MUM Europe 2020
kolorasta
Problem after storm
Mon Dec 18, 2006 3:46 pm
There was a big storm in my city... after that some clients could not connect to my AP... what could have happened?
i have checked this:
*clients ants are aligned
*clients ap are working
*clients that can't connect can't see my ssid, but can see other ssid and can connect to them
*some clients can connect to my ap and see my ssid
i have a RB532 with an SR2...
The problem is in my SR2 ?? my ant???
before the storm everything was working fine
HarvSki
Mon Dec 18, 2006 4:01 pm
It could be water in the co-ax / antenna blown in by high winds or (more likely if it was an electrical storm) the SR2 radio's front end killed by a close lightning strike. I've had the latter happen to 3 of my APs this year, I will be installing lightning protection as soon as I can afford it. I think of the effect as somehow making the AP muffuled so only some clients will work.
kolorasta
Mon Dec 18, 2006 4:30 pm
if the SR2 radio was kill... is it possible for some clients to still connect?
HarvSki
Mon Dec 18, 2006 4:39 pm
I think you will find that the SR2 is mortally wounded rather than killed out right, it will probably need replacing.
Was it a lightning (electrical) storm?
kolorasta
Mon Dec 18, 2006 5:32 pm
yes it was a lighning storm... the most powerfull of this year...
if I change from Antenna A to Antenna B in Antenna Mode... and obviously connect the omni ant to the other connector in the SR2... do i have any probability to solve my problem? or if antenna A is down, antenna B is down too¿¿?
HarvSki
Mon Dec 18, 2006 5:52 pm
I don't think swapping the antennas over will work. You might be able to repair the card as desribed by rickard in http://forum.mikrotik.com//viewtopic.ph ... =diversity "removing the diversity switch"
hth
Users browsing this forum: No registered users and 38 guests
