moodnasser
i can't login in winbox from clud
Tue Dec 26, 2017 10:27 am
hello
my issue is when i active cloud in cloud core ( 2 ) and put the name in winbox i login in cloud core ( 1 )
i can't login winbox from name cloud for cloud core ( 2 ) can help me plese
Anumrak
Re: i can't login in winbox from clud
Tue Dec 26, 2017 12:27 pm
Which DNS server do you use on routers in order to resolve DNS records?
moodnasser
Tue Dec 26, 2017 12:41 pm
look at the pc
poizzon
Tue Dec 26, 2017 8:53 pm
ip firewall rules on CCR1 ?
what ip address you getting, ping CCR2 - ping xxxxxxxx.sn.mynetname.net
poi
moodnasser
Tue Dec 26, 2017 10:28 pm
moodnasser
Tue Dec 26, 2017 10:35 pm
poizzon
Wed Dec 27, 2017 2:34 am
In first picture we see that IP address is 192.168.4.1/24
But in cloud we see 178.80.xxx.xxx
I didn't remember which IP address cloud are getting..
Please provide full IP structure.
As I understood you need forward winbox management port on first router and accept management firewall rule on second router.
P.s. DDNS - it means it taking external IP address, so it is CCR1 , remove DDNS and you get CCR2 WAN IP address
poi
moodnasser
Wed Dec 27, 2017 7:00 am
this ip for LAN ( out ) from CCR1036 ( 1 )
this is real ip a variable , When I turn off the cloud and turn it on again it will change the ip
explain what you mean
poizzon
Wed Dec 27, 2017 7:14 am
this is my guess , try remove DDNS and check which IP address you'l get ?
https://wiki.mikrotik.com/wiki/Manual:I ... Properties
sorry I not fully understood your schema at the begining :)
you are double NAT'ed, so if you want connet from WAN to CCR2, then you must add forwardin rule in CCR1
poi
Anumrak
Wed Dec 27, 2017 4:16 pm
Ping your domain names from both routers.
moodnasser
Fri Dec 29, 2017 10:44 am
moodnasser
Fri Dec 29, 2017 10:47 am
can you give me a rule please
poizzon
Fri Dec 29, 2017 12:04 pm
Simple port forwarding rule.
Make it on ccr1
poi
poizzon
Fri Dec 29, 2017 12:06 pm
This is example some port forwarding , just write ccr2 IP address.
ip firewall nat
add chain=dstnat protocol=tcp dst-port=8291 action=dst-nat to-addresses=192.168.100.77 to-ports=8291 comment="Winbox to CCR1" disabled=no
poi
moodnasser
Fri Dec 29, 2017 12:44 pm
ip firewall nat
poizzon
Fri Dec 29, 2017 12:49 pm
CCR2 add inut firewall rule
/ip firewall filter add action=accept chain=input disabled=no dst-port=8291 protocol=tcp
and from where you are trying connect ?
from yours local or from wan network ?
poi
moodnasser
Fri Dec 29, 2017 12:59 pm
cloud core ( 1 ) Site A
Cloud core ( 2 ) Site B
i'm trying connect from Site B
moodnasser
Fri Dec 29, 2017 1:03 pm
Do you have Teamviewer ?
poizzon
Fri Dec 29, 2017 1:44 pm
yes,
is there are option write private messages ? :)
poi
moodnasser
Fri Dec 29, 2017 2:15 pm
yes,
No :shock:
send me email to send you team viewer
p-sa@hotmail.com
poizzon
Fri Dec 29, 2017 4:49 pm
Check your email
poi
Users browsing this forum: No registered users and 39 guests
