asle
Newbie -> can not enter commands in terminal!
Mon Nov 06, 2017 5:02 pm
exptected end of command line
No matter what I write in the console I get this message. What am I doing wrong? I am trying to enable l2tp-server like this:
[aslint1@aslint] /interface l2tp-server> set enabled=yes
expected end of command (line 1 column 12)
How do I enter commands??
BartoszP
Re: Newbie -> can not enter commands in terminal!
Mon Nov 06, 2017 5:11 pm
Are you sure that your "set" command syntax is correct?
Try to write "set ?" and you will see that "set" command has more fields to fill than you have entered.
Real admins use real keyboards.
giorgiop
Wed Nov 08, 2017 7:20 pm
you are missing a "sub-menu"...
it should be " /interface l2tp-server server " so as to see the server sub-menu. Imagine like going to interface --> l2tp-server --> server.
[aslint1@aslint] /interface l2tp-server server> set enabled=yes
as i can see you are trying to enable it as
all you have to do is write:
set enabled=yes
and you are ready
asle
Fri Nov 10, 2017 7:23 pm
Thanks for your replies. I was writing this wrong I guess. Now all commands work like a charm and I feel I very comfortable in the terminal :D
giorgiop
Sat Nov 11, 2017 12:40 pm
Good to know you made it work :)
Users browsing this forum: alitalib and 42 guests
