antonsb
Re: wAP 60G experience
Sun Apr 08, 2018 1:06 pm
RC releases will show more information on aligment by using sector calibration inforation
There are T/Rx-sector items in
interface w60g monitor 0 once
command output.Anybody know what this last two lines exactly means?
connected: yes
       frequency: 60480
  remote-address: 30:07:4D:81:D0:B6
             mcs: 8
          signal: 80
       tx-sector: 54
       rx-sector: 96
npero
Thu Apr 12, 2018 8:44 am
wAP 60G by the google maps 238m distance. In good weather condition
mcs: 4
          signal: 40
            rssi: -70
       tx-sector: 28
  tx-sector-info: left 3.8 degrees, down 3.8 degrees
       rx-sector: 96
In btest UDP have 600-800Mbps also have half hour with rain speed drop to 100Mbps in test.
For now wating rain again to see results.
juliokato
Mon Apr 16, 2018 8:39 pm
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
djvolt1942
Mon Apr 16, 2018 8:47 pm
mcs: 4
          signal: 40
            rssi: -70
       tx-sector: 28
       rx-sector: 96
On what ROS? Newest r59 or 6.41.4?
There are same wAP60G link without any our shields etc?
_________________
PtP 60GHz Pro MHD: $660 exc VAT
http://24.multimediahd.pl/en/60ghz/8-wi ... link-.html
www.siec.multimediahd.pl/60ghz
Madex Cables
brasileottanta
Tue Apr 17, 2018 5:36 pm
Hello ,
our first test on real link. Distance about 240m , perfect LOS without particular aim.
We using traffic generator for check bandwidth and latency. Test using tcp packet of 1500.
Very nice :-)
brasileottanta.
ps . please make a note on rc59 changelog for Ap Bridge BROKEN !! :-9
npero
Tue Apr 17, 2018 7:35 pm
rb56 for now, planing upgrade to final version in Friday. Just wAP60G unit from Wire kit package without anything.
Also today is raining have some link drops but they has been just for 1s that say in log.
antonsb
Wed Apr 18, 2018 2:54 pm
Ap-bridge mode should be fixed in latest current and RC releases.
Insider
Thu Apr 19, 2018 1:05 pm
Sorry for delay I had long period of heavy metal :) Too busy to make things which make sense..
So.. Our tests.. With the regular body of wAP we are getting stable link for 150m, anything more make pain during rain (yes rains came finally)
The good story is we are making with wAP now links for more then 500m, with regular AP and modified clients..
Here we go 240 m with modified client, last prototype:
connected: yes
frequency: 58320
remote-address: 30:07:4D:84:A0:52
mcs: 8
signal: 95
rssi: -56
tx-sector: 27
tx-sector-info: right 3.8 degrees, down 3.8 degrees
rx-sector: 96
If we will make both clients same way it will have on same link rssi:-48, we will see if MT will go for this solution..
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
jarod
Mon Apr 23, 2018 8:15 pm
Question;
With RouterOS 6.42 i saw w60g > status: MCS: 9/10/11.
Now with RouterOS 6.42.1 i only see MCS: 8 or lower. Is this a bug of feature?
jarod
Insider
Thu Apr 26, 2018 12:43 pm
Multiple instalallation with in close range on pole brings unstability, we are now installing shields to try if performance will be better (1 site, 3APs, 20 cm far each from other, different frequencies, 3 clients on each)
http://Pojitko.cz
sup5
Thu Apr 26, 2018 5:37 pm
Question;
jarod
Seems to be a feature.
http://rfmw.em.keysight.com/wireless/he ... ncepts.htm
MCS8 is more than enough to carry 2Gbps.
More is not necessary, because 1000Base-T is the limiting factor here.
luksik
Tue May 08, 2018 3:50 pm
I've recently tested p2p on wAP 60G with tagged transmission to switch and vlans. Unicast is working without ant problems but i've noticed that multicast (iptv) streams has problem with continuity.
I'm generating (using iperf) tcp traffic between two machines that are using 60g connection and problems appears but only if traffic is from same side that multicast stream is coming.
When i'm generating (about 1Gbps) in backard direction there is no continuity errors.
Any ideas ? (link has about 10m - set on table).
Lukasz
Bergante
Thu May 10, 2018 9:57 am
I wonder... Do these units lower the MCS when transmitting multicast or broadcast traffic, like other wireless protocols? For wireless point to point links that shouldn't happen in my opinion.
If the link is very short and you are running a recent version check the signal levels, you might be suffering signal overload. I had to lower power for a 20 - 30 m link because it got a bit unstable.
luksik
Thu May 10, 2018 12:44 pm
I've tested this setup on short link (table) and outside (link about 90m). Same problem in both cases,
Lukasz
hrcho
Fri May 11, 2018 4:17 pm
Can I expect full throughput at 70 m distance through one tree using the Wireless Wire Dish (RBLHGG-60ad kit)?
ste
Fri May 11, 2018 4:25 pm
You cant expect anything with a tree.
Lakis
Long time Member
Long time Member
Tue May 15, 2018 12:18 am
Anyone tested wAP 60G (with no modification) on 210m can I get >150mbit, should I expect disconnect on light rain?
Thanks.
Bergante
Tue May 15, 2018 10:14 am
One suggestion: It would be great to be able to graph information such as RSSI, signal, MCS, tx-sector and rx-sector (or better yet, tx-sector-info) and Phy rate these interfaces.
Given that some of it is not available over SNMP and that even for people with SNMP management software it can be tricky to add custom OIDs I think it would be really helpful!
Lakis
Long time Member
Long time Member
Thu May 17, 2018 12:20 am
Thanks.
Link is up and running distance 210m, throughput is 350mbit (btest is made from wAP to wAP), 24h no disconnects for now looks promising, just waiting for the rain.
Only one minor problem, I can't understand why signal is fluctuating so much from 30-60, every second signal is changing 30-35-40-50-55-60 than again 60-50-45-35-30 all the time
Why is that ?
Oh yes I m using 6.42.1 OS.
djvolt1942
Thu May 17, 2018 12:31 am
_________________
Madex Cables
Bergante
Thu May 17, 2018 9:12 am
Why is that ?
Multipath? What does the environment look like?
With the latest releases you can try to fix the "tx-sector" parameter.
Lakis
Long time Member
Long time Member
Thu May 17, 2018 1:00 pm
djvolt1942 shields for what?
Bergante Multipath? - don't get it!, What does the environment look like? ?!like moisture, LOS... ??
marcin21
Thu May 17, 2018 1:06 pm
not sure, should I tweak something after upgrade ?
antonsb
Thu May 17, 2018 1:22 pm
How far is the link? Please provide CLI output from both ends:
/interface w60g monitor wlan60-1
marcin21
Thu May 17, 2018 1:29 pm
connected: yes
frequency: 60480
mcs: 8
signal: 50
tx-sector: 63
rx-sector: 96
connected: yes
frequency: 60480
mcs: 8
signal: 50
tx-sector: 24
rx-sector: 96
Link length is around 130m.
but I downgraded them to rc52 to have more stable link now.
antonsb
Thu May 17, 2018 2:11 pm
Try to switch used frequency to 58320 and upgrade to 6.42.1
djvolt1942
Thu May 17, 2018 2:17 pm
We use 58GHz for far link like 600, 800 meters :P
Lakis - shields for far links up to 300meters or better stability in snowy/rainy day, also for reduce SNR from wap to wap or MultiPoint...
_________________
Madex Cables
Bergante
Thu May 17, 2018 5:44 pm
It's a long shot, but depending on how you have installed the units you might be getting multiple reflections? One of my
units is installed on a window (outside of course) and it's in a corner with three walls around. That's a scenario
that can be troublesome in some cases.
In theory that might sometimes confuse the beam selection algorithm, and, if that was the case (sorry, it's really
hypothetical but I haven't seen your installation) selecting a fixed beam configuration might help.
Anyway the experiment is easy. If it's just a point to point link look at the tx-sector values when the
link is performing best and configure them statically. if that solves the problem then you had something
disturbing the beam selection algorithm.
marcin21
Thu May 17, 2018 5:45 pm
why should I change freq? It seems to work quite good with rc52. there is no noise or other 60ghz link visible under scan. besides if it works worse with newer routerOS
I doubt Your advice is to solve problem looks rather as a workaround.
Sad.
Bergante
Thu May 17, 2018 6:25 pm
Are the tx-sector and rx-sector numbers changing often? If they are, fixing tx-sector could be beneficial.
My link (very short, around 30 metres crossing a street) actually worsened a lot when Mikrotik improved the antenna patterns. But the only reason was signal overload. Reducing power solved it.
Monitor tx-sector regularly and let's see.
antonsb
Thu May 17, 2018 6:50 pm
Sad.
Different frequencies has different attenuation over air. Channel 2 isn't picked up automatically on free spectrum if "frequency=auto"
MonkeyDan
Mon May 21, 2018 8:46 pm
I had the same problem with a ~30m link. New firmware was just too hot. Lowering tx-power to 10 on both sides helped tremendously
MonkeyDan
Thu May 24, 2018 11:29 pm
And 6.43rc17 has vastly improved one of our longer links (~170m)
Waiting for a final release to upgrade to the rest.
marcin21
Fri May 25, 2018 1:10 am
what FW was before upgrade to 43rc17 ?
almdandi
Fri May 25, 2018 1:20 am
@MonkeyDan
What software are you using for the grath visualization?
marcin21
Fri May 25, 2018 1:27 am
after upgrade from
6.42rc52 to 43rc17
i've got ERROR WRONG PASSWORD after trying to login into ( using winbox 3.11)
is it some kind of very late aprilfool joke?
PLEASE mikrotik support help me solve my problem
npero
Fri May 25, 2018 9:13 am
Look viewtopic.php?f=21&t=133420&start=100#p663507 at the end of post say need to use new Winbox 3.14 in rc17.
antonsb
Fri May 25, 2018 11:34 am
new version will have distance measurement tool, it would be cool if we could get some feedback to support@mikrotik.com
marcin21
Fri May 25, 2018 2:09 pm
@npero thanks, with this beta winbox and webbox password works ok.
@antonsb where Can I find dist. measurment tool ?
Bergante
Fri May 25, 2018 2:55 pm
On the AP/master: /interface w60g station monitor 0
[admin@w60-master] /interface w60g station> monitor 0
       connected: yes
          remote: 30:07:4D::
             mcs: 8
        phy-rate: 2.3Gbps
          signal: 80
            rssi: -54
       tx-sector: 21
  tx-sector-info: left 11.4 degrees, down 11.4 degrees
       rx-sector: 96
        distance: 18.34m
And on the slave,
[admin@w60-slave] /interface w60g> monitor 0
       connected: yes
       frequency: 58320
  remote-address: 30:07:4D::
             mcs: 8
        phy-rate: 2.3Gbps
          signal: 80
            rssi: -53
       tx-sector: 20
  tx-sector-info: left 3.8 degrees, down 11.4 degrees
       rx-sector: 96
        distance: 18.33m
-- [Q quit|D dump|C-z pause]
Before someone gets nervous with the signal levels at a distance of 20 metres: I lowered tx-power to 10 for both units.
marcin21
Fri May 25, 2018 4:34 pm
strange on 6.43rc17 i get this :/
int w60g station monitor 0
  connected: yes
     remote: 30:07:4D:
        mcs: 8
   phy-rate: 2.3Gbps
     signal: 80
       rssi: -70
  tx-sector: 63
  rx-sector: 96
MonkeyDan
Fri May 25, 2018 5:41 pm
@MonkeyDan
rrdtool https://oss.oetiker.ch/rrdtool/
Specifically a Perl script to do an snmpwalk and write the values to an RRD which can be graphed with rrdgraph.
MonkeyDan
6.42.1
brasileottanta
Sat May 26, 2018 10:55 pm
after upgrade to 43rc19
djvolt1942
Sat Jun 02, 2018 12:50 am
Test in Rainy day, Light Rainfall, on 1200 meters link Rock Solid Signal 80 mcs 8 everytime
New model of aluminium antenna with draft shield on the front soon :P
https://www.youtube.com/watch?v=78On7sLnv_k
http://siec.multimediahd.pl/60ghz#400
_________________
Madex Cables
Insider
Mon Jun 11, 2018 11:38 am
Hi guys, we finalised a EM concentrator solution for ranges up to 600m.. It is compact solution for current housing with extra gain 10 dB for each end..
connected: yes
frequency: 58320
remote-address: 30:07:4D:87:84:16
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -51
tx-sector: 27
rx-sector: 96
distance: 231.2m
Shortly we will have ready market solution
We found some bug, that by this level of signal device disconnects time to time
http://Pojitko.cz
antonsb
Mon Jun 11, 2018 12:32 pm
This will be fixed in next RC version
Insider
Mon Jun 11, 2018 1:37 pm
OK, I lied you.. Should be fine up to 1 km with -63
We will build a link shortly for 973 m to test it..
Here it is how it looks like in prototypes, it has simple aiming tool (which is completely correct)
Next week we will improve the LHG.
http://Pojitko.cz
djvolt1942
Mon Jun 11, 2018 2:13 pm
This Horn is made from Plastic or Metal? :P
You can reach on this about 600m?
_________________
Madex Cables
Insider
Mon Jun 11, 2018 2:14 pm
What you prefer, plastic or metal ? We can make you limited edition :)
We will reach 1km with this.
http://Pojitko.cz
Users browsing this forum: No registered users and 15 guests
