markom
RB960PGS + POE cisco meraki mr33
Thu Dec 07, 2017 12:13 pm
I have problem to power cisco meraki mr33 from 960PGS.
both devices say 802.3af PoE compatible but cisco want power on on mikrotik.
I am using 12V 2A powering to mikrotik. Does some one have similar problem in the past ?
cdiedrich
Forum Veteran
Forum Veteran
Re: RB960PGS + POE cisco meraki mr33
Thu Dec 07, 2017 12:25 pm
I'd bet it's the voltage.
the mr33 needs at least 37V
You're powering your hEX PoE with 12V. AFAIR there's no up-stepping. Power your device with at least 37 Volts and it should work.
And from my experience with the mr33, better go with 48V directly (they can be divas when running at the lower end of the supported voltage range).
-Chris
markom
Thu Dec 07, 2017 1:07 pm
TY this is closed
