Wed Jan 03, 2018 3:59 pm
Thank you for the quick response, but I guess i mislead you with the lack of information that i gave.
I want to use this for a slave port since i want that ether-port as a switch port. I dont want to go in routing on that switch.
I followed your advice yet this is the response that im getting.
add action=drop chain=input in-interface=ether19 port=67-68 protocol=udp
#in/out-interface matcher not possible when interface (ether19) is slave -use master instead (ether1-master)
