cajkovski
CHR bandwidth consumption
Tue Dec 12, 2017 1:44 pm
Hi, I am issuing problem with bandwidth consumption on CHR -v6.40.50.
I installed CHR and left it online, without using it as VPN server or any activity att all.
After tree weeks I see ether1 interface generated over 1.2 TB off bandwidth.
I have only one interface on VPS server.
jarda
Re: CHR bandwidth consumption
Tue Dec 12, 2017 9:52 pm
You maybe have left it unsecured so someone succeeded to find it. Normal thing...
cajkovski
Wed Dec 13, 2017 9:51 am
I changed all ports and disabled all service, I only left possibility to connect on it via Winbox on port 1463. Only service/script that I installed and it was active is blacklist. According to the log, there was attempt to connect via pptp but without success.
jarda
Wed Dec 13, 2017 10:44 am
Ok. If there is still another traffic, see the torch.
If you detect attacking ip address, you can drop it in the raw firewall table. It will vanish in the time when you will not be sending responses back...
hajde
Fri Dec 22, 2017 5:31 pm
Maybe, DNS attack, torch, port 53 udp.
Users browsing this forum: No registered users and 20 guests
