ste
RB1100AHx4 Switches/Block diagram
Fri Nov 10, 2017 3:24 pm
@mikrotik
I have 1100ahx4 Dude Edition and now got normal 1100ahx4.
With Dude Edition I see 3 integrated switches. With normal Edition Winbox does not show the switch menu (6.38.4 and 6.40.5).
routerboard.com does not have a block diagram for these devices.
So is there no switch in normal 1100ahx4 ? Guess not as I see the switch groups blinking groupwise at startup.
honzam
Re: RB1100AHx4 Switches/Block diagram
Fri Nov 10, 2017 5:25 pm
LAN, FTTx, Wireless. ISP operator
ste
Fri Nov 10, 2017 6:12 pm
Thanks.
ste
Mon Nov 13, 2017 10:11 am
Did a throughput test port1/port2. Could push nearly 1GBit/s udp traffic FDX to port1 and another to port2. Would not work with switch between. So Winbox is correct. There is no switch.
BartoszP
Mon Nov 13, 2017 10:41 am
...So is there no switch in normal 1100ahx4 ? Guess not as I see the switch groups blinking groupwise at startup.
My RB1100AHx4 has no Switch menu either.
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
ste
Mon Nov 13, 2017 11:55 am
@Mikrotik
Could you please add a block diagram for RB11AHx4 (non Dude Edition). I guess the Bandwidth numbers are different, too.
This is a great device as it has a wide temperature range. It uses low power (I see <10W poe-powered). It has no fan (which are the first parts failing). It has all power input options I could think of. It is faster than AHx2 and it is cheaper.
Well done !!
vadimbn
Tue Nov 14, 2017 10:27 am
@mikrotik
You can see a photo.
There are three switch chips with a transformers, there are no disk interfaces only. This CPU have too few RGMII interfaces (otherwise "Dude edition" also would not have a switches), so You can not output 13 ethernet ports directly from CPU. So if You have no switch menu - this is the reason for contacting technical support. All IMHO :).
Veni. Vidi. Feci.
RBSXTLTE3-7, CRS326-24G-2S+RM, RB850Gx2, RBMRTG, RB1100AHx4, RB750Gr3, RBD52G-5HacD2HnD-TC, Woobm-USB
ste
Tue Nov 14, 2017 11:32 am
@mikrotik
Ok. So we have to wait for a SW-Upgrade.
There is a big free place on the left. Looks like a RB1100AHx8 is possible ;-).
normis
Tue Nov 14, 2017 11:37 am
That space is not free on the RB1100AHx4 Dude Edition model.
ste
Tue Nov 14, 2017 1:02 pm
Looked into the block diagram of 1100ahx4 dude edition. As Switch is connected with 2,5Gbit/s to CPU my test was not valid as it did not max out the switch-cpu connection.
Another advantage to 1100AHx2 which has only 1GBit/s between switches and CPU. There you cant route more than 500MBit/s between 2 switched ports.
nightcom
Tue Nov 14, 2017 7:52 pm
I'm looking for something like Dude Edition but sadly no SFP+ port :( does MikroTik planning to release something like Dude Edition but with one SFP+ cage? I know you got this model CCR1009-7G-1C-1S+ but it's to big jump with power and price (and fan's mounted what's make this unit loud), please release something between those two units ;)
RB3011UiAS-RM / RB2011UiAS-in / RB750Gr3 + Dude / CRS326-24G-2S+RM
jebz
Wed Nov 15, 2017 9:51 am
The CCR1009-7G-1C-PC fits the bill of middle ground and no fan.
newranman
Re: RB1100AHx4 no switch menu
Thu Nov 16, 2017 7:13 am
I can also confirm there is no switch menu in webmin or webfig. I did configure it with the initial firmware for the the ethernet interfaces for master ports. Now on last bugfix and current its gone in winbox and webfig. I tried to downgrade to the previous bugfix version but it didn't reappear. The options are still there in the cli and can be configured.
[admin@house] /interface ethernet switch> print
# NAME TYPE MIRROR-SOURCE MIRROR-TARGET SWITCH-ALL-PORTS
0 switch1 Realtek-RTL8367 none none
1 switch2 Realtek-RTL8367 none none
2 switch3 Realtek-RTL8367 none
[admin@house] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 ether1 1500 64:D1:54:CE:98:C8 enabled none switch1
1 ether2 1500 64:D1:54:CE:98:C9 enabled none switch1
2 ether3 1500 64:D1:54:CE:98:CA enabled none switch1
3 ether4 1500 64:D1:54:CE:98:CB enabled none switch1
4 ether5 1500 64:D1:54:CE:98:CC enabled none switch1
5 R ether6 1500 64:D1:54:CE:98:CD enabled none switch2
6 S ether7 1500 64:D1:54:CE:98:CE enabled ether6 switch2
7 S ether8 1500 64:D1:54:CE:98:CF enabled ether6 switch2
8 S ether9 1500 64:D1:54:CE:98:D0 enabled ether6 switch2
9 RS ether10 1500 64:D1:54:CE:98:D1 enabled ether6 switch2
10 ether11 1500 64:D1:54:CE:98:D2 enabled none switch3
11 ether12 1500 64:D1:54:CE:98:D3 enabled none switch3
12 ether13 1500 64:D1:54:CE:98:D4 enabled none switch3
BartoszP
Thu Dec 07, 2017 4:33 pm
Any chance for fix?
vadimbn
Thu Dec 07, 2017 7:54 pm
Any chance for fix?
What's new in 6.41rc61 (2017-Dec-06 08:15):
*) winbox - added switch menu on RB1100AHx4;
Veni. Vidi. Feci.
BartoszP
Mon Dec 11, 2017 1:57 am
Thanks for info but 6.41 is very experimental ... I would like to see it in 6.40.6
Users browsing this forum: ObiDanKenobi and 50 guests
