sino32
RB951G-2HnD - speed limit 280 Mbps
Wed Dec 27, 2017 2:36 pm
My provider changed download speed to 550Mbps, but RB951G-2HnD allow max 280Mbps.
Configuration is simple PPPOE to provider -> NAT to all lan ports. No queue, no special firewall rules, only few port forward rules.
Can you help me select powerfull microtik router, which will not have a problem with speed 550Mbps?
Thank you
freemannnn
Long time Member
Long time Member
Re: RB951G-2HnD - speed limit 280 Mbps
Wed Dec 27, 2017 3:09 pm
did u turn on fasttrack at your rb951?
rb750gr3 is a nice price router but it does not have wifi. i read in the forum that is very powerfull. of course you can add an extra ap. (like wap ac)
https://mikrotik.com/product/RB750Gr3
also
RB3011UiAS-RM
RB1100AHx4
https://mikrotik.com/products/group/ethernet-routers
InoX
Wed Dec 27, 2017 5:10 pm
RB951G-2HnD can route via pppoe over 800mbps with fasttrack in my case.
poizzon
Fri Dec 29, 2017 6:16 pm
https://mikrotik.com/product/RB951G-2HnD
Show config, some think is missconfigured
poi
Users browsing this forum: No registered users and 24 guests
