Hello Everyone,
I have a question regarding following scenario:
I have 2 houses I want to connect with a wireless station. Each of them have an internet connection via local telcom provider. The houses have a clear line-of-sight and the distance is about 75-100 meters. The weakest point int the link is going to be a powerline connection, so it is no use to have an extreme high bandwidth (300 Mbps should be ok). I want to use this link for backup/File sharing to the other house as going through VPN only goes to about 20 Mbps.
What type of device would you recommend? (I was thinking of SXT 5 ac)
Is it possible to route between the 2 different networks? I only find info on configuring as wireless bridge, but that consists of only 1 router...
Regards,
Steven
