plam40
RADIUS - how to not account local traffic
Wed Dec 20, 2006 6:19 pm
I got the following setup :
      local FTP_____RADIUS
     dsl ------> MT ----> MT (AP) ----> CLIENTS
                 |______ PPPoE___________|
My problem is that Radius accounts all the traffic for each client , but I need to account only the traffic to DSL and not account any local , like FTP or local HTTP !
I have unchecked the box "Account local traffic" but it still accounts every single packet .
Any soloution will be pretty much appriciated !!!
Tahnks in advance !!
smacebr
good question
Wed Dec 20, 2006 11:07 pm
Here I'm using PPPOE instead of VPN but I have this problem too. I would like NOT to accouting traffic to some networks like 10.0.0.0/8, 192.0.0.0/8, 200.111.2.24/29, 200.10.20.176/28 for example. If I could make it would make my life MUCH easier!!!! Mikrotik is there any solution?
gideono
Thu Dec 21, 2006 10:18 am
I have the same problem.
tneumann
Thu Dec 21, 2006 4:12 pm
If you need to do accounting based on source and/or destination addresses your only choice is probably NetFlow. Radius accounting has no knowledge of where the traffic comes from or where it goes to.
--Tom
Hellbound
Long time Member
Long time Member
Thu Dec 21, 2006 8:04 pm
--Tom
Radius may not care,
MT can care and know where traffic comes and go and MT is the one reporting to Radius.
maybe the option is not working and it only left there for decoration to make sure that MT ROS is a rich feature RouterOS.... just kididng...
any idea?
tneumann
Thu Dec 21, 2006 9:19 pm
What option do you mean? The account-local-traffic option that plam40 was taking about? That pertains only to traffic that is originating from/destined to the router itself, see
http://www.mikrotik.com/testdocs/ros/2. ... 5966296164
it has nothing to do with declaring certain source and/or destination IP networks as "local" and to then exclude them from accounting.
--Tom
marko_bg
Sun Dec 24, 2006 3:56 am
plam40
That is true!
Sun Dec 24, 2006 8:29 pm
The check box for account local traffic has nothing to do with RADIUS but i do not get it :? there is such thing for the flow and there is no for the radius ...
Geoffb
Tue Jan 09, 2007 10:49 am
I'm having the same issue with the same setup as you. I really wish i could get radius to exclude traffic done to the local ftp server.
Coz atm i need to log in to winbox every morning and check the queues then convert each one to bytes and add it all back into radius for each user one by one.
As you can guess it's extremely time consuming and frustrating.
ropebih
Re: RADIUS - how to not account local traffic
Mon Apr 07, 2008 10:53 pm
Is it possible that mikrotik create option like "exclude from accounting"? In that option you could add IP address which will be excluded from accounting.
Users browsing this forum: Google [Bot] and 83 guests
