nicutdk
wlan DHCP server RED color
Mon Oct 23, 2017 9:43 pm
Hello ,
I have a very simple configuration on Metal G-52SHPacn
With this configuration DHCP server not working
# model = Metal G-52SHPacn
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge ssid=MikroTik
add name=dhcp_pool0 ranges=192.168.15.2-192.168.15.254
add address-pool=dhcp_pool0 disabled=no interface=wlan1 name=dhcp1
add address=192.168.15.1/24 interface=wlan1 network=192.168.15.0
add address=192.168.15.0/24 gateway=192.168.15.1
Can explain what is wrong ?
Best Rregards,
AlainCasault
Trainer
Trainer
Re: wlan DHCP server RED color
Mon Oct 23, 2017 10:21 pm
This usually happens when your interface is slaved, to a bridge for example.
Since I think your posted config is partial, check that out.
If that's the case, dhcp server needs to be assigned to the bridge IF wlan1 has to be slaved to the bridge.
Regards,
Sent from Tapatalk
___________________________
Alain Casault, Eng.
If I helped you, let me know!
nicutdk
Mon Oct 23, 2017 10:32 pm
Regards,
Sent from Tapatalk
That configuration is ALL config on the router and the wlan it is not slave. I don't have bridge port created on router.
I reset the router without default config, I assign a ip on wifi and run dhcp server. The DHCP server after that is RED and not working.
scampbell
Trainer
Trainer
Mon Oct 23, 2017 11:21 pm
If you do not have any registered clients on your WLAN1 interface it will not show a Running Flag (R). Consequently any IP Address and DHCP-Server will be in an inactive state.
As soon as a client registers the DHCP Server should change colour and start working.
If you were to create a bridge, add the wlan1 to the bridge and assign both the IP address and dhcp-server to the bridge it wouldn't show as red.
Hope this helps.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
nescafe2002
Long time Member
Long time Member
Tue Oct 24, 2017 12:00 am
I have tried the config and it works fine. DHCP turns black as soon as first client connects.
Clients have no internet connectivity but that's due to absence of dhcp client on ether1 and standard nat/firewalling config (quickset is a good start).
nicutdk
Tue Oct 24, 2017 8:15 am
Thank you for your answer. I think the red color means BAD.... So... I think now is good :)
MasterJames
Tue Apr 02, 2019 11:35 am
If you plug the outside into Port 2 or other it will show RED in Default DHCP Client as the interface is ether1 once you plug the WAN in to ether1 will be acquired and change to black with the Status bound and a release timer countdown labelled as Expires After (default for me is 24 hrs).
I think I did that out of the box because it's not needing POE and I thought initially to avoid it but it also says "POE In", while last one is 'POE out', so that's new to me with this new RB4011iGS+5HacQ2HnD (arm).
I guess I'll look more into the difference of POE in vs out (any comments appreciated) but it seems WAN in ether1 is the defconf way to go.
Users browsing this forum: No registered users and 5 guests
