MUM Europe 2020
o_hawchar86
multi-link , 3 interface , is it possible !
Mon Dec 18, 2006 9:30 pm
i have 2 internet connections and i have for it 2 routers is it possible to join the both connections in one .
each connection is 256/32 so by joining the 2 i can obtain 512/64 . in a cheaper way .
is it possible for mikrotik to set 3 network interface , and sum the two connection so a user can have the full 512/64
so
first interface : for the first link
second interface : for the second link
3rd link : for local network
i read an article about bonding as i understand the article was for wireless inteface and it's not the case here ! .
sergejs
Tue Dec 19, 2006 8:56 am
Bonding is not designed especially for wireless, you can use it in another media too.
Probably, the following configuration sceanario will be the most suitable for you,
http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
o_hawchar86
Tue Dec 19, 2006 5:52 pm
/ ip firewall nat
add chain=srcnat connection-mark=odd action=src-nat to-addresses=10.111.0.2 \
    to-ports=0-65535
add chain=srcnat connection-mark=even action=src-nat to-addresses=10.112.0.2 \
    to-ports=0-65535
as i understood from this example that i can use the same router foro routing many link , i divise my customers into two groups "odd" and "even" the first group go through the first gateway and the second through the second...
but this is not what i want !
if i had the first link 256/32 , and the second link 256/32 the member into "odd" can maximum access 256/32 i want that the member can access 512/64
the question is : can the "odd" be equal of "even" and does this solve the problem thanks for ur patience
savagedavid
Trainer
Trainer
Wed Dec 20, 2006 7:49 am
The simple answer is: no. You cannot "join" two lines together to get a single higher speed line.
Equis
Forum Veteran
Forum Veteran
Wed Dec 20, 2006 8:28 am
Unless you have control of both ends :-)
Users browsing this forum: No registered users and 53 guests
