safiullahtariq
balance-tlb for Wireless Links
Thu Dec 28, 2017 8:25 pm
Hi All,
I hope you are doing great.
I have 2 wireless links, one gives 50mbps and the other one is less i.e. 32mbps.
What I want to do is Balance-tlb so that I can get total speed of both links and also get fail-over. Which mikrotik router/switch do you suggest?
I dont want to do balance-rr as it will give me lesser speeds.
Please help.
Regards
safiullahtariq
Re: balance-tlb for Wireless Links
Fri Dec 29, 2017 2:28 pm
Hello, will anyone help?
safiullahtariq
Fri Dec 29, 2017 6:27 pm
Following is the actual setup what I will setup.
Mikrotik R1 eth1 ---->(wireless link 10mbps) ----> Mikrotik R2 eth1
Mikrotik R1 eth2 ---->(wireless link 20mbps) ----> Mikrotik R2 eth2
I want to bridge links so that I can get 30mbps.
What should I chose, obviously balance-rr wont work. Should it be balance-alb or balance-tlb.
What I require i.e. 30mpbs can this really happen?
And what mikrotik router should I use?
Regards
safiullahtariq
Thu Jan 04, 2018 6:23 pm
This is the reply i got from Mikrotik Support.
The balance-alb/tlb is RouterOS feature which is supported in all RouterBoard devices and there should not be problems achieving 30Mbps throughput with any of them.
nice reply, waited for that for days... :)
mac86
Tue Jul 31, 2018 7:30 pm
no updates here ?....
https://www.netpro-ar.com
MTINE - MTCWE - MTCRE - MTCTCE - MTCNA
Patagonia Argentina IT Consultant
Mikrotik user from V2.7.7 - Aug/2003
safiullahtariq
Fri Aug 17, 2018 8:08 pm
what reply do you want :) ??
sup5
Fri Aug 17, 2018 10:45 pm
Maybe pulling one VLAN trough the slower link and two VLANs through the faster link.
Then make a 3x bonding out of all three VLANs.
That would make up for a 2:1 load balancing, which roughly meets the 50/32 ratio.
Users browsing this forum: Bing [Bot] and 131 guests
