rootlinux
PPPoE over VPN
Thu Dec 14, 2006 11:31 am
Hi all,
I have a current setup like below: -
Laptop (road warrior) <-- PPTP_VPN --> PPTP_VPN_SERVER <--> MikroTik (with PPPoE server config) <--> INTERNET
I cannot connect to MikroTik's PPPoE server with the above setup. Why?
Regards,
rootlinux
sergejs
Thu Dec 14, 2006 11:40 am
PPTP will not transport PPPoE.
PPPoE works over Ethernet, Laptop and MikroTik PPPoE server should be connected to the same Ethernet network (broadcast domain).
If '<-- PPTP_VPN -->' device is MikroTik router, you can create EoIP+PPTP tunnels, than PPPoE will be transported over EoIP.
I suspect there will be a lot of overhead on this configuration, as PPPoE provides encryption too.
Let us consider most recommended configuration scenario,
1) EoIP, PPPoE. EoIP between <-- PPTP_VPN --> and MikroTik Router, PPPoE is configured on MikroTik router.
2) PPPoE server is configured on <-- PPTP_VPN --> device, then laptop is connected directly to PPPoE server.
