letnab
Port forwarding
Sat Oct 28, 2017 10:26 am
Hi all.
I try to forward 80 port to internal server.
For start I tried this command:
ip firewall nat add chain=dstnat dst-address=xx.xx.xx.xx protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.29 to-ports=80
but it's not work.
After that i tried to add rule use winbox:
but it's not work too.
Firewall rules:
[admin@MikroTik] > /ip firewall export
# oct/28/2017 10:01:44 by RouterOS 6.35
# software id = 356A-NAW9
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add chain=input protocol=icmp
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat out-interface=beeline src-address=192.168.1.0/24
add action=masquerade chain=srcnat out-interface=ether1-gateway src-address=192.168.1.0/24
add action=netmap chain=dstnat dst-port=3389 in-interface=beeline protocol=tcp to-addresses=192.168.1.12 to-ports=3389
add action=netmap chain=dstnat dst-port=3389 in-interface=beeline protocol=tcp src-address=192.168.1.0/24 to-addresses=192.168.1.12 to-ports=3389
add chain=srcnat
add action=src-nat chain=srcnat dst-address=192.168.1.12 dst-port=3389 protocol=tcp src-address=192.168.1.0/24 to-addresses=192.168.1.1
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.xxx dst-port=80 protocol=tcp to-addresses=192.168.1.29 to-ports=80
For interface version:
add chain=srcnat
add action=netmap chain=dstnat in-interface=beeline dst-port=80 protocol=tcp to-addresses=192.168.1.29 to-ports=80
RDP is working fine. Http is not working.
why is this happening? What am I doing wrong?
evince
Re: Port forwarding
Mon Oct 30, 2017 11:58 am
Hello, check if HTTP server is not running on your board : /ip service
Falklan
Re: Port forwarding
Thu Nov 02, 2017 11:12 am
I presume this is what you are attempting.
https://wiki.mikrotik.com/wiki/Hairpin_NAT
Anumrak
Re: Port forwarding
Fri Nov 03, 2017 9:16 am
If in this rule ip firewall nat add chain=dstnat dst-address=xx.xx.xx.xx protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.29 to-ports=80, the xx.xx.xx.xx is global IP and you you want to access to server from outside, then you doing all right. If you want to access this server from the inside, then you need to manage Hairpin NAT.
krunical
Re: Port forwarding
Mon Nov 06, 2017 4:53 pm
Agreed with Anumrak
If it has been overlooked id also confirm the ip you are trying to access on the WAN side is publically routable.
Theres no place like 127.0.0.1
BTC: 1BTPtqpfcjEXSpxDi7fgGsfo5et21TTYiq
giorgiop
Re: Port forwarding
Wed Nov 08, 2017 7:32 pm
Wouldnt something like the following work?
add chain=dstnat action=dst-nat to-addresses=192.168.1.29 to-ports=80 protocol=tcp dst-port=80 in-interface=beeline ?
I tried a while ago redirecting the requests to my MT (testing some FW rules) and managed to see the login although i asked for a different page
Users browsing this forum: hyusube, matiss and 60 guests
