anishpsla
Configure 2 ip for WAN
Sun Oct 01, 2017 8:06 pm
My ISP is giving 2 IPs (A.B.C.D and E.F.G.H - different network) for WAN connection. I want to use one IP (A.B.C.D) for broadband connectivity and other (E.F.G.H) for hosting our websites (NAT the address and forward port 80). I configure IP (A.B.C.D) for broadband connectivity and works perfectly. I create a VLAN in WAN interface and configure IP (E.F.G.H) in it. I can ping the VLAN interface from internet. But I can't NAT the interface for configuring Webserver.
How can I configure both IPs for Broadband connectivity and hosting webserver.
anishpsla
Re: Configure 2 ip for WAN
Mon Oct 02, 2017 8:20 am
Any information from MT ?
Chupaka
Mon Oct 02, 2017 11:35 am
why? what's stopping you from doing that?
anishpsla
Mon Oct 02, 2017 8:33 pm
Please suggest me a recommended configuration.
As I mention in the first post, I configure the second IP in a VLAN under WAN port. but it's not working correctly. I can ping to the VLAN interface. But because of unknown reason, it's not working as I want.
Chupaka
Tue Oct 03, 2017 8:42 am
but what exactly do you want? what do you configure, what do you check and what does work not as you expect?
anishpsla
Wed Oct 04, 2017 8:10 pm
Our ISP give two IPs 103.12.x.x and 45.85.x.x on same fiber. I want to configure 103.12.x.x for 192.168.0.0/24 and 45.85.x.x for 172.16.0.0/24
I successfully configure 103.12.x.x on WAN and 192.168.0.0/24 on ether1. I don't know how to configure 45.85.x.x for 172.16.0.0/24 on ether2.
Chupaka
Re: Configure 2 ip for WAN  [SOLVED]
Thu Oct 05, 2017 8:50 am
You said you created a VLAN. Did your ISP tell you that you need VLAN? Or maybe you just need to add 45.85.x.x on WAN interface together with 103.12.x.x?
anishpsla
Thu Oct 05, 2017 2:01 pm
Yes, I want to host webserver on 45.85.x.x (NATed 172.16.0.0/24).
Chupaka
Thu Oct 05, 2017 3:51 pm
I mean, do not create VLAN on etherX, add second address directly to etherX
anishpsla
Thu Oct 05, 2017 8:27 pm
Can I NAT that address to 172.16.x.x and forward port 80 to WAN ?
ekpesinyang
Thu Oct 05, 2017 9:15 pm
You don't need a VLAN to configure That. But why not do a port forwarding instead. Can u do a sketch diagramme of your network ? what really do u want to achieve with it.
Chupaka
Fri Oct 06, 2017 10:13 am
Sure
anishpsla
Fri Oct 06, 2017 8:17 pm
Thanks, I will try and post the result.
