MUM Europe 2020
lz1dsb
PIM Routing Not Working
Tue Aug 29, 2017 9:54 pm
I'm puzzled by a relatively straight forward setup.
(Multicast client)192.168.82.50 -----------------192.168.82.1MikrotikRouter10.82.79.1--------------IPIP Tunnel---------------10.82.79.2MikrotikRouter2192.168.79.2---------------192.168.79.1 Multicast source
So, I've got PIM enabled on the local bridge interfaces, and on the IPIP tunnel interface.
[admin@MikrotikRouter] > routing pim export
# aug/29/2017 21:48:31 by RouterOS 6.38.7
# software id = HANY-G2QR
/routing pim interface
add interface=bridge-local
add interface=Tunel-MikroTik2
/routing pim rp
add address=192.168.79.2
[admin@MikrotikRouter2] > routing pim export
# aug/29/2017 21:49:01 by RouterOS 6.38.7
# software id = Q2JY-B7H6
add interface=Tunnel-MikroTik
/routing pim rp
So when I register a multicast sender behind MikroTik Router on multicast group 226.94.10.1 and than try to reach it from behind MikroTik Router2 it does not work. I'm using iperf to test this:
On the sender
iperf -s -u -B 226.94.10.1 -i 1
On the receiver
iperf -c 226.94.1.1 -u -T 32 -t 3 -i 1
Am I missing something in my configuration?
lz1dsb
Re: PIM Routing Not Working
Wed Aug 30, 2017 7:56 pm
An update:
Both routers see each other as PIM neighbors:
[bsotirov@Mikrotik1] > routing pim neighbors print
ADDRESS INTERFACE PRIORITY TIMEOUT
10.82.79.2 Tunel-rtsf79
[bsotirov@Mikrotik2] > routing pim neighbors print
10.82.79.1 Tunnel-rtsf82
I have also allowed IGMP in the input chain on both routers along with UDP. IGMP and UDP are also allowed in the forward chain on both routers. I could indeed see the IGMP messages on the tunnel interface between the routers.
Regards,
Boyan
lz1dsb
Tue Sep 05, 2017 8:27 pm
Any ideas on how to further troubleshoot that?
Regards,
Boyan
ZeroByte
Wed Sep 27, 2017 7:36 am
Look in the status windows to see if the routers show your multicast group e.g. 226.94.10.1
Also - since you use two different groups with iperf - I assume that one or the other is the real group your system uses, and not 224.0.0.x (which is defined as local segment only - i.e. it doesn't pass through routers).
If you see the group and members, then I'd suspect that the firewall rules are filtering your stream. You could try placing a rule near the top of the forward chain which allows address-type=multicast in-interface / out-interface=tunnel
(or just accept all packets in/out the tunnels and then narrow it down from there if that broad stroke works)
When given a spoon,
you should not cling to your fork.
The soup will get cold.
lz1dsb
Mon Feb 26, 2018 8:01 pm
It turned out it's working, but I have issues with the end hosts. The reason I need Multicast routing is for DLNA. It turned out though some DLNA clients use different ports in requesting content. That's the reason why it was not working. So I have to figure out a way now to change the end client behavior.
Regards,
Boyan
krzysztof
Wed Apr 11, 2018 5:45 pm
I've been testing a group of 700 TV IP tuners for a long time (IP TV).
I tested PIM protcol with CCR CCR1009, CCR1036 and X86 (Ethernet Controller Intel 82599 10Gb/s).
I've always tested the same configuration.
Tests showed that CCR works very badly.
Every moment there were breaks in Video and sound.
Sometimes there was a total stoppage.
But RouterOS with X86 and Ethernet Controller Intel 82599 10Gb/s worked very well.
Works perfectly.
I always use the same configuration for the 10Gb/s port.
Always RouterOS 6.41.3 and today 6.41.4
Thought that he even works more stable than Cisco Better than CISCO!
I do not know but the question is what is the reason.
Users browsing this forum: No registered users and 7 guests
