larmaid
[ask] mikrotik support modem....?
Sat Dec 09, 2006 12:31 pm
does mikrotik support modem internal.....????
i like it
normis
Mon Dec 11, 2006 9:18 am
external
rinoel
Mon Dec 11, 2006 3:13 pm
I have a question about modems, i have cable internet connection, so:
ISP ---- Modem ----- Me, can i use this type of connection to give any client i want the connection I mean creating an AP, and which radios (cards), and antennas do you recommend me, I am planning to transfrom my Intel P4 to a router and then to an AP so i can give the access my friends about 1 or 2 km away from me. thnx im advance, i know its a stupid question however I need your help.
janisk
Mon Dec 11, 2006 3:52 pm
for that distances if there is no real noise around would be enough with R52 or any other card and if you are good at homeworks - you can even search the internet and find - how to create antenna yourself. for that distacne it would be enough
larmaid
Mon Jan 08, 2007 6:15 pm
does any external modem works in mikrotik....????
can mikrotik be a call back server..????
larmaid
Tue Jan 09, 2007 12:06 am
help pliss
i like it
pedja
Long time Member
Long time Member
Tue Jan 09, 2007 10:25 am
Yes, just connect external modem to free serial port (pay atention that by default MT uses the first serial for terminal access). Then add PPP in server in Interfaces and set PPP to allow dial-in access.
Juse set modem users on separate IP range, set simple routing ant that is it, Qute easy setup, in my opinion.
larmaid
Wed Jan 10, 2007 7:59 pm
@pedja
1.that mean mikrotik can be a CALL BACK SERVER right....????
2.can u specified in dummies way pliss..????
thx
for advanced
i like it
mneumark
Thu Jan 11, 2007 7:42 am
larmaid,
Visit http://www.mikrotik.com/testdocs/ros/2. ... ce/ppp.php
This has examples and explains how to accomplish this.
larmaid
Sat Jan 13, 2007 12:07 pm
thx i'll try first
i like it
larmaid
Mon Jan 15, 2007 11:57 am
@mneumark okay, now the real question is how setup the call back...???
i like it
larmaid
Mon Jan 22, 2007 5:54 am
hwllo...... :(
i like it
jwcn
Mon Jan 22, 2007 6:32 am
Go read, learn and then come back. Every question you have asked is answered in the documentation. Don't expect people to always spoon feed you.
Do the leg work or pay someone else to configure it for you.
larmaid
Tue Jan 23, 2007 6:19 am
:shock: ..... :cry:
i like it
jo2jo
Forum Veteran
Forum Veteran
Tue Jan 23, 2007 6:39 am
he's right..
but know this before you give up or begin your reading:
Mikrotik
CAN dial out via the modem AND can accept dial INs as well.....from there you can do just about anything with those users or connections
:beep :beep :beep
larmaid
Tue Jan 23, 2007 3:33 pm
thx jo2jo i'll try
i like it
Users browsing this forum: csalcedo, martinzellweger, sutrus and 96 guests
