slikmik
Mikrotik router with ubiquity access points
Tue Aug 29, 2017 6:20 pm
Hi all
The problem i have at the minute is we have gone into a venue where they have ubiquity unifi access points what only have power going to them , no Ethernet cables therefore they are communicating over WiFi to a switch. i was informed by the IT guy to plug our mikrotik into an open port on his switch which i have done but the unifi access points are not picking our mikrotik rb951 up, they are still broadcasting there original open and secure network , but not bringing up our captive portal.
so basically how to get our router to communicate through WiFi to ubiquity
erlinden
Re: Mikrotik router with ubiquity access points
Tue Aug 29, 2017 7:18 pm
Wat do you mean with "not picking up"? Are the Unifies supposed to user the MikroTik for wireless uplink purposes? How should the Unifies know about a portal on the MikroTik? Have you made adjustments on the controller? Can you please draw the network with the IP's and inter-device connections? Do hou have any experience with Unify?
flynno
Tue Aug 29, 2017 10:51 pm
You need to install the UniFi controller software on your laptop / PC
see link
https://dl.ubnt.com/guides/UniFi/UniFi_ ... _V3_UG.pdf
Users browsing this forum: bingo19 and 92 guests
