Write the service name the same as you see it in the Windows Task Manager.
Sometimes it also helps to use the if() function for debugging. If you are not shure what you will get with "if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"), "db2sec.exe")>0" and want to see it, put the same command as "to do". For example:
Error: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"), "db2sec.exe")>0, array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"), "db2sec.exe"), array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"), "db2sec.exe"))
With this error line you will see the output of the command in the "Problem" column of the "Services" table. Sometimes it helps me a lot to find bugs in my commands.
Hi
i've a question about function array_find !
i've integrate in the device appareance a count for process running (in my case HTTPD naming httpd.exe
my code
[array_element(oid_column("1.3.6.1.2.1.25.4.2.1.2"), array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"httpd.exe"))]
[array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"httpd.exe")]
the prolem il : i've 2 httpd.exe running (look with process explorer) and i watch on device 12 process ! !
it's a syntax function problem or bug on Dude program (version 4 running on windows server)
PS : (sorry for my english , i'm French)
eriitguy
Re: Probe Thread
Sun Aug 20, 2017 4:39 pm
Hello, everyone!
I'm trying to setup HP Procurve Cpu probe from the following post.
Now I have configured:
Function
Code: oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0")
Probe
Type: Function
Available: Procurve_Cpu() <> ""
Error: if(Procurve_Cpu() > 80, "", concatenate("Cpu load is = ", Procurve_Cpu(), "%"))
Value: Procurve_Cpu()
Unit: %
It seems that it working, but I need some advises:
1. I periodically get "Not available" - how this may be fixed?
2. Should I use Procurve_Cpu() > 80 or Procurve_Cpu() < 80 for Error? I need a notification when Cpu load is over 80%.
With current setup I get periodically errors: Cpu load is = 0%, Cpu load is = 4%
3. I also tried to configure something like this but without success - I got the error: parse failed
Function
Code: if(oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0",10,5), oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0",10,5), "False")
Probe
Type: Function
Availavble: Procurve_Cpu_Test() <> "False"
Error: if(Procurve_Cpu_Test()<>"False", if(Procurve_Cpu_Test()<80), "", concatenate("Cpu load is = ", Procurve_Cpu_Test(), "%"))
Value: Procurve_Cpu_Test()
Unit: %
Thank you!
lebowski
Re: Probe Thread
Sat Aug 26, 2017 4:10 am
Add 1 in the function since the CPU can return 0% utilization. subtract 1 in the value and error lines...
Code: if(oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0",10,5), oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0",10,5)+1, "False")
in your error line
if(Cisco_CPU_a()<>"False",if(Cisco_CPU_a() -1<80, "", concatenate("Warning: high CPU = ", Cisco_CPU_a(), "%")), "Cisco Device down")
eriitguy
Re: Probe Thread
Mon Aug 28, 2017 9:00 am
lebowski,
Thank you for help!
I have configured a function and probe per you recommendation. Now it look like this:
But I see multiple outages:
And my chart look like this:
lebowski
Re: Probe Thread
Fri Sep 01, 2017 11:23 pm
eriitguy, the only idea I have is your probe interval is conflicting with the probe. On the appearance of the device place your function for CPU [Procurve_Cpu_Test()] and see what the label does. Check your label refresh interval and modify it to be the same as your probe interval and see if they act the same. I have my probe interval set for 1 minutes and probe timeout to 25 seconds and the down count to 3.
jmay
Re: Probe Thread
Thu Sep 14, 2017 6:45 pm
Is it possible to graph all the time and still have a notification on failure if a probe fails? For example, I'm graphing DC voltage from MT's and I want an alert if that Voltage drops down to a certain point. I used to do this with 2 probes, but if would be nice if I could just have one probe. The problem I'm running into is when voltage gets below 24V I get the alert like I should, but I stop graphing.
Here's my current function:
Available: oid("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlVoltage.0")
Error: if(oid("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlVoltage.0")>24,"","failed")
Value: oid("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlVoltage.0")
pablolite
Re: Probe Thread
Tue Oct 10, 2017 1:27 pm
I got 600 routers in Dude with (10 probes). Now I define email notification and Im wondering how to configure it for all devices?
Ex.
My 600 devices in Services tab got probe "Internet" without notification. I want to change "Internet" probe to notification "email" in my all devices?
There is any way to change that with command line?
Best,
Pawel
sorry for my english :(
EDIT:
I find solution.
In DUDE->Services->select multiple ones->open context menu->Settings
LogicalNZ
Re: Probe Thread
Mon Dec 04, 2017 10:53 pm
Hey All,
Just having a bit of a test with creating probes. In particular we have been working with SNMP to see if a windows service is running. It works fine :)
My problem is that when the service fails, the monitor only turns "Orange" rather than RED.
Is there any way to change this?
With thanks
lebowski
Re: Probe Thread
Thu Dec 07, 2017 1:10 am
Only if you make 2 probes, one to graph and one to notify, on the one to graph just put "" in the error line and don't put anything in the graph on the 2nd probe....
miro
Trainer
Trainer
Re: Probe Thread
Wed Jan 31, 2018 3:43 pm
Hi guys.
I monitor with dude WIndows servers. On Icon in Network map I've following info:
CPU: [cpu_usage()]%
RAM: [mem_usage()]%
DiskC Free: [win_diskC_free_MB()] MB
DiskE Free: [win_diskE_free_MB()] MB
[failed_services()]
[services_info()]
I would like to display information from function services_info() in notification email, which is sent, when some probe is down.
Here is my message body tekst... I don't know what is correct sintaks to display value of function in email message.
Service [Probe.Name] on [Device.Name] is now [Service.Status] ([Service.ProblemDescription])
Stanje servisov:
[Device.services_info()]
eine
Re: Probe Thread
Wed Jan 31, 2018 4:42 pm
syntax <> sintaks
On what platform is the dude server installed (rb, windows OS, something else)? What version do you have there? What do you receive in the notification? Why there's no description of the obvious? As I can see you're network professional, then pretty please act as one.
miro
Trainer
Trainer
Re: Probe Thread
Thu Feb 01, 2018 10:53 am
For correct syntaks in notifications imho versions are not important...
But anyway, here they are:
Dude is on CHR ver 6.41 and server is Windows Server 2012...
In notification I receive no output of function services_info(), just plain text [Device.services_info()]
ryz
Re: Probe Thread
Thu Mar 01, 2018 9:31 am
Hi that's my problem too. I don't know how to display function/probe values in email/sms body...
Please help.
Regards
dmain
Re: Probe Thread
Tue Mar 13, 2018 9:49 pm
Hello, another new to Dude user struggling with alerting on utilization. I found the post below from 2009, is there something more recent?
"Mon Aug 03, 2009 4:02 pm
To get the bandwidth displayed in the links between devices the Dude uses the delta of sent/received octets multiplied by 8 averaging over each second of collected data.
Nice to know and I have often wanted to alert on high and or zero utilization but it is not obvious how to do it, like you are finding out.
I looked into data sources but they look like this "serial0/0 (2) @ router1 tx" and I don't know how you would use one in a function or a probe...
Maybe you can figure out how to use a data source in a probe?
All data sources can be seen by selecting chart, make a chart if you don't have one, click on + to add a new chart line then click on the edit all data sources (the "..." button). In there you can see a list of "interface @ devicename tx or rx" which is where I assume that you discovered how exactly the builtin source works."
dmain
Re: Probe Thread
Tue Mar 13, 2018 10:35 pm
Hello, another new to Dude users here struggling with utilization notifications. I found the below from long ago. Is there a more recent example?
nikc
Re: Probe Thread
Mon Jun 18, 2018 5:49 pm
Another new Dude user ... nice thread this .... worried after reading it that MT arent that interested in Dude though :S
autostoper76
Re: Probe Thread
Fri Jul 20, 2018 5:21 am
when will the new versions?
There is no improvement for a long time
6.39 === the latest version
https://wiki.mikrotik.com/wiki/Manual:T ... _changelog
Noa
Re: Probe Thread
Wed Jul 25, 2018 10:06 am
Hi guys. I try to make disk usage probe for large disk 9Tb but snmp give negative value of disk size.
Can i do something with this?
kenjix
Re: Probe Thread
Wed Aug 28, 2019 5:44 pm
Hi, I've been using the dude for a while now and was trying to get the bandwidth probe and alerts to work, but haven't been able to find any documentation as to how to start. Was this project/work ever followed up? All I can find are post from 2010 and back. Any help will be greatly appreciated.
I've been using the Dude for about a month now and am very impressed, the Probe Thread has been very useful. One probe I am having trouble creating is for current bandwidth utilization, giving a notification at a ceratin percentage. Here's what I've done so far:
Using the idea that (InOctets + OutOctets)*8*100/ifSpeed gives the percentage of utilization I created the function:
Function
Code: (oid("1.3.6.1.2.1.2.2.1.16.21")+oid("1.3.6.1.2.1.2.2.1.10.21")*8*100/oid("1.3.6.1.2.1.2.2.1.5.21")
From there I applied this function to a probe
Probe
Available: Bandwidth()
Error: if(Bandwidth()<50, "", concatenate("Bandwidth Utilization is at ", array(Bandwidth()),"%")
Value: Bandwidth()
Unit:
Rate: none
The does work in the fact that it does return a percentage, and when that percentage is passed I receive an email stating that percentage has passed and it gives me what the current percentage is.
The two problems are that this percentage does not match up with the link status given by The Dude in the network map, nor does it line up with the percentage shown on the port in the switch's web based console. Second, because these OIDs are counters if I watch this in real time in The Dude, I can see the percentage start low and then get higher and higher for 90 seconds until the next poll interval when it drops and starts again. Is there a way for it to give an average of the poll interval to show more accurate data?
Users browsing this forum: No registered users and 6 guests
