mo30
split tunnel in vpn remote access
Sun Aug 27, 2017 2:19 pm
hi
we have vpn remote access l2tp from internet for connect to office
we need when user connect to office white vpn from internet they have internet and office network same time.
how can do it in mikrotik
device that user vpn connect mobile pc windows and android
mrz
Re: split tunnel in vpn remote access
Thu Sep 07, 2017 12:46 pm
L2TP does not support split tunnels. I would suggest to use either ike2 or ike1 + modeconf or OVPN to push routes.
idlemind
Fri Sep 08, 2017 12:19 am
If your users are on Windows 10 you can use the new PowerShell command-lets for VPN management to get some of this in place.
Something like this could be used to edit the VPN connection named MyFluffyBunny and to add a route for 10.0.0.0/8 that only is made active when the VPN (managed by the OS):
Get-VpnConnection | Where-Object -Property Name -EQ "MyFluffyBunny" | Set-VpnConnection -SplitTunneling $true
Get-VpnConnection | Where-Object -Property Name -EQ "MyFluffyBunny" | Add-VpnConnectionRoute -DestionationPrefix 10.0.0.0/8
NTheZone
Fri Aug 21, 2020 10:22 pm
Minor typo in your -DestionationPrefix, and corrected below. Otherwise, BRILLIANT! It works great. It's possible home users will have a network/subnet: 192.168.88.0/24 (instead of 10.0.0.0/8)
Get-VpnConnection | Where-Object -Property Name -EQ "MyFluffyBunny" | Add-VpnConnectionRoute -DestinationPrefix 192.168.88.0/24
almdandi
Tue Aug 25, 2020 6:28 pm
Or just
Set-VpnConnection -ConnectionName "MyFluffyBunny" -SplitTunneling $true
Add-VpnConnectionRoute -ConnectionName "MyFluffyBunny" -DestinationPrefix "193.110.29.0/27"
lukman2705
Wed Dec 01, 2021 8:14 am
Hi, is there any ways to configuring split tunneling on mobile phone like android and iphone using vpn in Mikrotik (like ovpn) and how is the configuration for the push route?
Thank you
Users browsing this forum: clambert, sas2k, scoobyn8 and 193 guests
