MUM Europe 2020
ekpesinyang
EoIP with public IP
Sat Sep 16, 2017 11:01 pm
https://wiki.mikrotik.com/wiki/Manual:Interface/EoIP.
I read the above and need to know if it will work on public ip address and also can the config work with VPN.
i'll Never stop Learning....!!!!
Ekpedeme Inyang
amt
Long time Member
Long time Member
Re: EoIP with public IP
Sun Sep 17, 2017 1:34 am
Both of yes
its work on puplic ip, you can use for vpn
ekpesinyang
Sun Sep 17, 2017 6:59 am
Both of yes
How does the config look like please...
Ekpedeme Inyang
amt
Long time Member
Long time Member
Sun Sep 17, 2017 2:24 pm
Both of yes
Can you share what you need ?
Also both router should be mikrotik for eoip.
ekpesinyang
Mon Sep 18, 2017 1:02 am
Both of yes
I have 2 locations with public IP addresses.we have 20 users at each location and a server running an accounting package. We want to share resources from each location to the other location. We also have a cctv which should be viewed by the MD and IT Admin from any other locations they are. I have 2 mikrotik RB3011-RM router on both locations. Each site has a bandwidth of 2MB/2MB running.
Ekpedeme Inyang
amt
Long time Member
Long time Member
Mon Sep 18, 2017 9:06 am
Here is example with ipip tunnel that I use for vpn 2 location.. you can use eoip also instead ipip
at your Location-1
/interface ipip
add !keepalive local-address=Location-1PuplicIP name="to location-2" remote-address=Location-2PuplicIP
add address=172.16.120.102/30 interface="to location-2" network=172.16.120.100
add address=192.168.1.1/24 comment="location1 Local network" interface=ether1 network=192.168.1.0
add distance=1 dst-address=192.168.0.0/24 gateway="to location-2"
at your Location-2
/interface ipip
add !keepalive local-address=Location-2PuplicIP name="to location-1" remote-address=Location-1PuplicIP
add address=192.168.0.1/24 comment="location-2 local network"interface=ether1 network=192.168.0.0
add address=172.16.120.101/30 interface="to location-1" network=172.16.120.100
add distance=1 dst-address=192.168.1.0/24 gateway="to location-1"
with this config you can reach 192.168.1.0/24 from location-1 and you can reach 192.168.0.0/24 from location-2
scampbell
Trainer
Trainer
Tue Sep 19, 2017 2:04 am
For EoIP on Public interfaces do not forget to allow GRE (47) on your input rules.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
ekpesinyang
Tue Sep 19, 2017 12:11 pm
Why that and how please.
Ekpedeme Inyang
amt
Long time Member
Long time Member
Tue Sep 19, 2017 12:42 pm
I think ekpesinyang telling that rule below if you have firewall on your routers,
add action=accept chain=input protocol=gre
mducharme
Trainer
Trainer
Tue Sep 19, 2017 7:57 pm
For security reasons, it is best allow GRE on input only from the IP of the far end.
ekpesinyang
Wed Sep 20, 2017 8:11 am
Should that be implemented on both Routers. I hope that will not also block the administrative privileges. what i mean is that if need be that I've to logging to the router from another public IP to make some urgent changes.
Ekpedeme Inyang
ebreyit
Wed Sep 20, 2017 12:02 pm
Admin ports should not be directly open via Public IP.
Either use port knocking or a VPN to manage the router from the Internet
Users browsing this forum: mbolsteins and 36 guests
