CrazyApe
Dude client not responding
Wed Nov 15, 2017 5:56 pm
i have problem with dude running on RB1100ahx4 dude edition. Complete clear instalation of ROS and dude package. I set only IP adress, password and started to add devices.
Problem is that my dude client often stucks and show "not responding" like in picture. It takes about 30 sec to unstuck and respond again.
I tried older dude package 6.39/6.40, older ROS, 2 laptops runing win 7 profesional 64bit same problem..
Problem is when i try to edi/add new device.
Any solution for me? Thx
jarda
Re: Dude client not responding
Thu Nov 16, 2017 1:27 pm
I have the same repeated problems. But didn't nothing with it, restart of client helps for a while. Other bad thing is that client prevents correct shutdown of windows 7 and when minimised to the tray (small icon aside of clock) with no icon on task bar it will not open up by clicking on that icon.
Hedsteem
Wed Nov 22, 2017 5:54 pm
I had to Turn Off Probing Globally (Turns everything white) to add devices..and then Cut it back on when your done Its a Dude Bug Running CHR 6.40.5 Been doing it since 6.38. This is my work around but needs to be fixed.
CrazyApe
Thu Nov 30, 2017 4:38 pm
Yes restart help for few "add/edit" but its realy annoying. :-(
CrazyApe
Tue Jan 23, 2018 5:11 pm
Still no solution ?
jarda
Thu Jan 25, 2018 5:05 pm
Nothing so far. Looks like mikrotik doesn't do anything with dude again.
sid5632
Thu Jan 25, 2018 8:40 pm
It's disappointing isn't it. This is what I got in response to a recent problem report:
"We have stored all your provided information, and will take a look at it when the active Dude development will renew!"
jarda
Fri Jan 26, 2018 12:17 am
Really disappointing. Definitely.
Treath1
Fri Mar 09, 2018 4:37 pm
I can't seem to click the attachment or picture from the original post.
Mine also freezes up and I notice under services of a newly created device it says "Unknown - 4.29G "
slech
Long time Member
Long time Member
Sat Mar 10, 2018 8:51 pm
Treath1,
After forum update some attachments are broken.
Similar situation is described it the forum post: The program thinks for a long time!.
Thank you!
sorry for my english
CrazyApe
Fri Mar 23, 2018 2:11 am
Hey MikroTik do something with this please....
one service (ping)
password and user set
IP adress set
Router os checkbox checked rest unchecked
Rest default setting
Attacgnebts added agaub
deanMKD1
Fri Mar 23, 2018 9:50 pm
Dude freeze for me too.. After loading takes about 35 seconds to back to normal.. 6.40.5 bugfix version on RB750Gr3.
CrazyApe
Wed Mar 28, 2018 2:44 pm
After "unfreeze" i can see in general tab Unknown - 4.29 G grey interface. Thats probably the problem. But i had added only ping service nothing more.
kburley
Tue May 14, 2019 12:46 am
Just wanted to say that 13 months after the last post here the problem is not resolved in v6.43.14.
Settings windows will stop responding when editing to add information to a device within a submap and once it's back the the Ghost of 4.29 G appears. The window will "hang", but CPU is not adversely affected.
Restarting the server clears the issue, however it'll crop up again on any new devices where I'm adding RouterOS, and sometimes it will appear on Unifi APs (on which I do not enable RouterOS at any point).
It doesn't seem to reoccur on any devices once it's gone, even if I have to manually restart RouterOS on the device.
The only real issue is the delay between double-clicking to open the settings window on a device. The Ghost of 4.29 appears benign and doesn't seem to affect anything at the sub-map level, and doesn't appear to have any effect on whether or not a device shows as "up". If you acknowledge a device with the Ghost of 4.29 on it, that ack on the Ghost of 4.29 G will be persistent and can't be unack'd, but that acknowledgement appears nowhere on the submap view, the map view or on the device icons. It will only appear in the settings window on the device.
All in all, not the worst problem... but the delays can make entering/editing multiple devices a pain. I don't use network discovery and all devices are entered manually as some are "internal" to the client and some are gear on our own network.
I look forward to this being fixed.... someday.
Users browsing this forum: No registered users and 10 guests
