fedor47271
Overruns on CSS326-24G-2S+RM
Thu Nov 02, 2017 12:24 pm
Rx Overruns on CSS326-24G-2S+RM > 1000 for 1 hour on the uplink port. Traffic is a maximum of 40Mbps on this port. On other ports, traffic is less than 3Mbps and it is all going to the uplink port (all computers work only with the Internet - they do not communicate with each other).
Can the frame buffer size not be enough? What is the frame buffer size? The characteristics are not indicated. Can it be without a buffer?
In the test results, the throughput is 33-43Gbps depending on the size of the packets.
That is 1000 times more than in our mode of operation. Why appear Rx Overruns I do not understand.
fedor47271
Re: Overruns on CSS326-24G-2S+RM
Wed Dec 06, 2017 5:39 pm
the problem is solved - after the firmware update the errors have disappeared
Atentaduh
Fri Feb 23, 2018 2:42 pm
I got the same problem! rx-overruns on the trunk port
i'm running with the latest version (2.7)
Example:
The trunk port is running at 1G full duplex connected to a RB1100Dx4
i'm connected direct to a random port running at 100Mbps
if i ran a btest from another device on a different port running at 100Mbps
on my device... i cant get more than 2Mbps
i tried with flow-control on and off
same thing..
Atentaduh
Thu May 03, 2018 5:39 pm
Well here we go again, i got a brand new CRS326-24G-2S+ and the same problem with overruns!!!
The performance just sucks, before the crs i was using a cheap switch with 8 ports and was doing GREAT! idk if im doing something wrong! can someone help me
i'm running the lastest version 6.42.1 RouterOS
Bridge with Hardware-offload ! to several devices
Ether1 work as trunk port to ad RB-1100AHDx4 with a few vlans
Heres the config bellow
add name=bridge-vlans priority=0x20 vlan-filtering=yes
/interface vlan
add interface=ether1-trunk name=vlan500-mngt vlan-id=500
add interface=bridge-vlans name=vlan2403-mrb-hades vlan-id=2403
add interface=bridge-vlans name=vlan2404 vlan-id=2404
add interface=bridge-vlans name=vlan2405-mrb-aegon vlan-id=2405
add interface=bridge-vlans name=vlan2406 vlan-id=2406
add interface=bridge-vlans name=vlan2407 vlan-id=2407
add interface=bridge-vlans name=vlan2408 vlan-id=2408
add interface=bridge-vlans name=vlan2409 vlan-id=2409
add interface=bridge-vlans name=vlan2411-ptp-loja vlan-id=2411
add interface=bridge-vlans name=vlan2412 vlan-id=2412
add interface=bridge-vlans name=vlan2413-saveiros vlan-id=2413
add interface=bridge-vlans name=vlan2415-mrb-pegasus vlan-id=2415
add interface=bridge-vlans name=vlan2416 vlan-id=2416
add interface=bridge-vlans name=vlan2417-mrb-heimdall vlan-id=2417
add interface=bridge-vlans name=vlan2419-mrb-zeus vlan-id=2419
add interface=bridge-vlans name=vlan2421-mrb-poseidon vlan-id=2421
add interface=bridge-vlans name=vlan2423-mrb-diana vlan-id=2423
add bridge=bridge-vlans interface=ether23-mrb-diana pvid=2423
add bridge=bridge-vlans interface=ether19-mrb-zeus pvid=2419
add bridge=bridge-vlans interface=ether17-mrb-heimdall pvid=2417
add bridge=bridge-vlans interface=ether15-mrb-pegasus pvid=2415
add bridge=bridge-vlans interface=ether13-saveiros pvid=2413
add bridge=bridge-vlans interface=ether21-mrb-poseidon pvid=2421
add bridge=bridge-vlans interface=ether3-mrb-hades pvid=2403
add bridge=bridge-vlans interface=ether5-mrb-aegon pvid=2405
add bridge=bridge-vlans interface=ether11-ptp-loja pvid=2411
add bridge=bridge-vlans interface=ether1-trunk
add bridge=bridge-vlans interface=ether2 pvid=2402
add bridge=bridge-vlans interface=ether4 pvid=2404
add bridge=bridge-vlans interface=ether6 pvid=2406
add bridge=bridge-vlans interface=ether7 pvid=2407
add bridge=bridge-vlans interface=ether8 pvid=2408
add bridge=bridge-vlans interface=ether9 pvid=2409
add bridge=bridge-vlans interface=ether10 pvid=2410
add bridge=bridge-vlans interface=ether12 pvid=2412
add bridge=bridge-vlans interface=ether14
add bridge=bridge-vlans interface=ether16 pvid=2416
/interface bridge vlan
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether3-mrb-hades vlan-ids=2403
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether5-mrb-aegon vlan-ids=2405
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether11-ptp-loja vlan-ids=2411
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether13-saveiros vlan-ids=2413
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether15-mrb-pegasus vlan-ids=2415
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether17-mrb-heimdall vlan-ids=2417
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether19-mrb-zeus vlan-ids=2419
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether21-mrb-poseidon vlan-ids=2421
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether23-mrb-diana vlan-ids=2423
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether2 vlan-ids=2402
add bridge=bridge-vlans tagged=bridge-vlans,ether1-trunk untagged=ether12 vlan-ids=2412
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether10 vlan-ids=2410
add bridge=bridge-vlans tagged=bridge-vlans,ether1-trunk untagged=ether9 vlan-ids=2409
add bridge=bridge-vlans tagged=bridge-vlans,ether1-trunk untagged=ether8 vlan-ids=2408
add bridge=bridge-vlans tagged=bridge-vlans,ether1-trunk untagged=ether7 vlan-ids=2407
add bridge=bridge-vlans tagged=bridge-vlans,ether1-trunk untagged=ether6 vlan-ids=2406
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether4 vlan-ids=2404
add bridge=bridge-vlans tagged=ether1-trunk,bridge-vlans untagged=ether16 vlan-ids=2416
Should i just give up on MK Switch?
Raumaster
Tue May 22, 2018 2:33 pm
Did you guys find a solution for the RX Overruns? I'm having exact the same problem. Firmware version 2.7...
Raumaster
Wed Jun 06, 2018 9:37 pm
Nobody?
reg51ka
Tue Jul 03, 2018 11:03 am
FezzFest
Tue Jul 03, 2018 1:59 pm
Try mailing support@mikrotik.com instead of posting on the forum. This is a user forum, there's no guarantees MikroTik staff will pick up issues here.
eevee147
Wed Jul 25, 2018 11:51 pm
same problem in version 2.8, no mikrotik help at least to know its a bug or i suck configuring it, disabling or enabling IGMP doesnt work, flow control neither, there are times when swich just blocks and i have to restart it in order to function again, i don´t know if it´s related to this Overrrun errors
john3v
Fri Aug 31, 2018 9:37 am
Hi
I had the same problem.
And I was trying to change firmware, switch ports, settings ...
Uplink constantly gets more and more RX Overruns errors (more than 30000 in 12 hours), and a little later another port also get some RX Overruns errors (about 300 for the same time) connected at 100mb.
In the end, it turned out that one of the donwlinks on the remote 100mb switch has a faulty RJ45 connector (not a defective port).
EDIT:
after a few hours RX Overruns errors appears again. e.g. nothing is solved.
Switch is sended back to local dealer (RMA).
berlevdv
Wed Sep 05, 2018 11:32 am
Same problem with very simple connection schema and standart switch settings.
Switch CSS326-24G-2S+, firmware ver. 2.8 (built at Fri Jul 13 2018)
Connection scheme: Computer with 1 Gbit/s ethernet adapter - Switch CSS326-24G-2S+ - computer with 100 Mbit/s ethernet adapter.
Trouble description: Rx Overruns counter is raising on the port where 1 Gbit/s computer connected to, performance drops down from 95 Mbit/s to 48 Mbit/s periodically.
Testing conditions:
Switch has standard settings.
Testing program: iperf-3.1.3-win64
Computer 1 Gbit/s: iperf3.exe -s
Computer 100 Mbit/s: iperf3.exe -с 172.30.10.3 -t 15000 -R
Trouble persists during usage in existing network. Test was performed just to locate trouble. We can not use this switch in production
dimiter
Tue Oct 02, 2018 12:53 pm
I have the same problem with my CSS326-24G-2S+RM ( swos 2.8 ) on router port periodically "Rx Overruns" increase in time.
There is no much traffic on the port, I use this switch in home and router is RB951G-2HND.
fedor47271
Tue Oct 09, 2018 10:03 am
Hi, guys.
Below is my previous post.
Now i have 2.6 firmware version on my CSS326-24G-2S+RM and 248 days and 04:53:15 hours uptime. Disabled «Flow control» on uplink port on others it is works.
Upgrading fireware to 2.6 ver and disabling Flow Control on the uplink port helped me to fix this problem in that time.
Not long ago i enabled IGMP Sproofing but i had another problem, not overruns.
What about you? Do you have the same problems (with overruns) nowadays?
storp
Tue Oct 09, 2018 3:49 pm
Running 2.7 on two CSS326 switches and yes, I do see some RX overruns. Will enable flow control on those ports and see what happens.
Update: Didn't help. Still get RX overruns. Noticed I have these mostly on the ports which are running LACP. Will try without LACP and see if it makes any difference....
dimiter
Mon Nov 19, 2018 4:17 pm
Switch has be changed with switch from different vendor, it seems this is the resolution for now ....
chechito
Mon Nov 19, 2018 6:42 pm
i have the same issues with CRS 326 and CRS 328
looks like a CRS 3xx series problem
becs
Fri Nov 23, 2018 3:38 pm
We are currently testing a new SwOS version for release, this version includes more fixes for performance and packet forwarding related issues which previously has been addressed in RouterOS. If you have a CRS series switch and observe the described problem with packet overruns only when using SwOS and not in RouterOS, then the solution will be in the next SwOS version very soon.
Paternot
Forum Veteran
Forum Veteran
Fri Nov 23, 2018 5:16 pm
That's great news! I'm running RoS on a CRS328 exactly due to FCS errors on the 10Gb interfaces. Fingers crossed, waiting. :D
storp
Sun Nov 25, 2018 12:48 am
Looking forward for a new version! I actually had problems with 2.8 so I reverted to 2.7 which kind of works well enough. But still having the RX overruns and RX FCS errors.
gregecslo
Tue Nov 27, 2018 12:35 pm
Hi!
How soon :) ?
RusConSPb
Mon Dec 03, 2018 7:04 pm
Hi! Any chance to get it for Christmas? :)
NeedAGeek
Thu Dec 13, 2018 5:56 am
I am also wondering on this. I can see the changelog shows v2.9 when checking for auto updates, but it doesn't seem to be available. RouterOS upgraded SwOS to 2.8p with build date 7/14/18 (yes, there's a p), but this 'p' version doesn't show in the change log or the site. Trying both auto and manual updates fail to install the 2.8 (no 'p') with build date of 10/4/18. They act like they are updating, but come back up with 2.8p again.
Please advise as I'll have to RMA these switches if I can't find a solution soon.
Thank!
Raumaster
Sat Dec 15, 2018 3:42 am
Using the SFP instead of an ethernet port for the uplink, solved my overrun (overflow on RouterOS) problem.
kosyot
Sat Jan 19, 2019 6:49 pm
Same problem ->
CSS326-24G-2S+RM, SwOS 2.9 with 10G SFP+ upLink to
CRS317-1G-16S+, SwOS 2.7
with disabled flow control :
on CSS326 lots of Rx Overruns
on CRS317 lots of Rx Pauses
with enabled flow control :
lots of Tx/Rx Pauses on both switches
no Tx/Rx Overruns on both switches
Traffic about 1,5 Gbps between two switches - most of it with MTU 9000.
Any ideas - i seem to be lost on this...
storp
Fri Feb 15, 2019 2:36 pm
I've given up on Mikrotik switches. I have two CSS326 connect through sfp+ fiber (S+85DLC03D in both ends). A lot of RX overruns, some RX FCS Errors and also on many of the other ports, not only the sfp ports. I've now moved almost all equipment to HP switches and only using a two port LAG to the HP switches and the fiberlink. Also enabled flowcontrol on SFP port. Now at least I have no errors but a lot of TX and RX pauses. With the equipment I have I can get ~3,5 Gbps throughput (can't put more load on the link with current setup). The HP switches reports no errors. Running swos 2.9 and have had the same results with earlier versions of swos. My conslusion is that either swos is broken and/or the hardware (CSS326) doesn't have enough capacity (buffers or whatever). So those running the CRS326 with Routeros seems to get it working why I am leaning towards swos problem. I hope the CRS305 and CRS309 are working better since I've been thinking of getting some of those but right now I'm looking at other brands.
kosyot
Tue Mar 05, 2019 7:55 am
Same here!
Lot of tx/rx overruns on 10G port (SFP+ to CRS317) or pauses when flow control is enabled.
I'll wait till next SWoS release and if it is not fixed will throw away and will declare it as another cheap junk.
k6ccc
Long time Member
Long time Member
Wed Mar 06, 2019 12:41 am
Same here!
You are welcome to send them to me. I have been very happy with my CRS326 (in SWOS) and two CSS326 switches and would be happy to have a spare :) I have had no problems with the three, but I'm not trying to connect at 10Gb/s - max of 1Gb/s.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
kosyot
Wed Mar 06, 2019 10:37 am
if you thing this is normal - errors tab :
Rx Overruns Tx Pauses
SFP tab:
k6ccc
Long time Member
Long time Member
Wed Mar 06, 2019 4:45 pm
Not my experience. Just looked at one of mine which shows an uptime of 199 days. There is 1 RX Overrun and 0 TX pauses. As I said, nothing faster than 1Gb/s....
Jim
Paternot
Forum Veteran
Forum Veteran
Wed Mar 06, 2019 5:10 pm
But with 199 days uptime You are running 2.8, right? I upgraded from 2.8 to 2.9 (CSS326), and saw the increase in Rx Overrruns and Tx Pauses. They are too frequent to my liking, but I don't think they have a real impact on network speed. At least, not for me.
Truth be told, although I use a 10GB trunk, the traffic is light - so maybe it is worse with heavier loads.
=== EDIT ===
10Gb trunk. That typo was killing me!
Better now. :D
=== /EDIT ==
k6ccc
Long time Member
Long time Member
Wed Mar 06, 2019 6:20 pm
Good catch. That one had not been updated. I had forgotten that I had not updated that one yet. I have a bunch of network changes coming up in a few days because of a change in one of my internet connections, so that will be a good time to update that one. A couple routers will also be updated at that time too...
Jim
chechito
Thu Mar 07, 2019 2:17 am
i think its a HOL (Head of LIne) Blocking issue
in mi case it is enough that an download interface (toward clients) negotiate at 100m or 10m is saturated to start to increase dramatically overrun counters on SWos, if running Routeros the count is called overflow in the interface receiving all the traffic from main router
tested with:
CSS 326
CRS 326
CRS 328
kosyot
Thu Mar 07, 2019 9:49 am
That means - we have that problem when traffic passes between interfaces with different speed. Most of people, I think, byes those models to extend 10G networks to old 1G equipment and it's not work...
I receive overruns on 10G eth (up-link) only.
chechito
Thu Mar 07, 2019 2:22 pm
agree with you, that's the issue, when a down-link port gets saturated the up-link port suffer from overrun/overflow
in my case im only using 1g ports and the issue is present, that imply is not exclusive of 10g uplink vs 1g downlink scenario
i was recommending this switches but from now i am stopping mi customers (mostly isp's) from buying until this issue gets resolved
kayander
Mon Apr 15, 2019 9:32 pm
Same issue on my CSS. Overruns on 10g trunk port and pauses on CRS side running routeros.
Cannot say if it affects the experience a lot, haven't catched any packet loss and the forwarding is not too bad, as I was able to record files to a remote PC at 95Mb/s through an SMB protocol. Haven't tested the actual SFP+ speeds yet as it's only between the network devices. The end users are maximum 1gbit.
Would try to do more speed testing to see if I'm able to push at least 1g simultaneously between multiple PC's.
Отправлено с моего Mi A1 через Tapatalk
ploquets
Mon Jul 08, 2019 9:38 pm
Same here... Only overruns, only at one interface 10G
Interface traffic most time is passing 2Gbps+
ploquets
Fri Jul 26, 2019 6:30 pm
Linked this CSS326 with CRS317..... with s+da0001
When Flow Control is enabled, we see RX Pauses.
When Flow Control is disabled, we see Rx Overruns
Seems the problem is with CSS326, because, we moved one 10G interface from CSS326 to the CRS317.... and it is running without erros.
No change on modules was made.
Really strange behavior.
nfored
Tue Sep 24, 2019 4:59 am
I have this same issue 2.10 I am wondering if anyone can say if they have this issue using Mikrotik SFP+ transceiver and any brand of fiber. I am starting to wonder if its a DAC issue. I can see this between my CSS3266-24G-2S+RM and my CRS309-1G-8S+ using a 10m Cisco active Twinax, as well as between my CRS309-1G-8S+ and my ESX host where there is like for like bandwidth and like for like a machine. When pushing 5gbps+ between ESX host that each have 2 10G i interfaces in an active LACP bond between them and the CRS309-1G-8S+, with 3m cisco Twinax.
Even pushing a solid 10gbps and getting this pause incrementing like my utility meter its not a huge impact on latency or bandwidth, but it is a problem if you had more sensitive setup than my home lab.
chechito
Tue Sep 24, 2019 5:36 am
very rare
with 2.10 solved the issue on most scenarios
nfored
Tue Sep 24, 2019 6:57 am
This is why I am wondering if its the DAC's. On the interface labeled Core94 I can get seeing this type of error as its a 10g link that downstream has to exit 1g link either to a lan device or the fiber internet. However on the esx it doesn't make much sense they each have bonded 10g pairs and I can see in the stats its load balancing pretty well for tx no so well for rx, to generate these errors here I ran a iperf for 3 minutes from esx03 to esx01 and a second iperf from esx03 to esx02. Its very interesting the esx03 got no errors while the other two host got errors, again leading me to ask of three identical network cards, going to the same switch what is different and the only thing is the dac's.
I honestly can say for my current needs its more of a visual issue seeing the errors than an actual issue I notice. But at the same time if swapping out dac's for optical would actually solve the problem then thats what I might have to do.
edit: On closer inspection I would expect it to be TX pause not RX pause on the core94 since its was generated running iperf to my colo so sending from a device behind this switch to an internet location limited to 1g
walterav1984
Thu Sep 26, 2019 3:06 pm
I can confirm @ploquets behaviour about CCS326-24G-2S+RM having RX pauses with Flow control enabled on the SFP1 with 10GB 3M DAC cable to CRS328-24P-4S SFP1. Both running SWOS 2.10, the RX pauses on the CCS326 are the exact double amount of the TX pauses on the CRS328.
chechito
Fri Sep 27, 2019 3:45 am
have you tried no flow control at all?
walterav1984
Fri Sep 27, 2019 11:07 am
No, indeed haven't disabled flow control I'm already glad I don't see any errors anymore. Haven't had any real issues either since there is almost no traffic on these switches some voip/webbrowsing.
The first thing I'm will to try is change the original 3m mikrotik DAC 10GB cable with another one even optical and than change the trunk port from sfp to a regular 1GB copper port on the switch.
nfored
Fri Sep 27, 2019 5:36 pm
If you look at my screen grab above you can see a list of 3M DAC's that also seem to have this same issue with Flow control enabled. I am really leaning towards trying optics out, if you try optics I would be interested to hear if that fixed it.
@chechito I have never had to disable flow control before, but I have also never used Mikrotik. In my case with 10G host to Switch communication on a single switch with active LACP between the host and the switch, Do you think I should try to disable flow control? I know I need it on my SFP7 link that links my two Mikrotik switches since the devices on the second switch are all 1g.
Thank you all for your time
-Fred
chechito
Fri Sep 27, 2019 7:02 pm
i always use flow control disabled on all installations
chechito
Tue Feb 11, 2020 6:21 pm
i dont understand Why MikroTik do not publish buffer size of any switch on their product line
that info its very important to forecast switch performance
IPANetEngineer
Trainer
Trainer
Tue Feb 11, 2020 6:28 pm
I agree, i'd like to see buffer numbers on all the switching chips to be able to plan.
The Marvell Prestera chipset this switch is based on (98DX3236) is used in a few other platforms and the listed buffer space is 12MB for the 24 port model.
https://eltex-co.com/upload/iblock/9af/ ... 0.1_en.pdf
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
mattlach
Tue Aug 11, 2020 6:14 am
I have a CRS317-1G-16S+RM as my main switch in my rack, extended via 10GBase-SR and OM3 fiber (Finisar Transducers) to two remote CSS326-24G-2S+RM and one CRS305-1G-4S+.
All the clients attached to the secondary switches are gigabit only.
I have a large number of RX pauses on the SFP+ port on the CRS317 which goes to one of the CSS326 switches. The corresponding SFP+ port on the CSS326 has TX Pauses, (but only about half as many as the CRS317 switch has RX pauses for some reason. I would have thought these would match)
The other CRS326 and the CRS305 are both fine without any pauses.
All of my switches are running SWOS.
Not sure if I am having the same issue as those of you in this thread, if it is a switch hardware issue, a switch software issue, my choice of transducer, or bad fiber that is causing this.
I only used the Finisar transducers because they are what I already had, and they seemed to work.
Signal between the two switches seems perfect with TX dBm on one almost identically matching RX dBm on th eother and vice versa.
Appreciate any thoughts or suggestions.
kosyot
Tue Aug 11, 2020 11:34 am
Try mention above on 317:
Boot RouterOS on it, upgrade it to latest version. upgrade system firmware too. Boot SwOS and upgrade it to latest version. Remove TX/RX flow control on all switches.
Cheers
mattlach
Fri Aug 21, 2020 3:12 am
Cheers
I'll have to try that when I have some light usage some time. Thnaks for the suggestions.
So are you saying that there is firmware on the router that is not updated when you update SwOS and only updated when you update RouterOS?
Well, I figured out why it was only affecting the ports of one of the two CRS326's was connected to.
Turns out I somehow missed updating it. It was still on SwOS 2.07, or something like that. When I caught it, an dupdated it to 2.12, I now have paus frames on th eports of both the CRS326's
I'm guessing the CRS326 added flow control support somewhere between 2.07 and 2.11.
Users browsing this forum: No registered users and 10 guests
