RB86
Unable to access RB via webbrowser
Thu Nov 16, 2017 9:59 pm
I have been given the 193.191.xxx.xx as public ip address
Configured the interfaces as follows
And the firewall is this
But still not able to connect via webbrowser. What is wrong?
blajah
Re: Unable to access RB via webbrowser
Thu Nov 16, 2017 10:20 pm
First you should hide your IP addresses in your original post. Next, you should check IP->Services, just to make sure there is nothing changed. Your firewall rule is accepting (matching ) some traffic.
One additional note, i guess you are not trying to open WebFig from LAN side, just pointing your browser to Public IP?
P.S.
I can not access your IP telneting to port 80, so if you see some connections from Serbian IP's its just me ;)
sid5632
Long time Member
Long time Member
Thu Nov 16, 2017 11:07 pm
I suggest you put the WAN on ether1 not ether5 unless you know what you're doing.
I don't know what you've done with your master/slave ports either.
ether1 should not be a master or a slave.
ether2 should be a master and ether3-ether5 should be slaves.
(Until 6.41 of course)
gamba47
Fri Nov 17, 2017 9:08 pm
Can i ask about this? why ether1 is better than ether5 ? thanks for your time!
gamba47
sid5632
Long time Member
Long time Member
Fri Nov 17, 2017 9:12 pm
Because that's what the default configuration is set up for. Otherwise you have to change lots more things.
jarda
Fri Nov 17, 2017 10:21 pm
I always suggest to fully remove the configuration and set only the features and parameters you really need. It is also wise to keep ether1 unconnected if possible because an accidental overvoltage can damage port and only ether1 is capable of pxe boot for netinstall.
RB86
Sat Nov 18, 2017 10:29 am
P.S.
Thanks for your response.
Yes I am entering the public ip in the browser and trying to connect that way with the RB.
it does work when connected to the RB via LAN but when I unplug the cable, it doesn't anymore.
Laptop ------- 192.168.xx.x RB 10.0.x.x/30 --------10.0.x.x/30 RB 10.0.x.x/30 ------- bridge to another building across the street --- 10.0.x.x/30 RB 10.0.x.x ----- 10.0.x.x/30 RB
The above is the setup and is located at my school.
The first RB should stay at school and have a public IP address so that way I can access it from home and try to configure it.
RB86
Sat Nov 18, 2017 2:19 pm
Could you explain me what is the difference and importance of those master slave ports?
I now have put the public ip address on Ether1. Ether2 is master port, 3-5 are slave
jarda
Sat Nov 18, 2017 3:38 pm
A switch is connected to cpu by master port. Other slave ports of the same switch group are not directly linked to cpu.
RB86
Mon Nov 20, 2017 5:13 pm
Does someone have an idea? I am at school now and it still doesn't work.
